Question about Hayward Power Flo Lx
How do I get the pump apart to fix it, it is seized up on me, but it will turn, can't figure out how to get the fin off to get to the shaft to get the shaft out, what can I do?
    President:
  • Hayward Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Removing the impeller requires you lock the shaft as you turn the impeller off counter-clockwise. To lock the impeller you will have to remove the motor end cover or a cap covering the shaft end depending on which version your particular motor has. Look at the end opposite the pump and imagine a shaft from one end to the other right in the center.
Once you remove the cover you will see a slot for a screwdriver, a flat for a wrench, a hex hole for a hex key or some combination of these. Lock the shaft and spin off the impeller. Some are so tight you will end up breaking them in the process. Simply replace it and the seal. Be sure the motor shaft is in good enough condition to allow the new seal to work properly. If too much shaft material has rotted away the new seal will leak soon after it is installed; you would need a new motor at that point.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Posted on Dec 31, 2010
Remove and replace waterpump on 88 mod petrol jackaroo
see if you can turn the pump shaft by hand (hub at the end of the shaft. If you can then the pump may be ok. check for idler pulley seized . Any item with bearings that spins easily will be ok. Check that the power steering pump turns by hand.
Pumps will not seize if they are not turning.water pump bearings will produce a deep grumbling rattly noise when idling if they are failing.
Dec 31, 2014 | Cars & Trucks
Ap-125 homelite gas watwer pump pull cord replace
few years late but here: guessing your problem area is the impeller blade? remove impeller blade by turning clockwise ( i put a screwdriver in the pull cord fin to stop shaft). Then remove spring around rubber gasket behind blade (then rubber gasket pulls off shaft. everything else just UN-bolts. Just figured it out myself today.
Jan 01, 2013 | Homelite Plumbing
I have a ANNOVI pressure washer and I can not seam to get the engine apart from the pressure pump. All bolts are removed and the bludy thing will not come apart. The lock nut on the drive is not even
There may be no good news for you. Once those hollow shaft pumps seize to a engine shaft, they can be real buggers. In fact, they can be impossible.
But before you give up and completely destroy the pump to remove it from the shaft -- the mounting flange has threaded holes that are designed for taking the pump off. The bolts that you removed go through unthreaded holes on the pump flange and into threaded holes on the engine. On the pump flange, there are also either two or four threaded holes. So you take the same bolts and screw them into the threaded flange holes -- the idea being they will contact the engine as you screw them down and push the pump outward.
BUT: this does not always provide a fix. That flange is made out of cast aluminum so it is not very strong. It breaks quite easily. So your best shot at getting the pump off this way is to go slow. Put some oil on the bolt threads, so they will turn easily. Try to bring them up to equal pressure and then use a meium hammer to "ping" somewhere. Remember though, the entire pump casing is made out of this cast alluminum and is very brittle. It is easy to knock a hole in the pump with a hammer. But alternating with some persistent pinging and then tightening the bolts a little more (tighten/ping/tighten/ping) is the shot you have. When tightening down on the bolts - equal pressure on each side is very important. And I can't over emphasis....just a little bit at the time! And if you can (if there is room) pinging on the engine shaft a git can help too.
If it seems to move a little, but then gets even more resistent, oil the engine shaft and knock the pump back down and then start over going in the off direction. This is because once you get some oil under the hollow pump shaft it usually will free up.
From someone who knows how frustrating it is, I hope this helps you. If it does, please take a sec to rate me. Thanks!
Don
Mar 18, 2012 | Garden
The pump was left off for a couple of weeks. When I try to turn it back on, the circuit breaker trips. I banged the pump housing with a rubber mallet bu it still trips the breaker. Thank you
You may have a blown motor start capacitor, or the motor shaft has seized up. Try to see if you can reach the impeller through the hole in the back of the pump pot and spin it with your finger. If you can't then it has seized and you will need to take it apart to see if something is jamming the impeller or the bearings are locked up. Make sure you have the power off before you try to spin the impeller with your finger or you could end up missing a finger if it should start running.
Sep 11, 2011 | Hayward ALADDIN GO-KIT1 FOR HAYWARD MAX...
Motor hums, but wont run, it's seized up. What do I do?
The first thing to do is to disconnect power to make sure it cannot come on while you are trying to fix it. Determine for sure weather the motor is seized up by either trying to turn the shaft under the cover on the end of the motor or reaching in the pump pot and turning the impeller with your finger or with a metal tool. If the motor cannot be turned then it usually needs to be replaced. If it can be turned then the capacitor may be defective and if you can replace it the pump has a better than even chance to work normally. Otherwise, the motor needs to be replaced. I hope this helps.
Sep 04, 2011 | Sta Rite 18" AG Sand Filter System 1 HP...
My spa will hum when turned on but will not push water. The motor then turns off.
The pump seized up or the motor bearings went bad and seized up...
Bottom line is that you will need to remove the pump and motor and take it apart to figure out what is causing the problem....
heatman101
Aug 29, 2011 | Whirlpool Home
HAVE SWITCHED ON PUMP FOR FIRST TIME THIS SEASON AND IT IS BUZZING BUT NOT TURNING AT ALL. SEEMS SEIZED. PROBABLY INSUFFICIENT WINTERISATION IS THE PROBLEM. WHAT COULD BE THE PROBLEM? DO YOU THINK IT'S...
Yes they do sieze up....try to get a pump pliers on the shaft between the pump and the motor and turn it backand forth till it frees up...then turn the pump on... sometimes you can even help the pump get started with the pliers...do not use your fingers!!!
If that does not work, then you will need to take the pump apart and figure out if the motor or the pump is causing the problem and replace accordingly..
heatman101
Apr 22, 2011 | Garden
Pump hums then breaker flips
Something is binding in the pump try the impeller to see if it runs true when you have it apart. It may be cross threaded on the shaft. This is a common problem if you have a air leak in your system.
Apr 28, 2010 | Sta Rite Max - E - Pro 1 1/2 Hp Dual Speed
Dishwasher pump will drain but not force water into spray arms
Hi there is a scond motor that forces the water through the spray arms it sounds like the motor has seized .
Dec 11, 2007 | Hotpoint 18 in. DC27 Slim-Line Built-in...
Hayward Power Flo Lx Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
