Question about Canon I990 InkJet Photo Printer
The ink from from s820 what other printer can i use that ink"""
  • Canon Master
  • 7,733 Answers
S820 Printer Model Brand is?
Posted on Jan 01, 2011
Waste ink absorber is almost full
The waste-ink counter for the BJ F900, F890, F700, F500, S900, S820, S750 and S520 are all reset in the same manner.
Turn off the printer.
Press and hold the RESUME button, then press and hold the POWER button.
Release the RESUME button, then press and release the RESUME button two more times in succession. (youre still holding the POWER button during this). The printer mechanics will move momentarily.
You are now in Service mode.
Pressing the RESUME key will select a function; for example, pressing RESUME 4 times will select the clear waste ink counter function. The lamp will alternate color with each key press.
1. service/factory test printout, including ink sensor check
2. EEPROM info printout
3. EEPROM initialization
4. Clear the waste-ink counter
5. Printer model setting. (more selections beyond this- leave this alone)
After selecting mode, press the POWER button to commit the change, and return to the top of the function selection menu. Pressing the POWER button again turns off the printer for a restart.
If you have a defective printer head, your power lamp may flash during the service mode key-in, and info printouts may not work. In this case, clearing the waste-ink counter may not fix your problem.
Feb 13, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Tip
Ink System Failure Fix for Some HP Printers
<span><span>Hewlett Packard Ink System Failure Error Fix (tested C6180) </span></span> <ol> <li><span><span>Press and hold the "*" key. </span></span></li> <li><span><span>Press the "#" key and release both keys. Display should say "Enter Special Key Combo" </span></span></li> <li><span><span>Press and release in sequence the "1", "2" and "3" buttons. screen says "support" R0631M </span></span></li> <li><span><span>Press and release the right arrow button until the display says "System Configuration Menu". </span></span></li> <li><span><span>Press and release the "OK" button.</span></span></li> <li><span><span>Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status", </span></span></li> <li><span><span>Press and release the "OK" button. </span></span></li> <li><span><span>Display should say "Hardware failure status: Clear. Press OK to clear". </span></span></li> <li><span><span>Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". </span></span></li> <li><span><span>Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. </span></span></li> <li><span><span>Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.</span></span></li> <li><span><span>Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer </span></span></li> <li><span><span>Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. </span></span></li></ol><span><span>I hope this helps</span></span> <span><span><br /></span></span> <span><span>Regards GM</span></span>
on Jul 15, 2011 | Office Equipment & Supplies
Tip
How to reset Canon S820 printer ?
  1. Turn off the printer.
  2. Press and hold the RESUME button, then press and hold the POWER button.
  3. While still holding the POWER button, Release the RESUME button, then press and release the RESUME button two more times in succession.
  4. The printer mechanics will move momentarily. You are now in Service mode. Release the Power Button.
  5. Pressing the RESUME key will select a function; for example, pressing RESUME 4 times will select the clear waste ink counter function. The lamp will alternate color with each key press.
    1. Service/factory test printout, including ink sensor check
  6. After selecting mode, press the POWER button to commit the change, and return to the top of the function selection menu. Pressing the POWER button again turns off the printer for a restart.
on Mar 10, 2010 | Office Equipment & Supplies
Ink out reported as Communication Error.
Try reseating all cartridges, and power cycling the printer...
May 07, 2009 | Epson Stylus D88 InkJet Photo Printer
Canon S530D "Used ink tank is full" how do I remove the printer from the case to get at and clean the used ink tank? I need disassembly instructions.
The following may help, although the 530 is not mentioned
This resets, but not sure about cleaning the tank
Canon Printers S520, S750, S820, S900 and any S Series Reset Procedures
May 05, 2009 | Canon Office Equipment & Supplies
How do you clean the ink jets on a cannon S820?
Best way I know of cleaning blocked heads is to run them through a cycle in an ultrasonic bath filled with warm water. Failing that then you will need to replace them.
Dec 03, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon model # S750 has stopped printing. The orange lite flashes 8 times indicating that the waste ink tank needs to be replaced. Is this something that I can do? If not, where do I go from here?
Your waste ink tank is full. the following will get you going again, but the sponges should also be cleaned or replaced, although I have not heard of any one having problems without doing this.
Canon S900, S820, S750, S520
Jul 02, 2008 | Office Equipment & Supplies
Now got a reset problem...
Hi ok
Mar 10, 2008 | Canon S900 InkJet Printer
Canon F-80
I just fixed mine but I did 3 different things but my inks were empty...now that I replace the inks it works but not sure which one of the 3 fixed it so here they are
For Printer Model: Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
For printer model: Canon BJ F900, F890, F700, F500, S900, S820, S750 and S52:
3. Release the RESUME button, then press and release the RESUME button two more times in succession. (you?re still holding the POWER button during this). The printer mechanics will move momentarily.
4. You are now in Service mode.
1 times - Factory/Service test printout, including ink sensor check
2 times - EEPROM info printout
3 times - EEPROM initialization
4 times - Clear the waste-ink counter
5 times - Printer model setting. (more selections beyond this- leave this alone)
Nov 27, 2007 | Canon MultiPASS F80 All-In-One InkJet...
Canon I990 InkJet Photo Printer Logo
old marine
old marine
