Question about Jandy Stealth 2 HP UR Pool Pump SHPM2.0 SHPM20
Having problems with jandy stealth pump for my pool. it doesn't go it high speed
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
Need new 2 speed relay
Posted on Sep 25, 2014
  • 59 Answers
SOURCE: Pentair 2 speed pump will not go on high speed
check to confirm jandy system is wired for high. if all wiring is correct you could have bad hi speed windings.
david
Posted on May 25, 2009
  • 16 Answers
SOURCE: my 2 speed pool pums is only working on low speed.
could be the start capacitor or run capacitor on pump motor.
Posted on Aug 23, 2009
  • 16 Answers
SOURCE: Jandy pool pump will not prime it is a Jandy plus HP model PHPM 2.0
make sure pool is full of water
check skimmer weir doors and make sure not stuck in up position
fill pump basket with water and try to prime
if that doesn't work
replace diffuser oring
http://www.jandy-downloads.com/pdfs/PHP_Manual.pdf
Posted on Jan 16, 2010
thepool
  • 78 Answers
SOURCE: digital read out....fault high ref pressure.
Verify circulating pump is on and that there are no water flow restrictions to the heat pump. Make sure all necessary valves are open or in the proper positions to allow proper water flow to the heat pump. Verify filter and skimmers are clean. Check for water level in the pool. This condition may also appear if the heat pump has not been operated for an extended period. To clear the condition, cycle the heat pump, on and off, up to 3 times. If this does not correct the problem, call for service.
Posted on Apr 22, 2010
  • 351 Answers
SOURCE: Jandy/Stealth Pool Pump motot
Hi .. If ypou are gtetting air in the basket, then ytou have a leak somewhere in the system. start by closing off the skimmer, bottom, cleaner one at a time and see when the air stops gettingt in. Is there enough water level to cover the skimmer? have you checked the seal on the strainer at the pump? you might be able top hear hissing if it is at the pump.
Posted on May 04, 2010
Is there a reset button for a jandy stealth 1.5HP pool pump
it kicks out breaker try turning the motor shaft if still doesnt work need new motor
Jun 27, 2012 | Jandy Stealth 1.5 HP UR Pool Pump SHPM1.5...
Jandy Stealth wired internally for 220V. There are three available terminals, the "A", the "B" or the L1 but I only have two red wires. Where do they go?
look at the schematic on the side of the motor it will tell you where the two red wires go probably on L1 and L2 green to ground the case
Feb 27, 2011 | Jandy Stealth 1.5 HP UR Pool Pump SHPM1.5...
Jandy Stealth 2.0 tripping GFI after heavy rain. Been a week since storm.
Very possibly a bad GFI. GFI's are cheap and worth replacing if in question. also might try hooking up directly to another source and see if it trips a breaker
Sep 13, 2010 | Jandy PHP High Head Pump 2 HP Up rated
Jandy mhp pump wiring connect
Hi, The connections for the pool pump motor should be described on the motor name plate, inside the cover of the wiring cubby, or on the wiring base near the terminals. Questions?
Jun 19, 2010 | Jandy Stealth 1 HP UR Pool Pump SHPM1.0...
May 02, 2010 | Jandy Stealth 2 HP UR Pool Pump SHPM2.0...
My 2 speed jandy pool pump is over heating
you may either have a bad start/run capacitor for the high speed side or bad supply voltage feeding the high speed side. If there are no loud bearing noises, it should just be either of those two problems.
Aug 15, 2009 | Jandy PlusHP Pool Pump EE Dual Speed - 2.0...
Pentair 2 speed pump will not go on high speed jandy system indicates on high but pump remains on low
david
Apr 24, 2009 | Pentair 2.0 Hp Whisperflo Pump
Jandy Stealth 2 HP UR Pool Pump SHPM2.0 SHPM20 Logo
166 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
