Question about Broan-NuTone Vacuums
My broan cv30 purchased in 1996 carpet power head unit sucks up dirt and rocks but will not pick string or yarns up from carpeting. I find myself picking it up. It is sucking fine dirt and small particles but won't pick up stiring or yarn that need extra brushing from the carpet. Do I need a new motor for the powerhead unit-is that replacement still available?
  • 694 Answers
It's possible you simply need a new belt or roller brush. Place the power nozzle upside-down turn the vacuum on. Ensure the brush turns. If it doesn't, the belt has broken or is too worn to turn it. Replace the belt. Make sure the tension is properly set prior to reassembling the power nozzle.
Next, with the power nozzle upside down, run the flat of your palm across the brush area. If you can barely feel the bristles, it needs replaced. A good brush will loosen the yarn and strings, but needs to be cleaned periodically.
As long as the powerhead motor is running, there is no need to replace it. If it's not running, look for a reset button and press it. There could also be a broken wire, loose connection, or bad switch causing a power head motor to not operate..
Posted on Dec 31, 2010
My dirty devil vacuum cleaner is not picking even the tinniest dirt off the carpet
Has the hose at the clearer head gotten clogged with carpet fibers, that is the common reason for this.
Sep 21, 2016 | Dirt Devil Vacuums
Why is it not picking up dust and dirt from carpet. pipes clear. Can you help
How to Fix a Vacuum That Lost Suction - Quick and Dirty Tips
www.quickanddirtytips.com/.../how-to-fix-a-vacuum-that-lost-suction
Oct 3, 2013 - It's true, a vacuum that doesn't have suction is not very useful ... The first and most basic reason a vacuum isn't picking things up off the floor is if the ...The lower your carpet, the closer the dial or lever should be to the bare floor setting. ....it off and shaking the dust off put the power right back in my vacuum!
Common Vacuum Issues - and what you can do to solve them
blog.mchardyvac.com/.../common-vacuum-complaints-what-you-can-do...
Oct 4, 2013 - Your vacuum's job is to pick up dirt, dust and debris - so when it stopsdoing ... Often when your machine is not picking up it is due to loss of suction. If yourvacuum cleaner turns on but won't pick up on carpet or bare floors, ...
Is your vacuum cleaner not picking up dirt and debris ...
https://www.mrright.in/.../is-your-vacuum-cleaner-not-picking-up-dirt-a...
Jan 7, 2015 - But many times it does not pick up or suck the dust as effectively as it is supposed to do. ... If the vacuum cleaner fails to pick up dirt and debris and has no ... Deep clean your expensive carpets to restore their original look.
Jan 24, 2016 | Vacuums
Dirt devil breeze bagless height adjustment mafunction
Hi there! If your vacuum is suddenly hard to push your roller lifter assembly, which controls the automatic height adjustment, may be damaged or broken. Check your roller lifter assembly located underneath your unit for damages. Also, your brushes help to maneuver through carpet, check that your brushes are still spinning. If not, replace the belt on your vacuum. I have included a link where you may visit to purchase a replacement belt for your vacuum. Hope this helps!
Style 4
Aug 08, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Seems to be sucking up the particles from the actual carpet, either the pad or carpet itself Help???
It sounds like there may be sand in the carpet. If you live in a sandy area, this is not unusual. Walking on the carpet will cause the fibers to rub on the sand and eventually be cut through. The vacuum is strong enough to pick up these fibers, but not the sand that's causing the problem. I recommend buying a vacuum that has enough suction to pick up the sand. One that you don't have to replace every couple years.
My recommendations would be: Aerus (once Electrolux), TriStar, Filter Queen, or Royal. Avoid any that have plastic fans, as the fan blades will wear down fairly quickly with sand being vacuumed.
Dec 17, 2010 | Dirt Devil Vacuums
Vacuum sucks up dirt and expells it back onto the carpet as I am using it. I have replaced the bag and took the bottom off to clean - even cleaned up the area where the dirt should go to make sure it was...
Good chance the tube from the base up the handle is clogged. Try removing the bag and look at the exit, that is where most clogs on this unit occur. Look for hair, string, etc. If clog is not there, then may be in the tube or at the base swivel unit to the tube interface.
Once you clear the tube, re-attach bag an d power up unit, be careful that it does not throw some debris at you.
Oct 14, 2009 | Oreck XL2600 Vacuum
Carpet roller will not turn. Vacuum still sucks up dirt
You may need to replace the belt that drives the roller head. They wear out and break, or maybe it has just come loose. Also check for string and thread wound around the roller wheel axles, that is a common "culprit"
Jul 21, 2009 | Kenmore 23913 Progressive PowerMate Bagged...
Carpet vacuum attachment quit working after sucking up a bedskirt. Bedskirt has been removed but carpet attachment will not work. My old vacuum had a reset button on the carpet attachment for use when...
I have a Hoover Conquest approx. 4 yrs old. The turbo head is not working Model No. PB4 230-240V AC 50Hz 200w CS4901N (N127) I have been trying to locate another one or another one similiar to fit my machine
Jun 12, 2008 | Hoover Vacuums
Kirby sentria
Hi There, The machine does not actually suck the suds up. Basically the machine lays the foam down which then crystalises and absorbs the dirt in the process. Once this has had around - 4-5 hours to dry then you vacuum up as normal taking the crystalised dirt away. You should really use the Genuine Kirby product as it's very good but you can also you any other DRY FOAM shampoo. Hope this helps Chris www.elidistribution.co.uk
Sep 22, 2007 | Vacuums
Kirby Ultimate won't clean carpet
when you install the hose connector it trips a switch that switches the vac motor into high speed because the vac path is longer using the hose. check the belt after you remove the front. make sure the direction of rotation is in the direction of belt travel stamped in the impeller. try adjusting the head height
Aug 13, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
185 people viewed this question
Top Broan-NuTone Vacuums Experts
Steve
Gerry Harvey
Gerry Harvey
JoeVacs
Are you a Broan-NuTone Vacuum Expert? Answer questions, earn points and help others
