Question about Grohe Plumbing
I need a parts list and assebly instructions for a ladylux cafe
    Problem Solver:
  • 5 Answers
Hi. There are 6 different types of LadyLux Cafe. If you go to http://www.grohecatalog.com/line/LadyLux-Cafe you can choose your product and they have a parts list and an exploded diagram of each product. This should help and at least get you going.
Regards, Myles
Posted on Jan 01, 2011
I have Grohe Ladylux and the flow will arbitrarily switch from stream to spray on its own.
Mine would stick in the spray setting. I soaked the whole head in vinegar to clean it and the problem went away.
Oct 05, 2014 | Grohe Ladylux Cafe Faucet with PullOut...
Clean lime scale from Ladylux cafe pullout
get a bottle of CLR and mix a batch then soak the head in it for awhile . Calcium Lime and Rust Remover
Need to tighten my ladylux
Grohe has a special tool that is used for installation that comes with the faucet. You have to remove the pullout spray and remove the curved neck of the faucet by pulling out. Insert the tool in the main body and tighten from above. Most plumbers will keep this tool when installing. I don't know if Grohe still uses the same system still today, but they did in the past.
Sep 03, 2013 | Grohe Ladylux Cafe Faucet with PullOut...
When replacing the hose on a Grohe ladylux, which end needs the gasket?
Need to replace Ladylux cafe 33755 hose, can't reach water line. How can they be removed?
Oct 25, 2012 | Grohe Ladylux Cafe Faucet with PullOut...
My new Ladylux appears to have an aerator, but it's doesn't work worth a hoot! All other brands of taps have properly functioning aerators that keep the water from splashing , but this one splashes...
if its new you should,nt have had to have spare parts fitted,sounds like the tap is faulty,take it back and have it replaced.if you change it and theres still a problem it looks like you might have to change the model
Nov 08, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
I'm trying to replace the flexible hose on my Ladylux Plus but the hose doesn't seem to pull through.
If you remove it from the sprayer and then pull it out the bottom it should come out quite easy and you will also need to remove the weight and add it to the new hose after the new one is installed.
Aug 22, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
Ladylux handal can not be removed afert taking screw off
Could not find information for your exact model; however these specifcation which include diagrams of your faucet and installation and maintenance instructions should be useful. See here:
http://www.groheamerica.com/lib/1/tpi/1311703.pdf
Go to Page 5 and look under Maintenance for intruction on how to remove the handle and replace the cartridge.
Feb 14, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
Grohe ladylux cafe faucet has low flow eventhough supply valves are wide open. This is true for both hot and cold. When supply is disconected from faucet and valve turned on there is ample pressure. Is...
I have the same problem and have the fix. There is a water pressure regulator on the bottom of the faucet( under the sink) this part is bad. Grohe will replace it for free. Call Grohe at630=582=7722 tell them the model # of the faucet and the color of the regulator, they will send you a new one for FREE.
Jun 09, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Plumbing Logo
389 people viewed this question
Top Grohe Plumbing Experts
john h
Craig Butler
Craig Butler
Mike
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
