Question about Singer Sewing Machines
Needle thread fails to pick up bobbin thread - Singer Sewing Machines
  • gwyneth604 Jan 05, 2011
    i decided thqt if something needs to be replaced a repair shop shlould do it.
  • 2,382 Answers
Hi, not catching the thread, my fears, broken gear, hope not. Lets try a new needle, perhaps when pulling the thread and fabric out of the machine, and I'm guessing, you may have pulled it towards you. This can bend the needle forward, and it wills start dropping stitches.
If a new needle doesn't work, double check the threading of the top tension. Pretty sure that is ok, but just a precaution. If nothing still, remove the bobbin, and thread from the machine. With the slide plate open, turn the machine towards you, and watch where the bobbin goes in. You should see the hook spin around in a counter clockwise motion. If not, then I'd say it is the top gear that went bad. If you need a gear, obtain it locally, with the repair guide that shows how to install, retime the machine, and have you up and running again. Might be the bottom timing belt as well, but doubtful.
Posted on Dec 31, 2010
Please share the symptoms of a messed up timing on a Singer Confidence sewing machine. Thank you in advance
A timing issue is usually demonstrated by the needle thread failing to pick up the bobbin thread. First, try installing a brand new needle as a bent/damaged needle will sometimes also fail to pick up the bobbin thread. You can search the internet for sewing machine timing or take it for service.
Dec 07, 2016 | Singer Sewing Machines
Embroidery machine bobbin not picking up thread
If you thread is coming out all tangled continue.
I Had this problem and found I had missed one leg of the threading.
I had an experienced seamstress look at our portable and could not get bobbin working. I took thread and redid it ,seems I had missed leg that went down.
she did to now all is well.
Sep 21, 2016 | Sewing Machines
Wont pickup bobbin thread when sewing.
Make sure you are using a brand new needle. Bent/damaged/dull needles frequently will fail to pick up the thread.
If it continues to skip stitches, it most likely has a needle/hook timing issue--the needle arrives at the bobbin at the wrong time to intercept the bobbin thread.
There are web sites and videos available that discuss sewing machine timing, or you can take it for service.
Sep 10, 2016 | Sewing Machines
My 532 wont pick up cotton from bobbin
First, install a brand new needle. Used/worn/bent needles will sometimes fail to pick up the bobbin thread.
Make sure the bobbin is installed correctly in the bobbin case.
If it still will not pick up the bobbin thread, most likely the machine is out of time (the needle arrives at the incorrect time to intercept the bobbin thread). Take it for service or search the internet for web sites or videos dealing with sewing machine timing.
Sep 03, 2016 | Sewing Machines
When thread cotton. Cotton don't pick up bobbin cotton please help bernette65
Be sure to use a brand new needle. A bent/damaged needle may have difficulty picking up the bobbin thread.
Verify that both upper and bobbin threads are threaded correctly. If so, and it still fails to pick up the bobbin thread, most likely there is needle/hook timing issue. Take it for service.
Aug 19, 2016 | Sewing Machines
I can't get my needle to grab my bobbin thread
Always--install a brand new needle. A bent/dull/damaged needle may not pick up the bobbin thread.
Remove the thread from the machine. Always Raise The Presser Foot and rethread from the beginning. Make sure the thread seats completely in the tension disk and the thread path is correct.
Test your machine. If it still fails to pick up the bobbin thread, then your machine may have a timing issue (the needle is arriving at the bobbin at the wrong time in order to intercept with the bobbin thread).
There are many web sites and videos explaining sewing machine timing. Or, you can take it for service.
Jul 17, 2016 | Sewing Machines
Why doesn't the needle pick up the bobbin thread ?
Try installing a brand new needle. Make sure it is pushed all the way up and that it is facing the correct direction. Check that the bobbin is loaded and threaded correctly.
If the machine still fails to pick up the bobbin thread, then it most likely has a needle/hook timing issue. Take it for service.
May 17, 2016 | Sewing Machines
Needle will not pick up bobbin thread (Bernina 830) despite tightening handwheel therefore no stitching. Have cleaned bobbin mechanism and have checked and rechecked bobbin threading. Have tightened
Make sure needle is inserted with the scarf(small indentation above needle eye) to the back and fully inserted. Otherwise it could be out of time which would require a technician.
Jul 10, 2012 | Bernina Sewing Machines
Needle thread will not pick up bobbin thread on
Change the needle first and make sure it is in the correct way round, failing that you may need to retime the machine, if you email me I can attach instructions drivewithken@blueyonder.co.uk
Jun 28, 2010 | Janome Mini Compact
Sewing Machines Logo
137 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
