Question about Microwave Ovens
Hi I have a FRIGIDAIRE FMV156DCA microwave. The door is sagging and not activating the switches. When I move the door up slightly the oven works. I don't see any adjustments on the door or on the switches. Brian
  • bsumm Dec 31, 2010
    Hi
    Thanks for your reply. I don't see any hinge mounting screws to loosen on the main compartment. Do the hinges on the door have adjustments?
    Thanks
    Brian
    Brigadier General:
  • 8,909 Answers
If the door is sagging, slacken the lower hinge and adjust it then adjust the catch settings on the side of the cavity by taking the cover off and lossening the screws that fix the interlock holder and with the door closed, tighten the screws back up.
Hope that helps.
Posted on Dec 31, 2010
Frigidaire microwave door is sagging
Hello Irfan, thank you for your post!
From the information you have provided the door on your Frigidaire microwave is sagging. Your door could be sagging due to the hinges or the door being damaged. I would check to make sure there is no visible damage. It is possible that the hinges and door may need to be replaced as well. To help avoid any unnecessary part purchases you may need to seek assistance from a professional technician for proper repairs. -Matt
Aug 10, 2015 | Frigidaire Microwave Ovens
My Frigidaire microwave door is sagging and about to fall off
I appreciate your post, Wayne!
From my understanding your Frigidaire microwave door is sagging and about to fall off. This could be an issue with your hinges or door. In order to check if you hinges are not damaged you may need to disassemble your microwave this is not a simple DIY job. I would highly recommend having a professional technician out to perform a proper diagnosis and repair. This will help you avoid personal injury, future problems, or unnecessary part purchases. I hope this information is helpful for you. -Matt
Apr 24, 2015 | Frigidaire Model PLMVZ169GC Microwave Oven
Fix sagging frigidaire microwave door
Hello Rick, thank you for your inquiry!
From my understanding you need to fix a door that is sagging on your Frigidaire microwave. Your door could be sagging due to the hinges or the door being damaged. I would check to make sure there is no visible damage. It is possible that the hinges and door may need to be replaced as well. To help avoid any unnecessary part purchases you may need to seek assistance from a professional technician for proper repairs. -Matt
Apr 01, 2015 | Frigidaire Microwave Ovens
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
FMV156DCA turns on, cook indicator lights but not cooking, timer counts down fine too
Hello epinvegas - Try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, then it sounds like the microwave has a faulty magnetron, wiring failure or control board. Contact a professional to assist with the repairs.
Feb 07, 2013 | Frigidaire FMV156DC Microwave Oven
Same - the counter counts down, but doesn't cook.
Yes your door isnt aligning right when closed and the lower interlock isnt being made when shut. Look and see if where the door pivots if it is broke or sagging down.
Sep 11, 2009 | Frigidaire FMV156EM Microwave Oven
Frigidaire door/power problem
Sounds like either the latch assembly or hinges too loose to activate the micro switch. TIP: Go to the web and type www.partselect.com enter your model number then scoll down to your part. Click to enlarge exploded diagram on left. Veiw enlarged diagram at top of page. You can print the entire diagram for exact assembly by holding your pointer in the upper left hand corner of diagram. Select the print icon. Now you have what you need. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 19, 2009 | Frigidaire FMV156DC Microwave Oven
Sagging microwave door
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If the door seal is damaged or out of alignment, there is a chance of leakage, which can cause burns, damage to the oven or even a fire hazard.
Feb 08, 2009 | Frigidaire FMV156DC Microwave Oven
Microwave Ovens Logo
155 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
