Question about Thermador Kitchen Ranges
I have a Thermador CV2136 "Cook 'n' Vent". When I was using it, there was a loud bang within the unit which blew the house main CB. The heating elements appear O.K., so it looks like there is a short circuit somewhere within the wiring harness. Is this fixable? Can one buy a replacement harness?
  • 49 Answers
SOURCE: suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Posted on Feb 19, 2008
  • 1314 Answers
SOURCE: stoves 900DFa dual fuel cooker
check to see if one of the oven elements are burned into if you have an oven cord on it turn the breaker off and check the cord where it connects to the oven
Posted on Mar 15, 2008
aborcass
  • 2651 Answers
SOURCE: Frigidaire electric range smooth top with no oven function
although you dont have hte model number , that is indeed a correct and valid part number for the control lists for a about $120. since your back there give a quick look at the wiring into the unit, is that ok ??? adn where the burnout is on the control does it appear to have shorted out against the back wall??? perhaps a relay on the board just blew??? i really wouldn't thinkn tha another component was goning to make that go bad, also ck the bake and broil elements for continuity, perhapa wire fell off the element blowing out the control
Posted on Mar 20, 2008
SOURCE: Need advice on Kenmore electric range
turning frot burner on sparked and now all 4 burners don't work any more
Posted on Sep 12, 2008
  • 5 Answers
SOURCE: Thermador cook top with down draft ventalation
I would think you can. Most of the cooktops are 240v and the vents are 120v, so the vent may be feeding off of one of the cooktop's hot wires. My vent is fed from it's own receptacle but is harnessed along with the cooktop's 240v.
Posted on Jan 07, 2009
Where can I get a replacement knob for a Thermador Cook n Vent gastop. The model number is CV2136
try contacting the company that makes to stove, there should be a stag on the back to tell you who made it
May 06, 2016 | Ovens
I have been using my Bosch Xcel PBH 600 watt when suddenly it made a loud bang and stopped working.it also was smoking and blew the house mains switch...
If it blew the "house main" and the circuit breaker did not blow, it indicates the breaker for the unit and the associated circuit wiring has major problems and you need to get them checked asap by a licensed electrician. Don't use it again until the circuits are chceked.
Aug 20, 2014 | Washing Machines
Thermador Model # CV2136 Cooktop Elements
call the company or the manufactor they might have it for you.
Jan 05, 2013 | Thermador 37 in. SGSX365 Gas Cooktop
Thermador cook n vent stuck in the up position. We have a thermador cook n vent. We had it running for about an hour. We turned the fan off but now it is stuck in the up position and will not go down. ...
replace the switch if the switch is going on and up position and not in down position the you should replace the switch for this part you can order it from thermador if they still stock the piece hope this helps
Aug 11, 2010 | Thermador UCV36A 36" Universal Cook 'n'...
Cook 'n Vent Downdraft Up/Down Mechanism Replacing
just the switch should be replacable. My vent has a screw at each end (philips flatheads - accessible only when vent is up) just under the top cap. Removing the screws and cap should give you access to the switch. Just make sure you cut your breaker off first.
Nov 15, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Oct 31, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Thermador Cook 'n' Vent Stove with stuck vent (model # SGCS304RS)
I just had a similar problem. The switch knob, and backer for the blower got jambed in the housing. After pulling it all apart I called the parts center at Thermador and ordered a new switch. If you can hear the motor the raises the unit run, then that could be your problem.
Oct 11, 2008 | Cooktops
Kitchen Ranges Logo
100 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
