Question about Bosch Nexxt 300 Series WFMC2201UC
The washing machine quit with a full drum of water. It makes 3 short buzzing sounds every 5 seconds if you turn the machine on.The door is locked shut also.
    Genius:
  • Bosch Master
  • 1,474 Answers
Check to make sure its drained okay a this can be at fault///Could be blockage at the filter
Posted on Dec 31, 2010
I have IFB washing machine it shows E7 error
1:IFB Washing Machine Not Turning ON OR Turns ON But Does not Starts. 2:IFB Washing Machine Door Does Not Opening. DE Error 3: Water is not coming inside the IFB Washing Machine Inlet problem 4:Water is Leaking from the washing machine, drum or hose pipe damaged 5:Wash is not happening / Spin not Happening in the IFB Washing Machine 6:Drum NOt rotating or Drum Making Huge Sound while spin cycle, 7:Water not Draining From the washing Machine 8:Burning smell, Tripping Problem, etc https://electronicshelponline.blogspot.com/
Read more: http://ifbservices-com.webnode.in/error-code-fault-codes/
Aug 05, 2016 | IFB Washing Machines
I have a Samsung front loader washer that will not work on any cycle, it only makes a humming sound. The door was stuck locked shut, finally got door open after taking washer apart. I don't know what...
it might be the lock or the pump if it was still full of water
This video will show you how to open your washing machine door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 07, 2013 | Washing Machines
WFW94HEXW door won't unlock and Door Lock isn't lit
if you machine is warranty you must call to the whirlpool, and get the assistance via online chat. However you must wait about 180 seconds since you did the command STOP, and stop the motor, fi the water level is higher must be drain before the latch door unlock.
2) if do not obey press and hold END OF CYCLE, wait about 10seconds
3) reset the machine unplugged from wall by 45 minutes, and then plug again, and turn on and unlock the door
God bless you
Jun 21, 2012 | Washing Machines
Apart from the cover at the base. How do I access the internals of the machine. I have a loud noise on spin plus I seem to have a water leak inside
The front panel comes off. 1st you need to remove the Facia to access the 3 screws...Leak could be door boot seal noise sounds like drum bearings/ if its under 5 years old phone Hotpoint it will cost around £100 for call, parts are free.....If over 5 yaers think new machine as its quite expensive to do full job and not always worth it if old........
Dec 03, 2010 | Hotpoint Aquarius WF215 Front Load Washer
Zanussi jet stream iz16s tripping ouy rcd once filled up with
It would seem to me that the heating element needs replacing from the information you have supplied especially as it performs most of the other functions like filling and spin and drain.
Good luck
Mar 17, 2010 | Washing Machines
Washer quit spinning
Sounds like the lid switch has failed. This switch will not allow the drum to spin if it senses that the door is not locked. Have it replaced and that should take care of the problem. Hope this helps. Good luck.
Jul 23, 2009 | Roper RTW4300SQ Top Load Washer
Me Estate washing machine, when started fills to specified water level then, it makes a buzzing noise then the buzz quits and nothing happens. Machine won't agitate or drain, just buzz then buzz quits.
sounds like you have a problem with your water supply to washer. the buzzing noise sounds like it's the valve opening to receive water but nothing going in. check supply hoses and water taps
Jul 14, 2009 | Washing Machines
After a load it makes a sound and as if the door
your lock could be bad, but when it unlocks it buzzes as if already unlocked? Is the door actully unlocked during the cycle but display reports locked? this would be a bad switch within the lock asm
Jul 14, 2009 | GE Energy Star WCVH6260F Front Load Washer
Ge adora whdvh626fww not filling with water and locks door
Can you take a look at the pump to see check why it is able to pump-in water ? Motor is still good as you can hear it trying to pump-in water.
Sep 30, 2008 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Bosch Nexxt 300 Series WFMC2201UC Logo
69 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
