Question about Siemens SF65
Missing resource
I have downloaded the latest driver for mobile phone manager. The above message came up when I tried to use the phone manager.. My computer runs on Vista. The download doesnot mention Vista only XP
Perihale blootooth driver
To resolve this issue, you will need to install the device driver for your Bluetooth device. If the device came with a CD or DVD containing device drivers compatible with your version of Windows, insert that disk into the disk drive and follow the instructions to install the driver.
If your Bluetooth device did not come with a driver installation disk, you will need to go to the device manufacturer's website and download and install the latest driver for your device. To do this, go to the hardware manufacturer and search on the latest version Bluetooth driver for your device. Follow the instructions.
Windows 7 Compatibility Center
Windows Mobile Devices
If youre using a Windows Mobile device, follow the steps below to updte to the latest version of Windows Mobile Device Center 6.1
  1. Go to the Microsoft Windows Mobile Device Center 6.1 site
  2. Click Continue.
  3. If prompted, download the Windows Genuine Advantage software.
  4. Click Download, then click Run.
  5. Follow the onscreen instructions to install Microsoft Windows Mobile Device Center 6.1.
  6. Click the Start button, type device manager in the Search box, then click Device Manager.
  7. Expand Unknown Device, right click on Bluetooth Peripheral Device, then click Update driver software.
  8. Click Browse my computer for driver software, then click Let me pick from a list of device drivers on my computer.
  9. Select Bluetooth radio from the list. Under Company name choose Microsoft Corporation, then under Drivers, choose the latest version of Windows Mobile-Based Device Support.
  10. Click Next. If any warnings should appear, click Ignore, then when prompted, click Finish.
  11. Restart your computer.
Nov 09, 2013 | Lenovo Computers & Internet
My device manager always show missing drivers ethernet controller and base system device,i can not reach it
Hi!
To fix this, you have to download and install the Chipset and Ethernet Drivers, which can be downloaded from the following link from HP Official Support: -
Compaq nc8000 Drivers
Visit the above link. Click the Network Drivers link and download the drivers for ethernet (LAN) according to the LAN you have on your laptop. (you may try other Broadcom or Intel LAN Drivers)
Also, from Operating System enhancement section you can get the chipset drivers
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
May 31, 2011 | HP Compaq Business nc8000 Notebook
Philips go gear sa3245/97 not starting
You can download content to a Philips GoGear multimedia player using Windows Media Player or MusicMatch Jukebox in Windows. Earlier versions of Windows starting with 2000/ME and XP are compatible with GoGear. If the device is not recognized by the Windows XP operating system or is receiving error messages, you may have older versions of the necessary software installed. There also may be firmware issues with the GoGear device.
Instructions
Connect the Philips GoGear to another USB port on the computer. Sometimes USB ports go out, especially those in the front of the computer case. Try inserting the GoGear into another port and see if XP can now recognize the device.
Download Service Pack 1 or later for the XP operating system (see Resources). Philips GoGear can only operate on XP systems with at least Service Pack 1 installed. You may also receive an error message pertaining to the service pack when trying to insert the installation disc for the GoGear support software.
Install the latest version of Windows Media Player. Philips GoGear requires at least Windows Media Player 11. Windows Media Player 11 is available for XP .
Install the latest version of MusicMatch Jukebox (see Resources). Earlier version of this software may be causing error messages regarding missing MP3 tag information and missing tracks. Follow the download prompts, then unzip the folder and click on the "HDD_xxx.exe" installation file. The latest version of the software will be installed.
Install the latest firmware on the Philips GoGear. The actual firmware required depends on your GoGear model. Open either Philips Device Manager or Songbird, depending upon which management software you are currently using. Close all programs on the computer except for the Device Manager/Songbird. Connect the GoGear to the power supply and the computer. Click the "Repair" tab in the Device Manager and click "Repair," or click "Tools" in Songbird and select "Check for updated firmware," and the firmware will be updated on the GoGear.
Mar 31, 2011 | Philips Audio Players & Recorders
Internet connection
I think you need to install latest PC suite for your mobile. Try downloading latest PC suite from samsung site.
Jul 07, 2009 | Samsung SGH-J600 Cellular Phone
Dell inspiron 1545 laptop and the same webcam problem.
open your my computer, click on "c" the system will tell you the information is hidden, click on the link and open up the operating system and look in the drivers or there in C and se if you can find you web cam driver, when you find it you might have to force the opening of the driver to install, and once you do that plug your web cam in and see if the system see's it and installs the drivers for the cam, if you installed the driver origanally witht he web cam installed you will have to remove the web cam and unistall the driver and re install it and then plug the web cam back in, and that should help correct the problem.
Jun 22, 2009 | Dell Inspiron 1545 Notebook
Intel pro nic no i/o resources
Its simple try this card on some other if u get the same error replace the card
Feb 05, 2009 | Compaq Armada M700 Notebook
HOW DO I RESET MY PHONE
Hi Rob,
Reset, you mean firmware reinstall. Download the latest firmware drivers from Blackberry.com and then install those drivers via the Desktop Manager on your PC.
I hope this helps,
Thanks.
Jan 30, 2009 | T-Mobile BlackBerry 7105t Cellular Phone
Nokia n72 pc suite problem
my nokiaN72 pcsuit does not work properly & display an error of pcsuit file in mobile is missing.
Oct 31, 2008 | Nokia N72 Cellular Phone
Mobile drivers
Try the software Mobiola Webcam lite for Nokia 6233. It works via bluetooth. It can connect your Nokia 6233 to your PC as a webcam. Search for it Now...
Nov 28, 2007 | Nokia 6233 Cellular Phone
Cell Phones Logo
135 people viewed this question
Top Siemens Cell Phones Experts
Computer Repairing
Computer Repairing
michael galang
Colin Stickland
Colin Stickland
Are you a Siemens Cell Phone Expert? Answer questions, earn points and help others
