Question about Maytag Bravos MTW6600T Top Load Washer
How do I take the top/lid off a Maytag Bravos Washer?
  • 3 Answers
SOURCE: F51 & SD Codes --
I have a question for tech17....
the part #W10130544 is around $199.00. Am I correct? Is this the entire control board or a new RPS Sensor? I checked prices on just the sensor at around $34.00. I also got a quote from a local Appliance Parts shop for what i thought was the same part, a Whirlpool part for around $78 bucks. What is the correct repair? I have attempted the reseat and clean atleast 3 times and still cannot get this code to clear!?!?! Also, how can I get into diag mode on this console? I am assuming the power needs to be on!?!? How can I clear the stored fault codes? Any help would be greatly appreciated! I love this machine but for a few dollars more I can go back to the old style controlled machine and be done with this electronic BS! Like I said any help would be greatly appreciated! Thanks for the previous posts!
Posted on Mar 30, 2008
  • 130 Answers
SOURCE: Maytag washer MAV551EEWW top load with loose tub
If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly  and the outer shell with the tub bearing.
Sometimes the inner basket support will crack, this can give an clicking or banging noise as well.
Pictures of this job...
A sure indication was the brown junk/gookus leaking out if the rear bearing area and the belt has spewed it around in the drum that the rear bearing and seal was bad...
Picture1 - Picture2
The whole outer shell and basket come out to do this repair....what bad bearing and rusted shaft looked like...
Picture1 - Picture2 - Picture3
I had to remove the back panel. Undo the pump hose & water level hose, remove the 2 shocks, remove the motor, undo the front boot from the outer panel and remove the 2 springs to lift the whole assembly out from the back to work on it.
Picture1 ( boot pushed inside ) Help page1 - Help page2
Posted on May 07, 2009
  • 37 Answers
SOURCE: Maytag Washer lid switch
Ohm out the blue/ blk terminals on the sw (remove wire harnes first and notate wire color connection) with an ohmmeter-- Reading should be zero (closed lid position)
Then ohm the ylw and white sw terminals-- reading should be 0 as well.
If I am not mistaken this sw has a plunger that sticks out, if hte unit goes off balance this could push the plunger in. to reset- pull the plunger out
Lou
AFFORDABLE APPLIANCE REPAIR
(949) 855-0788
Posted on Jun 20, 2009
SOURCE: maytag Bravos top load gives LF code..not working
Have same problem. Service tech said LF code is caused by low water pressure coming into machine. Tech verified water flow looked fine, getting new controller installed tomorrow.
Posted on Sep 23, 2009
  • 3 Answers
SOURCE: maytag bravos top load washer error code F1
Well, you're not gonna like this, but here's the deal.
Remove the three screws on the rear of the control panel and lift it up. Disconnect the rubber hose on the right side of the gray control module and blow through it to make sure it is clear and not kinked. If this check is fine then your control module needs replaced.
Note that Maytag knows this is a fairly common problem. My washer failed 9 months out of warranty with this problem.
The only good news is that it is an easy, though expensive, replacement.
Posted on Sep 25, 2009
How to run diagnostic
Maytag Bravos MTW6600T Top Load Washer Run ... - Fixya
www.fixya.com > ... > Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test cycle related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test ccu related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer Diagnostic ...
Dec 02, 2015 | Maytag Bravos MTW6600T Top Load Washer
Lid lock broken can I overide?
Washer not starting Cycle:
I would have to slam the washer lid before the washer recognized the lid was shut.
What I did to fix:
1. Ref the link below for Schematics
http://blog.kennyluong.com/Tricking-A-Maytag-Bravos-Washer/
2. Looking at the Lid Lock section of the Schematic:
Place a jumper between pins 2 and 3 of J15
This engages the 1st switch (Lid Lock) so, I don't have to slam the lid anymore
3. Since my Lock switch (2nd switch), which is engaged with a magnetic, is working, my work is done.
If you find that your machine is still not starting the cycle, you will need to
replace the Lid Lock mechanism or ref the above link for temp bypass.
Mar 30, 2014 | Maytag Bravos Top Load Washer
Maytag bravos x lid lock overide or bypass
dpthom's wife is the smartest woman on earth! :)
Feb 11, 2013 | Maytag Bravos Top Load Washer
Maytag bravos mvwx500xw0 has no power after closing lid
You should hear a click just before the lid closes and a click just after it opens. If no click, check lid switch and it's actuator.
Jan 12, 2013 | Maytag MVWX500XL High-Efficiency Bravos X...
My maytag bravos washer is flashing DL, what does this mean, its not spinning!
The "dL" error code appears when an item inside the washer prevents the lid from locking properly. Open the washer and readjust any items that may be hitting the lid. The error code should go away once you properly close the lid
May 03, 2012 | Maytag Bravos 3.8 Cu. Ft. Washer
The plastic lid lock from my bravos washer broke off any thing i can do to fix it so i can wash cloths?
You may be able to use super glue to reattach the pin that broke off otherwise go to a parts dealer and purchase a new lid pin.
Jul 31, 2011 | Maytag Bravos MTW6600T Top Load Washer
My Maytag Bravos pumps, drains but wont spin.
Hello & Welcome to FixYa
When the washer fills but does not agitate or spin then you can check if the lid switch is fine. You can jump start the lid switch by connecting both the wires with each other or use the third wire to act as jumper between the two. After this if the problem is solved then replacing lid switch is recommended repair. Please get back to me if you have any other questions.
Kevin
Jul 22, 2011 | Maytag Bravos MVWB700V Top Load Washer
My maytag glass lid shattered and I need to find A replacement and how to install
Unplug the machine. Pop the top using a putty knife to release spring clips between the top and front panel. Remove the hinge screws with phillips head screwdriver, pull the hinge straight out as seen on page 49 of this Maytag Bravos Service Manual
Jun 27, 2010 | Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer Logo
453 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
