Question about Garmin nuvi 255W GPS Receiver
Screen seems OK but there is no way to interface as it does not respond to touch. Unit is 255w and about 2 years old.
  • 321 Answers
The solution to this problem is for you to calibrate the screen. Before calibrating the screen, i will advice you reset the gps. To reset your device, hold down the power button for about 15 seconds, it will restart itself and power up fully, if the touch screen does not still work, then calibrating the screen will do the job for you. To calibrate the screen, follow the steps below:
  1. Turn off your nuvi,
  2. Hold the upper left corner of the screen, then turn on the nuvi,
  3. Release the power key once the garmin screen appears,
  4. Continue to hold the upper left corner of the screen for 30 seconds till a white screen with 'touch dots' appears,
  5. Then follow the rest of the guide from there.
It might take a few tries before it works for you but you have to keep trying till you get it right. I am very certain that this will work for you.
Posted on Dec 31, 2010
Why garmin 255w wont come on when plugged up
because it is old and dead.... no seriously, your cell phone doesn't last 6 years, why do you expect this to?
if it does not respond to a power button, powered into a car or plugged into a computer, the unit is toast.
Jul 16, 2014 | Garmin nuvi 255W GPS Receiver
Touchscreen not responding
If the touch screen of your phone is not responding to touch then it means you have to calibrate the screen to get it working once again.
To calibrate your screen, be sure that the nuvi is properly charged, then you follow the steps below:
  2. Press your finger on the upper left corner of the touch screen,
  3. While holding your finger on the touch screen, turn on the nuvi.
  4. Continue to hold your finger on the screen for about 30 seconds until the calibration screen appears(white screen with touch dot),
  5. Then follow the on screen instructions.
That should do the job for you. hope this helps.
Jan 10, 2011 | Garmin nuvi 255W GPS Receiver
My gps Garmin nuvi 255W touch screen is broke, how can i fix it??? is it expensive ???
My GPS Garmin Nuvi 255 touch screen is not responding. How can I fix it?
Sep 27, 2010 | Garmin nuvi 255W GPS Receiver
Unit does not respond to touch; won't change menus when touched
1) your screen may be faulty and require repair/replacement
2) Slowness is related to battery condition
Please rate my help++++Thanks for using FIXYA
Jun 01, 2010 | Garmin nuvi 255W GPS Receiver
Can't get past the WARNING/Agree screen
Try re-setting it. 1 -hold thumb is lower right corner - turn on unit - keep pressure on - as shown in pic 2-push YES 9124cfe.jpg
May 03, 2010 | Garmin nuvi 255W GPS Receiver
How do I change the country on my Garmin nuvi 255W?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Stuff happens. Try this:
This may be a result of a previous software version on a device or possibly some one changing the settings. If a device does power on with a foreign language that you can not understand it can be corrected by going through the settings to change the text language.
To change the text language:
  1. Touch Wrench icon on the screen with the Magnifying Glass and Map icon
  2. Touch the Gears icon
  3. Touch the down arrow
  4. Touch the second option from the top1
  5. Touch the middle blue box on right
  6. Touch the up arrow until American English appears2
  7. Touch American English
  8. Touch OK
  9. Touch Back
The device should be in selected text language.
Note 1 - In some cases, if there are Custom POIs loaded to the device then it may be the first option at the top.
Note 2 - If American English is not the language needed, please selected the desired language
Jan 29, 2010 | Garmin nuvi 255W GPS Receiver
My screen does not respond to my touch
You need to Calibrate the touch screen.1Turn off the Nuvi. 2 Turn on the Nuvi and hold the Power key to the left for about 30 seconds untill the calibration screen appears (white screen with "Press dot")
Nov 08, 2009 | Garmin nuvi 255W GPS Receiver
My Garmin nuvi 255W will not go off of the garmin screen....any suggestions
You can try plugging it into a computer via usb cable and see if that snaps it out of it other wise try doing a hard reset, you will loose all data but its the only option you seem to have. Hold the bottom right corner of the touch screen and power the unit on. wait until you see the confirm delete and select yes.
Aug 14, 2009 | Garmin nuvi 255W GPS Receiver
Touch screen does not respond
Step 1. Turn your Nuvi unit off, remove any SD cards from the SD card slot and make sure that the unit is not plugged into any computer.
Step 2. Place a fingertip on the upper left hand corner of the touch screen and keep it there while turning the unit on, a prompt should read " Do you really want to start in maintenance mode?"
Step 3. Select the yes button.
Step 4. Enter your PIN if enabled.
Step 5. Main Maintenance Mode screen should have 4 selections:
System information
View Diagnostics
Clear User data
Clear Waypoints
Step 6. After some selections the unit should reboot and you check to verify unit after rebooting.
Feb 25, 2009 | Garmin Nuvi 300T GPS Receiver
Garmin nuvi 255W GPS Receiver Logo
697 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
