Question about Stanley Bostitch HP118K 23 Gauge Headless Pin Nailer Kit
Just purchased a bostitch air compressor and three air guns , i am having trouble with the sb 1850 , will not shoot nails and lack of power
First, check all the air connections to see if there is anything that prevents the air to flow (pieces of cadrboard, packking chips or seals that need to be broken)
Check also if there is any manual valve and also if the quick connects are not entirely plugged in.
Posted on Dec 31, 2010
My fn1664k does not shoot a 2 inch nail all the way into a 2x4
Check the pressure at the gun to make sure the hose is good. Make sure the gun is oiled. The compressed air forces a piston down to drive the nail. the inside of the cylinder may be corroded causing the piston not to move as fast as it should or with as much force. Most air guns are pretty easy to disassemble to inspect. You should be able to figure this out pretty quickly this way.
Oct 31, 2014 | Stanley Bostitch FN1664K 16 Gauge Finish...
How do i fix my nailer from jamming
Parts are piston driver replace the point has a problem replace driver AND important use the right nails i think the nails are the nails are not big enough 40% chance this is the problem but when you have shoot on a hard surface the point of the driver will get 2 nails at a time and control part 52 that its not dirty or kinked. and the transport is clean.
Oct 21, 2014 | Air Tools & Compressors
Bostitch SB-1850BN. I bought a bundle of nail guns over a year ago, today I go to use this gun for the first time and just get a very poor poof of air coming out, no nail. I've tried it with pressure in...
At the end where you attach the air hose is the nailer imprinted with the words "add oil"? If so; add a few drops of oil designed for air nailers.
Also check to make sure no nails are stuck in the tip of the nailer and the return mechanism is reset.
Oct 20, 2017 | Stanley Bostitch Sb-1850bn 18-gauge Brad...
What degree nails are used in stanley bostitch n60fn nail gun
I've repaired many nail guns and I can tell you the Stanley Bostitch N60FN uses 15 guage nails from 1 1/4" to 2 1/2" long in the FN1500 series of Bostitch nails. Nowhere does SB or any of their aftermarket dealers list what the angle of the nails is. I do know most of the SB nail guns that come through for repairs are because of damage to them from using other than SB series nails.
Oct 01, 2012 | Stanley Bostitch Nail Gun
Leaves about a 1/4" of nail from seating
This can happen for a number of reasons.
1) Insufficient air pressure (should be set to around 100PSI)
2) Hitting another nail or other extremely hard surface (old roofs are known for this)
3) Defect in the gun or lack of lubrication.
Since this is a reconditioned unit, I think that the gun is probably fine. Verify that the compressor has the correct pressure and that the hose is large enough in diameter to deliver sufficient air to the gun. Check the CFM (Cubic Feet per Minute) rating of the compressor/tank combo against the requirements of the gun.
Keep us posted,
Dan
Nov 21, 2010 | Stanley Factory Reconditioned Bostitch...
The driver on my Bostitch nail gun won't retract
This is usually caused by either a lack of lubrication or a defect in one of the seals. If hte nailgun has been uised a lot, purchase an O-Ring kit and replace all of the O-rings. That should resolve the problem. I believe that these kits are available for around $20-$30.
Dan
Apr 12, 2010 | Stanley Air Tools & Compressors
I have a SB-1850BN Bostitch finish nailer that no longer shoots nails. I think it may be a o-ring in the cylinder but not sure. Is there an easy fix for this situation?
Generally speaking an O-ring kit will resolve this type of problem. Check with your local lumber yards that sell Bostitch products. They may have a Bostich Day at which, for a purchase of nails or some other Bostitch product, the manufacturer will give up to 2 tools a quick overhaul including replacing the O-rings.
Dan
Jan 11, 2010 | Stanley Air Tools & Compressors
How do you safely remove jammed nail gun?
Not sure exactly what Bostitch framer model you have, but if it is powered by compressed air, as long as you remove the air hose from the nail gun, there should be no risk of the nail gun firing while you remove the jammed nail. There should be a way to access the driver area from the top of the nail gun, even via a latch or a couple screws. Remove the top part of the driver area and that should give you access to the jammed nail, which you can remove. Use long nose pliers or something similar if the nails are really stuck.
May 31, 2009 | Stanley Bostitch F21PL Nailer
Bostitch nail gun loss of pressure, won't fire nail
Hello. I can help you. The nail gun you have uses 18 gauge brads. I would use only original Bostitch 18 gauge.
The one MM of difference you mention is the reason why you do not have the pressure you did have. Get rid of those 31MM brads and get the 18 gauge. Home Depot carries the Bostitch line. I would go there or to homedepot.com
May 20, 2009 | Stanley Bostitch BT200K
Stanley Bostitch HP118K 23 Gauge Headless Pin Nailer Kit Logo
89 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
