Question about FrancisFrancis! X5 Espresso Machine
Francis Francis x5
This morning...when plugging in the machine, the wall socket grounding button popped out, like blowing a fuse.  Tried the plug in a number of wall sockets with the same result.  What needs to be replaced/repaired on the Francis Francis?
  • 2 more comments
  • Marley13 Aug 27, 2008
    Same problem (recurrent). Happened last year. Plugged the X5 into another outlet and it worked fine. About a week later, switched back to the initial outlet and it worked fine for about 16months. Now the problem is recurring again (working with the "unprotected" outlet but tripping the GFCI outlet. Other appliances (blender and toaster) work fine in the protected outlet.
  • kkksss Dec 03, 2008
    Same problem here - we found the plug in the machine to be damp as well.
  • Anonymous Mar 21, 2014
    Put macintosh on its side to replace gasket and now it blows when plugged into socket
    Machine turns on but nothing happens
    Problem Solver:
  • 5 Answers
Almost certainly, your heating-element is corroded through, and with the...questionable...design of this machine, power continues to flow unchecked through the "substitute neutral" of your machine's case and ground wire, so it keeps working, sorta, until things burn out so badly within the boiler that you can't make a connection. Low boiler water-level might break that connection, too - that's how sketchy this design is. There's a reason the national electric code (and common sense) call for switching the HOT side of a circuit: to minimize the potential exposure to power as long as the switch is off. While the power-switch on this unit may do this, the F-F's thermostat, however, switches the NEUTRAL side, leaving it unable to do anything to prevent stray power from heading merrily through the machine via the ground, once your heating element has corroded through - which is a guaranteed failure item, just a matter of time. Sucks, don't it?
You could replace your element with an after-market version if you're game, but it's not a simple or quick fix. See http://www.fixya.com/support/t1029310-x5_boiler_share_did_replacement .
Posted on Oct 23, 2008
  • 515 Answers
It´s probably the boiler in the machine that is gone.
Posted on Jul 13, 2008
Central pneumatic 3gl pancake air compressor 61615 the reset button pops or blows wall socket fuse any ides why? motor brush replaced and new power cord plug put on the 3 grounding prong was cut off
most likely a start run capacitor has failed
do not remove any pins of a plug as they are all need for electricity
if the capacitor replacement makes no difference , get in an electrician to test the machine and insulation
Apr 19, 2017 | Air Tools & Compressors
Plug fuse blew.
Something is blowing the fuse if its out again, check for rails that are lower then they should be, chances are you will need a new power board.
Feb 08, 2018 | Televison & Video
Blowing the fuse
I just had this happen to me too... any ideas?
May 29, 2010 | FrancisFrancis! X5 Espresso Machine
Where to get extra parts for the Francis Francis X5 Espresso machine? I am looking for 1 and 2 cup filter baskets (for ground coffee). I have searched the internet for hours and - no luck! Not on Illy's...
I too have had problems finding gaskets for my much loves machine. Sadly, I am parting it out. I think that I have what you are looking for. Stainless steel baskets, right?
Oct 16, 2009 | FrancisFrancis! X5 Espresso Machine
Francis Francis fuse defective?
Hi
If you have power its not likely the fuse. It could be the heating element or the board.
Jun 16, 2009 | FrancisFrancis! X5 Espresso Machine
Haier window air conditioner
I suggest you check the ground of the wall socket. Many three proung sockets are not grounded.
Sep 03, 2007 | Haier hwr10xc6 Air Conditioner
FrancisFrancis! X5 Espresso Machine Logo
432 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Joe Lalumia aka...
Joe Lalumia aka...
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
