Question about Magic Chef Microwave Ovens
Magtag MVP V, Model CMV1000ADB (Magic Chef?) Over-the-range type...problem...plastic door handle loose (not broken or cracked, just wobbly), do you have a solution for this. Or can you tell me where I can get manual? Microwave came with house but no instructions. Thank you
fridgetech
  • 473 Answers
SOURCE: Magic Chef 1.0 cu. ft. Convection Microwave Oven
There are several things that could cause a microwave not to heat. Most common is the magnatron and some models have up to a 5 yr warranty on that part. Check the owners manual for that info.
Posted on Oct 05, 2007
  • 958 Answers
SOURCE: microwave
im not sure what a magic chef bulb is but you can check by opening the casing, the bulb is normally mounted on a fiber board and screwed on the metal part of the microwave,remove the two wires attached to it first, after unscrewing the screw, you can pull out the bulb holder and you can see if it is a replaceable bulb if it has a socket. you can use the old bulb holder , just replace the bulb. in some design, the bulb is mounted directly to the bulb holder, you have to buy the bulb mounted directly to a new bulb holder and use them all as an assembly. be sure to screw them back tight. tnx. i hope i was able to help.
Posted on Feb 11, 2008
SOURCE: Magic Chef Microwave
problem solved
Posted on Jul 07, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: How to replace MVP V CMV1000 Door Handle?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Nov 08, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Magic Chef Microwave Model MCO160S .
You can download that manual here.
Posted on Nov 27, 2008
MVP V door handle broken
Maytag mvp v microwave door handle parts Questions ...
www.fixya.com > Forum > Tags > mvp v microwave door handle parts
Maytag mvp v microwave door handle parts related problems. Ask your Maytag mvp v... The handle on my maytag microwave oven broke off ... door handle ...
Maytag Microwave Handle Parts from RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Maytag-Microwave-Handle-Par...
Shop for your Maytag Microwave Handle from our huge inventory. Return any part for any ... Repair Help for Microwaves .... Microwave Oven Door Handle.
CMV1000ADW Maytag Microwave Parts and Repair Help
www.partselect.com/Models/CMV1000ADW/
Dec 22, 2015 | Microwave Ovens
Trying to remove a microwave magic chef mvp iii -- about 20 years old
Try Magic Chef customer service here.
Oct 16, 2011 | Magic Chef CMV1000B Microwave Oven
No heat on magic chef microwave
Check the door safety interlock switches.
Dec 29, 2009 | Magic Chef MCD1311ST Microwave Oven
Sear's microwave falling apart
If this is and Over the Range micro, the exhaust fan needs to run ANYTIME the cooktop is on. They make things for quantity and not quality, so the plastic has little tolerance for heat. Running the fan, diminishes heat off the front of the unit. Also, the micro MUST be at leat 24" off the cooktop.
Mar 07, 2009 | Kenmore 62622 Microwave Oven
Magic Chef door handle needs replacing. Where can I find a replacement?
You can order Magic Chef / Ewave parts here.
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Mar 01, 2009 | Magic Chef CMV1000B Microwave Oven
MVP Iv vm12ab-1 microwave
I have an MVP III Magic Chef microwave for the past twenty years. Every Function on the smartboard works except for the start button. We've been told that the smartboards for this model have been discontinued. I recently tried to find the part online and my search was not successful. Any ideas on how to proceed to get my microwave up and running again...
Jan 19, 2009 | Maytag MMV5186A Microwave Oven
My magic chef over the range microwave oven handle is broken, i ordered the part online and have received the same. However I do no know how to remove the old broken handle and replace it with the new...
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Aug 01, 2008 | Magic Chef Microwave Ovens
MVP IV Microwave Model VM12AM-1
There are a series of switches in the door latch mechanism which are a safety interlock system. If the latch on the door is secure and not broken then it is in the latch mechanism itself. It is possible for the mechanism to come loose and stop the oven from working. The control panel will have to be removed and the mechanism adjusted for proper operation.
Alternately if the door hinges (screw in type) are not aligned properly then it can cause the same symptoms.
I am unable to locate your model in my reference, but there is usually one or two screws behind the grille that hold the control panel on if it is a vent hood style. If it is a cabinet style then the cabinet will have to be opened. Be sure to disconnect power at lease 1/2 hour before opening.
Jul 28, 2008 | Magic Chef Microwave Ovens
Microwave Ovens Logo
128 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
