Question about Panasonic Microwave Ovens
M# 1757 S#E14250048 Error Code F 21 - Panasonic Microwave Ovens
  • William Miller
    William Miller May 11, 2010
    I have the service manual for model the Panasonic commercial microwave model NE-1757.
    Is that your model number?
    I'm not showing an error code F21.
    Is that the correct code?
That is the correct model #
Also I don't find an F21 error code in my manual also ????, Thanks for any help you can give me.
Alan
Posted on Jul 10, 2008
What is error 21 in micro waves
In case you are using a Samsung Microwave, Error 21 or E21 is Thermistor Short error. It is caused when the thermistor sensor, which senses the temperature of the cavity inside does not work properly.
To correct this, unplug the power cord and wait for more than 10 seconds. Plug the power cord
again. If the symptom persists, contact the nearest service centre
Aug 30, 2016 | In Microwave Ovens
ERROR CODE E 21 APPEARS. WHAT DOES THIS MEAN PLEASE - AND WHAT CAN I DO ??
Cavity thermistor sensor may be defective. Or, wiring to it could be bad.
Apr 29, 2016 | Microwave Ovens
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
E-21 error on a Frigidair microwave oven
replace thermal sensor and fix it. God bless you
see the photo attached.
Nov 22, 2013 | Microwave Ovens
Aeg glass induction hob error code ER 21
reset the microwave. Disconnect the power cord, by 1minutes, and try again,the microcontroller is confuse.
If the problem persist you can be problem with the main controller board, repllace, but read your owner manual section troubleshooting for identi the error. download from www.retrevo.com
God bless you
Oct 27, 2013 | Microwave Ovens
Parts breakdown for panasonic ne-1757
The suffix will make a difference, but the two service manuals are here http://www.microwavedisplay.com/NE1257A_C_NE-1757A_C_NE-2157A_C_sm.pdf AND here
http://www.microwavedisplay.com/NE1257R_CR_NE-1757R_CR_NE-2157R_CR_NE-1258R_sm.pdf
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Sep 10, 2009 | Panasonic Pro NE1757 Microwave Oven
Error code E-21 Jenn Air convection microwave
That code says to first check your oven temp. sensor probe connection and ohm it out with an ohm meter, it should read about 1100 ohms at room temp.
If thats ok, then it says the problem is your relay board.
If you need more repair advice help on your appliance, click
Here
Jul 07, 2009 | Jenn-Air JMV8208A Microwave Oven
Works for approx 30 secs then it cuts off with a error Code F7 message.
Assuming yours is a model KHMS2050SSS0, here is what the technical sheet says about the F7 error code:
1. Unplug microwave oven or disconnect power.
2. After 40 seconds, check to see whether this solves the problem.
3. Unplug microwave oven or disconnect power.
4. Check cooling fan operation
5. Check the magnetron.
6. Check P65 connection on the relay control board.
7. Check the P56/P66 connection between relay board and relay control board.
8. Check wiring to the 1200W inverter and control system. See “Checking Inverters.”
9. Check operation of all interlock switches.
10. Replace all parts and panels before operating.
11. Plug in microwave oven or reconnect power.
12. Check voltage at 4903-1 on relay board. If it is 120, unplug microwave oven or disconnect power.
13. Replace inverter.
14. Replace all parts and panels before operating.
15. Plug in microwave oven or reconnect power.
16. If problem persists, unplug microwave oven or disconnect power.
17. Replace relay control board.
18. Replace all parts and panels before operating.
19. Plug in microwave oven or reconnect power.
20. If problem persists, unplug microwave oven or disconnect power.
21. Check for reversed plug connection on controls or loose wiring.
22. Replace all parts and panels before operating.
23. Plug in microwave oven or reconnect power.
(This troubleshooting guide presumes one does not know how to test electronic components. That's why they say to replace and part and check it again.)
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If yours is a different model number, please reply back.
May 26, 2009 | KitchenAid KHMS2050SSS Microwave Oven
NEED TO ORDER GLASS COOKING TRAY FOR MCD990ARS PART #3517203500 OR FIND STORE IN AREA CODE 48316 THAT WILL HAVE THE GLASS TRAY.
check this site :http://microwaveglasstrays.com/shop/microwave-glass-trays-c-21.html. search for your brand name buy online.
Jul 24, 2008 | Magic Chef Microwave Ovens
Microwave runs for a few seconds then F 12 displays on screen and it stops
The following is a solution for the Panasonic brand microwave. I do not know your brand so this is the best I can do.
PANASONIC
Model: NE-1057, NE-1057C, NE-1257, NE-1077, NE-1277, NE-1457, NE-1457C, NE-1757, NE-1477, NE-1777 Symptom: Code "F11" or "F12" appears on the display intermittently Problem: Moisture is accumulating on control panel from steam rising out of the door. Solution: Install foam sealer (cushion rubber) along lower edge of control panel escutcheon. Part # A8251-3180
Apr 03, 2008 | Microwave Ovens
Microwave Ovens Logo
183 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
