Question about Danze Home
Single lever bath faucet won't shut off - Danze Home
frcs68
  • 1605 Answers
SOURCE: shower head leaks water when water is turned on
take out the cartridge from the fixture and make sure it has all of the "O" rings and stoppers.
look at the instruction again, make sue you are installing it the right side up. if all that, the shower still leak, then you need to talk to the place you brought the fixture, it may have a defective cartridge.
Posted on Jan 13, 2009
lester482529
  • 226 Answers
SOURCE: water leaks from shower head while bath faucet is running
sometimes there are orings or gaskets that get tore in assembly one of those may be bad,or if it is around the threds you might try wraping teflon tape around the thred once or twice.hope this helps
Posted on Jun 14, 2009
mrhotandcold
  • 248 Answers
SOURCE: 1 handle pull and turn bath room faucet no hot
a common fault if the handle is forced the spindles get worn best to replace
Posted on Sep 18, 2009
  • 129 Answers
SOURCE: HOW TO DISMENTLE OR REPLACE A MOEN SINGLE LEVER
shut water off at stops under sink. Unscrew water supply lines from directly below handles. Above them you will find plastic nuts, remove them. Disconnect pop/up lever and you should be able to lift faucet from sink.
Posted on Sep 27, 2009
  • 115 Answers
SOURCE: low hot water pressure in kitchen faucet
this is fun, you probably have some rust or lime build up in faucet, most of these single handles you have to remove handle setscrew usually small allen wrench. shut off water supply first!!! next the barrel should be held on by a screw remove and lift barrel out you should now be able to see build up clean and reassemble if you are not confident with this call a plumber good luck
Posted on Oct 14, 2009
Single handle shower/bath faucet is dripping. Want
I can fix this.
What is the last thing you did before this problem started?
Jan 13, 2011 | Delta Faucet Delta 172-SSWF Waterfall...
Leaky single lever bath tub faucet
Faucet is leaking due to seats bad.
1- Turn water off first and remove handle and remove collar that holds stem and remove it..
2- in valve there are seats that looks like caps they may be in valve body or the end of stem itself.
3- Remove them and the springs and replace them this will take care of the leaking problem.
May 21, 2010 | Delta & Single Handle Shower Faucet
How do you switch out the single lever dial on a delta shower fau
Hidden under the lever is a little hex screw. Use an appropriate hex a.k.a. "Allen" wrench to remove the handle. You might want to shut down the water service first to save your shower until later.
Mar 16, 2010 | Delta & Single Handle Shower Faucet
Replaced single handle shower faucet with rite
u hve to adjust the temprture ring i think u put it all the way so u lock it ,
Dec 25, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
No hot water pressure on kohler bath / shower faucet
Try draining the system and apply air pressure (min 30psi) to each faucet. Open other hot water faucets to allow pressure to vent. Next try draining and cleaning the hot water tank.
Oct 07, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Moen - Single lever bath tub faucet - cold water only
moen does not have a ball and washers....sounds like a Delta maybe. Moen uses cartridges. Either way sounds like a balancing spool problem....but you will need to make sure of the right name for the faucet to get the parts.
Aug 17, 2009 | Plumbing
Home Logo
48 people viewed this question
Top Danze Home Experts
Mike
Rabbit Brains
Rabbit Brains
Mike Herrington
Mike Herrington
Level 1 Expert
Are you a Danze Home Expert? Answer questions, earn points and help others
