Question about Antec SL300S 300W Power Supply (045176) 300-Watt Power Supply
Diesel engine power supply
The fan on the power supply was making a loud noise like a diesel engine taking off...well now my computer won't start at all. I'm assuming it is the power supply that has finally broke. Do I have to put the same Antec SL300S power supply in? I've never changed it out before...are they all standard with the same cables? What do you recommend?
  • 2,794 Answers
There are power supplies that will work with your machine made by other companies. The wattage is whats important.
Posted on Jul 08, 2008
Mk3 mondeo engine loud ticking like grinding all the time.just had problem with injectors.had all 4 replaced.the garage says piston slap
Is this a new noise your hearing? If your mechanic has correctly diagnosed the noise find more info here:
http://www.autos.ca/auto-tech/auto-tech-noisy-engine-it-might-be-piston-slap/
The distinctive noise of a diesel engine is variably called diesel clatter, diesel nailing, or diesel knock. Diesel clatter is caused largely by the diesel combustion process; the sudden ignition of the diesel fuel when injected into the combustion chamber causes a pressure wave. Engine designers can reduce diesel clatter through: indirect injection; pilot or pre-injection; injection timing; injection rate; compression ratio; turbo boost; and exhaust gas recirculation (EGR).
Find more information more here: Diesel engine Wikipedia the free encyclopedia http://www.autos.ca/auto-tech/auto-tech-noisy-engine-it-might-be-piston-slap
Aug 30, 2017 | Cars & Trucks
Why is my 2002 Mazda Tribute making a loud knocking noise when I start it
loud knock and for how long
is it a diesel or petrol
broken engine mount
loud tapping is tappets ..should go away once oil reaches top of motor
water pump or bearing something running off drive belts
if high milage engine
a loud knock at engine revolution or half revolution
big end bearings or
piston slap or gudgeon wear
Oct 07, 2016 | Mazda Cars & Trucks
Engine making loud sound when attempting to start.
Diesel or Petrol?
Any warning lights on on the dash?
Oil pump working ok?
Check your timing belt?
Dec 04, 2012 | Cars & Trucks
Diesel fuel in a gas eos
You have ruined the exhaust converters with the diesel fuel
Its that dealer next to usless?
Nov 29, 2012 | 2007 Volkswagen EOS Convertible
I have a Volvo s60 52 2.4 diesel won't start when
hard starting in cold weather for a diesel is a sign of problem injectors or battery not full charged
take it to a specialist diesel shop for a diagnosis of the problem
Feb 10, 2018 | 2002 Volvo S60
MY Perkins generator 2300 series crank but can not start
I take it it's diesel. Have you renewed filters? Bleed fuel system Make sure there is plenty of diesel flowing out of tank (pipe not blocked) Check lift pump working
Oct 22, 2009 | Electrical Supplies
ThenI start my engine it sounds like diesel and no power
how is the oil level and pressure?, how many miles on engine? is this a loud knock or rather a clatter/ticking noise? knock is engine rod or crankshaft bearings, clatter loud ticking is valve follower noise. how long before it (the noise) goes away?
Jan 20, 2009 | 2001 Audi A4
Loss of power,f350,6.0 diesel
you might have a misfire caused by a bd injector there is many auto repairs than have a snap on brand scan tool and it will diagnose that problem also make sure to take it to the dealer and ask to have the water separator for the diesel serviced or drained, i hope and htis help but i been fixing ford for injectors problems specially number 8 injector
Jun 01, 2008 | 2005 Ford F 350 Super Duty
Antec SL300S 300W Power Supply (045176) 300-Watt Power Supply Logo
98 people viewed this question
Top Antec Computers & Internet Experts
Steven Wander
Steven Wander
Dimitar Todorov
Julie Endres
Are you an Antec Computer and Internet Expert? Answer questions, earn points and help others
