Question about Sony TC KA2ES Stereo Cassette Deck Dual Cassette Deck
I've got a TC-K461S Sony cassette deck. I didn't used it for like 8 years. Now when I press 'play', it's going to fast forward - like fast forward winding. Do you have any idea? Thanks a lot!
petraman7
  • 1175 Answers
SOURCE: tascam 122 cassette deck the cassette player won't play
There is an idler wheel behind the platen ( black plate behind the cassette)..replace the idler wheel.
The guy in texas is Marrs communications
Posted on Mar 25, 2010
petraman7
  • 1175 Answers
SOURCE: Door won't open
It might be a model that has a special IC that allows the door to open and close.
You'll need to take the case off.
try hifiengine.com...that site may have the service manual.
Kirk out
Posted on May 05, 2008
dunnbiker
  • 8546 Answers
SOURCE: sony cassette deck tc fx 210
Define 'skip' in the context of your CASSETTE deck.
Poor audio is usually due to damaged media or dirty transport (heads, pinch rollers and capstan).
You can see the tape inside the cutouts of the cassette shell. It should be perfecly smooth and the edges straight. Use reflected light to evaluate it. Edge damage will affect the Left Channel most.
Dirty heads will cause loss of high frequencies first.
The transport, well, if we need to explain it to you then we KNOW it's never been cleaned.
See this helpful link.
http://www.fixitclub.com/Electronics/Cassette_Deck.shtml
Posted on Mar 05, 2010
  • 5 Answers
SOURCE: Repair of Sansui cassette deck D-1000W and Compu Receiver Z-5000X in India.
i have the same deck with same problem..so this is the typical problem for this deck...got it from thrift shop..it was in perfect condition, working excellent but after few days of enjoying it, all of a sudden the same problem arises.... and the motor is abnormally hot..it is way too fast.
when i switch on the power the middle motor will automatically turn on at very high speed...i play around anything i can do hoping something is just stuck up but to no avail..
Posted on May 19, 2010
SOURCE: Sony TC-K690 3Head Cassette Deck - no playback
It needs a new rubber belt for the mechanism control.
It is a smallest of th 3 rubber belts.
Posted on Jan 25, 2011
How do I dub using the onyx double cassette deck?
There should be a button or switch that will select the recording deck and the dubbing deck. You put a blank tape into the recording deck and the pre-recorded one into the play deck. Pressing the record button on the dubbing deck, on some models should start the play deck running. If not press play on that deck.
Jun 05, 2014 | Sony TC WE435 Stereo Dual Cassette Deck...
When play button is pressed it switches itself off after a couple of seconds on Sony cassette deck
When a deck is stored for some time, the belts perish, or the belt on the main capstan drive motor ends up with tight bend in it, where it has been on the pulley for a while. On start up, the belt will drop off the flywheel.
Take off the lid and investigate. For fast forward & rewind the reel motor drives it, this motor also is used for take up on play.
If the capstan(s) are not running, the take up will not work. Most machines have a sensor on the feed spool, if this does not rotate, it will switch off so as not to feed a load of tape with nowhere to go.
Google your deck number for drive belts.
Mar 25, 2013 | Audio Players & Recorders
Sony TC-138SD cassette deck starts to play then stops after 3 secs. Same when trying to rewind/fast forward
It sounds like the belt is slipping or broken which monitors the speed of the tape movement. When you play or rewind the tape, it thinks the tape has reached the end of play and shuts off. You can try a different tape to make sure the tape does not have too much tension on it. If the second tape has the same result you will need to remove the top cover of the deck to inspect the tape drive mechanism. Make sure the belts and pulleys are clean and replace any belts which have glazing or cracks. If the belt is broken you will need to replace it with a compatible belt of the same length and width.
Aug 15, 2011 | Sony CASSETTE DECK Single Dual Cassette...
Both decks eat tapes when fast forwarding, normal play is OK
it never eate tape in ff or rew mode . look for back tenssion
Jun 21, 2010 | Sony TC-WA7ESA Single Cassette Deck
Mar 14, 2010 | Sony Audio Players & Recorders
Sony TC-WR670 eject wont open deck
I had the same problem. You probably have to replace the rubber belts.
Dec 02, 2009 | Sony STR-DE405
Cassette stuck in Sony TC-K611S deck
Rotate loading gear with your finger until mechanism released and set on stop position. press eject button and take out tape.
Jul 01, 2009 | Audio Players & Recorders
Tape will not turn
The more detailed the description of the problem, the better for diagnosing the root cause. Thanks.
It sounds like you have a couple of problems. I'll address them as you have them numbered above.
1. Decks typically have belts to drive the various 'reel' mechanisms. Therefore, they can slip without breaking anything inside the machine or the tape. Your first symptom leads me in that direction.
2. That it migrated is mysterious, unless Sony is using a common motor to handle both decks' reel duties.
3. This symptom may have something to do with the root cause of both sides jamming...
Do the cassette well doors come off, say, for cleaning? Could they be dislodge? If so, they may have something to do with the jamming problems in # 1 and #2 as the doors play a part in positioning the cassette and holding it in place against the reel motor cogs. How do the doors operate with NO tape inserted?
Does it take excessive force to close the door only WITH a tape? make sure the tape is fully seated before closing the door. The capstans (directly below each reel cog) have to engage through the small holes at the lower edge of the cassette. They should be straight and clean. Any dirt or oxide on them will cause problems as these are what move the tape at the precise speed necessary for good playback or recording.
My hipshot recommendation, otherwise, is to look around inside the cassette wells very carefully for any foreign matter, debris, dust bunnies.
Do you maintain the deck as recommended?
Apr 02, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
Tascam 122 cassette deck the cassette player won't play
Mar 18, 2009 | Tascam 122MKIII Single Dual Cassette Deck
Cassette Tape Deck Problem
Unit may have worn belts that are slipping. All cassette player belts are subject to deterioration even if recently installed. You may try ordering the belts yourself and have a service tech install them. The tech that installed belts 9 months ago may have used used belts. Although dishonest, it is common.
Jul 17, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
Sony TC KA2ES Stereo Cassette Deck Dual Cassette Deck Logo
359 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
