How do you expand the vertical height of the screen?
    Scholar:
  • 37 Answers
There is usually a few buttons on the bottom or side of the screen. You push the menu button then one of the other buttons to scroll through the list of options on screen. Should be a vertical position option somewhere. Most of the time they just list options as symbols and not as words so you need a bit of trial and error to work out what each option is. All monitors are different so you have to work out how each one works when you try to change settings.
Posted on Dec 31, 2010
Adjust vertical height kg 55lh55
To adjust the height of the picture, you have to enter its service mode option, and should adjust the vertical amplitude data value, accordingly. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 24, 2014 | LG 55LH55 55 in. HDTV LCD TV
Our Panasonic model PTH 3778R has elongated its vertical size about 2 inches outside the screen limit. Is there a way of adjusting the vertical size?
Usually this means that a cap in the vertical circuit is starting to fail. Are there any other symptoms at all? Does the height seem stretched more at the top?
Dan
May 09, 2008 | Televison & Video
Top of screen disappeared...cant see score of game
The Height adjustment is off... look in the back of the TV set, it has some knobs in the back, one should be vert.lin for Vertical Linearity adjustment, and there is another call Vert.Hgt. for Vertical Height adjustment. try adjusting the Vertical Height first with someone watching in the front of the big TV to see if the top comes back into view, you might have to adjust the knob very slowly one way then the other way, to make this adjustment. If it doesnot adjust take it to a TV shop to get it repaired.
Good Luck.
Nov 11, 2010 | Hitachi 57F500 57" Rear Projection...
The tv screen has reduced in height ,how to increase it's height
deu to vertical amp problem pls check the vertical out put ic
Aug 24, 2010 | Daewoo DTQ-20U4SC 20" TV
How do you adjust a headlight from pointing up to the right height
VERTICAL AIM ADJUSTMENT
1. Park the vehicle on a level surface approximately 7.6 meters (25 feet)
from a vertical wall or screen directly in front of it.
2. Measure the height from the
center of your headlamp to the
ground and mark a 2.4 meter (8
foot) horizontal reference line on
the vertical wall or screen at this
height (a piece of masking tape
works well). The center of the lamp
is marked by a 3.0 mm circle on the
headlamp lens.
3. Turn on the low beam headlamps to illuminate the wall or screen and
open the hood.
4. On the wall or screen you will
observe a light pattern with a
distinct horizontal edge of high
intensity light with a slight angle
towards the right. If this edge is not
at the horizontal reference line, the
beam will need to be adjusted.
5. Locate the vertical adjuster on
each headlamp, then use a 4 mm
socket/wrench to turn the adjuster
either counterclockwise (to adjust
down) or clockwise (to adjust up)
aligning the upper edge of the light
pattern up to the horizontal line
6. HORIZONTAL AIM IS NOT
REQUIRED FOR THIS VEHICLE
AND IS NON-ADJUSTABLE.
Mar 09, 2010 | 2002 Ford Explorer
Are there internal picture controls for the WS-55315?
Good Day; OPTION MENU "MENU 0370" SERVICE MENU. CAUTION document settings before any adjustments are made. V = vertical, H = Horizontal. Good Luck, big IRISH.
May 11, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Adjusting vertical height
I looked for info for your the Mct-2051 & imagine my surprise that Magnasonic not only doesn't have a manual for your model they don't recognize the model #. Excuse my sarcasm.
If MCT-2051 is not a typo, then the closest I could find was an MCT-2053 & there was no mention of a vertical height adjustment by software control. From my past experience this adjustment can only be performed by a TV tech because you need to access the inside of the TV.
The fact the picture has shrunk this much means that the vertical height driver is failing & eventually you will see nothing but a vertical line, stretched across the screen. Which will mean, that do to Magnasonics' lack of support, you'll be out of luck.
When shopping in the future for a TV try to stay with name brands who will support their products.
By the way, where did you hear that you could adjust the VH utilizing the remote? That could possibly be a function of digital device like a computer monitor, not an analog device like your TV.
Feb 25, 2008 | Televison & Video
Vertical problem,
chek tje vertical deflection yoke winding and the socket. readjust the vertical height control.hope this will help.
Feb 05, 2008 | Samsung TXM3096WHF 30" TV
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
