Question about A.O. Smith SQ1102 Pool Pump Motor
Have a.o. smith SQ1152. Need config for 240 volt
    President:
  • A.O. Smith Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Depending on the age of the motor you should have a 'quick change' switch of some type you simply rearrange for the 240V setting. If not I assume you have an old motor with a brown and white wire from inside the stator positioned on posts L1 and B if memory serves correctly. White will be on the L post and Brown on one of the two lettered posts. Move brown to the other lettered post and put white where brown was if you have these leads.
If you do have a plug or rotary switch, reposition it for 240VAC and your done. In any of these settings you still leave your two incoming line leads, one each, on L1 and L2.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Posted on Dec 31, 2010
Need to change a goulds 1.5hp motor from 120 to 240 volts
should have info on side of motor, some motors cant be switched
Mar 19, 2013 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
How to remove impeller
i think they screw on and the screw only locks it in place
Mar 22, 2012 | AO Smith SQ1152 Pool Pump Motor
Power Plug Adapter - Converter - 110V - max. 1550W US/Japanese to Australia
You need a stepdown transformer from 240 volts to 110 volts AC.
Make sure you get one that has the required wattage you require.
Jaycar has a 1000W 240 - 115V Cat. No. MF-1086 for $360.00
**** Smith has a 1000W 240 - 115V Cat. No M1154 for $246.00
If you require a higher wattage, try an electrical wholesaler.
Jan 14, 2012 | Video Game Consoles & Games
Need wiring diagram for AO Smith Motor. Model # K48K2PA105. Label gone. Not sure if its ready for 120 or 240. Any help appreciated
Remove the rear cover and take a look. Unless this is a very old motor, there will be an indicator on the tab that will tell you the information you seek.
Normally ... let me say again, normally, a larger motor will come default 220 while a fractional hp motor will be 110.
To be double sure, take your motor to your Professional Pool shop and ask them to have a look.
Jul 29, 2011 | AO Smith SQ1152 Pool Pump Motor
Pump runs for about 15 secs then cuts off.
try testing the starting capacitor by first disconnecting the power, opening the cover on the end of the motor, and test the resistance of the capacitor
Jan 24, 2010 | AO Smith SQ1152 Pool Pump Motor
A.O. Smith SQ1102 Pool Pump Motor Logo
55 people viewed this question
Top A.O. Smith Plumbing Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Gil Shultz
Are you an A.O. Smith Plumbing Expert? Answer questions, earn points and help others
