Question about Dishwashers
I have bosch dishwasher SGU6932SK/13. Front panel is broken, and I have bought a new one. My problem is how to remove the old one. There are many torx-screws, which I have loosened, but this doesn't help.
5 Suggested Answers
  • 11 Answers
SOURCE: Securing Bosch SHU 4300 under "hard" countertops
If this is a new Bosch Dishwasher then there should be two metal tabs that protrude from the top of the tub above the door. These tabs are for top mounting the dishwasher to a wood countertop, however these tabs also can be relocated to side mount the dishwasher to the cabinetry. The way to do this is to pull the dishwasher out of the hole it is in, in the counter (be careful not to pull too hard or to move the machine out too far due to the length of the water and electric lines). just pull it out easy till you can see the tabs, Now using a pair of pliers, bend the tabs on the backside of the mounts straight so you can remove them from the framing of the dishwasher. Next look at the tabs there should be a perforation where you can use 2 pairs of pliers to snap the tabs off at the perforation, after snapping off these tabs, look at the sides of the dishwasher and you will see a slot where you can reattach the tabs into, and bend the tabs in the back to hold them in place. If you look at the rubber gasket material on both sides of the machine - you can see where the round holes are located for side mounting. Attach the tabs and gently push the machine back into the cabinetry. Now using a small drill bit, drill a pilot hole into both sides of the cabinets to mount the dishwasher. You want to drill these pilot holes so as not to split the counter facing when you drill in the screws. Using the Bosch screws that came with the dishwasher (or small flat phillips screws) slowly screw in the screws into the sides of the cabinetry. When you attempt to remove the machine from the cabinetry you may find that it is adjusted tight to the countertop. If this is the case you will need to remove the 2 screws that hold the kickplate in at the bottom of the dishwasher in the front and remove the kickplate. Then you will need to bring up the front legs on both the left and the right and also the rear leg which is adjusted up and down by using a flat blade screwdriver. Look at the front of the dishwasher, behind the kickplate and there will be a adjusting screw with arrows which point left to right. the direction you turn this screw will determine which way the dishwasher will adjust,- right adjusts the machine higher and left lower. Good luck!!!!!! Hope this helps.
Posted on Feb 05, 2009
SOURCE: bosch dishwasher electrical smell
probably is, hit the breaker
Posted on Mar 31, 2009
  • 718 Answers
SOURCE: I'm trying to take apart a kitchenaid dishwasher door
You can get assembly diagrams of your system. Go to;
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=503880
Click on the diagrams in the left-hand side. You will see how the parts go together.
Posted on Apr 18, 2009
  • 246 Answers
SOURCE: Need to change color of front of dishwasher
Try Applianceart.com. They have a ton of options in colors and desings
Posted on Jan 14, 2010
My seven year old Bosch dishwasher has broken down. Should I have it repaired or is it too old and buy a new one.
7 years is close to its lifespan more to the point bosch parts are very expensive in general it all really depends on whats wrong with it?
Oct 08, 2014 | Bosch SPV68L00GB Slimline 450 mm Silver...
Bosch SHE55M16UC/64 Dishwasher replacing control panel fascia or cover. How to remove chrome handle cover from old part and reinstall it?
You will have to take the door apart. Be very careful not to break any clips. The screws for the handle are on the inside of the door.
Mar 13, 2014 | Bosch Dishwashers
Bosch has discontinued making the front flip tine insert for the bottom rack. I have two broken in my Bosch dishwasher. Can I substitute another manufacturer's part?
A solution to this problem would be to sell me your dishwasher. The law firm for which I work is looking to acquire an old unrepaired Bosch SHU 33 dishwasher for some ongoing litigation. If you (or anyone else with this model Bosch) could send me some details regarding your dishwasher, you may be able simply to buy a whole new dishwasher. My email is JFraser -at- jshlawmi.com.
Thanks!
Sep 07, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
The front panel is broken
http://www.4bosch.co.uk/cgi-bin/product.pl?PID=906106&brand=&model=sgS43E02gb%2f45&part=dishwasher%20panelI have this dishwasher with the same problem and tonight the whole panel broke off.Not sure what I am going to do yet as the dishwasher works perfectly except for this but is 6yrs old.
Jul 25, 2010 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
How do I reset an old Bosch dishwasher SHI4302UC ?
Assuming that you can control power to the dishwasher from your kitchen panel switches, hold down the power on switch on the front panel of the dishwasher and recycle power (switch off and on) at the kitchen panel switch.
This will reset the dishwasher.
Sep 26, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
4 year old dishwasher no longer draining water
check out my guide HERE. It addresses other problems you can have with bosch drainage. Tell me what you think!
Jul 26, 2009 | Bosch Dishwashers
3 yrs old model; worked fine then no lights on front panel
i hate to tell you this, but more than likely the circuit board behind that light has gone bad. It is a costly fix at several hundred dollars, and this isn't the first one i've heard that has done this...
Mar 13, 2009 | Bosch Evolution 300 SHE43M0 Built-in...
Bosch Dishwasher Problem
if you remove the front panel (the 6 torx screws) and the facia panel you can access the control module. remove the module and open it up to see if you have a burn mark from the solder melting. if you do then you know to replace the control module
Nov 26, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch SHV 6800 dishwasher, 2HR error
Bosch dishwasher all cycles start at 2H and get hungup on 1 min.
Jul 02, 2008 | Bosch SHU9950 Dishwasher
Bosch Dishwasher SGS43E02 Exxcel Control/Display Facia Panel
The panel is replaceable by removing the #20 torx screws inside the door. Once removed the metal outer door cover will slide down and the plastic top housing less switch panel can be unclipped from two locking tabs on either side. You can order via BOSCH service center, check to see if it is warrantied before removing
Feb 06, 2008 | Bosch 24 in. SGS43E02 Exxcel Built-In...
Dishwashers Logo
96 people viewed this question
Top Dishwashers Experts
