Question about LG GCC4522B CD-RW/DVD-ROM Combo Drive
Driver problem My cd rom worked properly before but now it shows error in driver. It shows "driver corrupted (code 39)"
  • Anonymous Jul 19, 2008
    i have the same problem
    President:
  • 1,257 Answers
Follow this article to fix the issue:
http://support.microsoft.com/kb/314060
Posted on Apr 23, 2009
  • 43 Answers
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)". You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Posted on Sep 18, 2008
I also have the same problem my cd is working not DVD
Posted on Aug 14, 2008
My ACER Aspire 4736Z cd-rom drive is not working. It doesn't read/write, it's not even showing on My Computer. On the device manager there's an exclamation mark (!) and a Code 10. Please h
The driver for that cd Rom is not loaded or is corrupt. You need to install a correct device driver. If it still doesn't work try reloading the os.
Dec 26, 2012 | Computers & Internet
Could not load the driver for this device. Perhaps the driver is corrupted or missing. (Code 39)
hi code 39 is a error code for a missing driver usually cd/dvd rom. go to my computer and right click /click properties /check for yellow exclamation marks against your cd/dvd rom /click/click update drivers.close program see if problem is fixed if not/
Read more: How to Fix Code 39 Driver Error | eHow.com http://www.ehow.com/how_5344400_fix-code-driver-error.html#ixzz0xzIAh2xi
follow this link .hope this helps.
Aug 29, 2010 | Computers & Internet
My DVD rom drive is not working I cannot "see" it on the system I have this error message "windowns cannot load the device driver for this hardware. the driver can be corrupted or m missing error code 29...
Check in device manager. To do this. 1st right click my computer, 2nd Click properties, 3rd click hardware, 4th click Device manager, 5th check that the computer is seeing the DVD/CD-ROM drives by double clicking the DVD/CD-ROM drives words or click the + symbol next to DVD/CD-ROM drives, the drop down menu will list your device if it’s there. If a device is listed double click the device. If it says it’s working properly click driver in the top bar and uninstall, then re-boot, the system will re-load the driver on re-booting. If the driver was corrupt it will re-install it correctly.
If the system cannot find the driver on re-booting it's missing from the systems file, go to the Support Fujitsu site and download and install the driver. Its free all you have to do is put the laptop details in the appropriate boxes and all the drivers for that laptop will be listed.
From your description of the error message it’s no doubt a corrupt or missing driver.
Hope this helps.
Feb 24, 2010 | Compaq Presario V4000 Notebook
Tsstcorp cd dvdw ts-l633a scsi cdrom device can't read the driver or it is corrupt. I am getting error code 39
Using Device Manager, look to see it laptop is sensing the presence of the cd-rom. (if it is not on the list, try removing / rebooting / and then reinstalling cd-rom) If it shows on the list, click to open it's properties and then delete the drivers for cd-rom (this will cause the laptop to reload the drivers on the next reboot) if it still doesn't work, go to micosoft updates and try to update the drivers there. If it still malfunctions, then the cd-rom may be faulty. Try replacing it with another cd-rom and see what you get.
Oct 10, 2009 | Acer Aspire 5500 5570-2609 Laptop
Drive not showing in WinXP (error code 39)Liteon Combo SOHC-5236v
After loading the Windows, the DVD/CD-ROM drives work properly, but we can not see the drives in “My Computer” (System can not recognize the drives.). When try to run the drives, it shows up a notice “Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code39).” Before solving this error, check the drives connection correctly, then follow the steps below:
Delete Device Manager. Most people will firstly think of Windows “Find New Hardware” when drives missed, but it does not always work out. To fix the problem: open “My Computer”’ “Control Panel” ’“System”’“Device Manager”’ “HDC(Hard Disk Controller) ”, then click “Delete”. Follow the note to reboot computer. After rebooting, the computer will find the Primary IDE Controller and Secondary IDE Controller again and install the drivers. Restart the computer again while the installation is completed. In this, we can get back our CD/DVD-ROM Drives.
The other way is by editing the registry to return the missed CD/DVD-ROM drives (Code 39 error.). Obviously, it is too risky to edit the registry if you are not familiar with it. To fix the error from the registry, carry out the following steps:
Exit and close all applications currently running on your PC.
Step1. Click Start > Run and type in Regedit, press Enter.
Step2. Look for the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\ {4D36E965-E325-11CE-BFC1-08002BE10318}
Delete any of the following registry entries under this key directory:
LowerFilters
LowerFilters.bak
UpperFilters
UpperFilters.bak
Step3. Reboot your PC and open My Computer to check that the CD-ROM drive is visible.
Also, have a look at the Device Manager to see if the yellow exclamation mark and the error code 39 are gone.
System errors are not welcome guests that bring up unhappy computing experience. Registry Easy (www.registryeasy.com) is a professional troubleshooting system maintenance tool that can help you to solve this error and many more.
Article Source: How to fix DVD/CD-ROM drives (Code 39 error) in Windows XP or Vista
Posted on 2 January '09 by , under TECH NEWS.
This worked for me.
Feb 12, 2009 | Lite On (SOHC5236V) CD-RW/DVD-ROM Combo...
LG GCC4522B CD-RW/DVD-ROM Combo Drive Logo
96 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
