Question about JBL PB10 Subwoofer
When I plug it up it makes a loud buzzing humming sound that's unconteollable with the volume.
    Brigadier General:
  • 8,546 Answers
Buzzing is usally AC line noise leaking into an un-shielded cable somewhere or a floating ground. If the AC plug is reversable, try that. make sure all audio cables are pluh\gged in tightly at each end and routed away from or at right angles to any power cords and away from other sources of strong magnetic fields like TV's. I've also seen variable track lights induce noise but it's usually minor.
If it still does it with no cables attached it's an internal amp problem.
Posted on Dec 31, 2010
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
Is there a way I can fix the low static sound on my Magnavox DVD player
Magnavox tv has loud static - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-2293282/magnavox-loud-static.html
Sep 9, 2014 - After a loud clap of thunder my magnavox tv with built in dvd and vcr developed static sound ... JVC DVD player and Samsung VCR to my new MagnavoxHDMI TV ... Can you connect the cable box with a HDMI cable or component ... and making a loud humming sound how do I fix help · Burning in of static ...
What is that TV Buzzing Noise? - noice fix brokentv ' Ask MetaFilter
ask.metafilter.com/17525/What-is-that-TV-Buzzing-Noise
Apr 14, 2005 - My TV does this annoying buzzing sort of humming noise (vibrating?) ... It especially seems to do it when I have the volume turned down low (or else I just don't notice .... The capacitors in there can store a charge large enough to kill you for 12 hours or more. ... Although, I feel like I hear it more often on DVD.
HOW TO FIX VCR & DVD PLAYERS REVIEW - YouTube
? 9:23
https://www.youtube.com/watch?v=1ggOD7RnMJU
Mar 17, 2013 - Uploaded by Tampatec
HOW TO REPAIR FIX VCR VHS DVD COMBO Easy Quick & Simple COMMON FIXES FOR ... this works ...
Magnavox TV help - ecoustics.com
Dec 30, 2015 | Magnavox Televison & Video
Humming sound
Samsung states - A buzzing sound from your plasma TV is normal. It is caused by the electrical charges used to create the images on the screen. The buzzing, however, should not be so loud that you can hear it when the volume on the TV is set at normal levels.It is also important to determine the type of buzzing sound. A sound like a ground hum is completely normal. This buzzing can originate near the power cord connection or from the SMPS board position on the upper back of the TV. The buzz will be more audible as contrast increases on the screen, most notably when displaying an all white screen. If the buzzing sound is loud, you may have the Contrast set too high. Lower the contrast to reduce or eliminate the buzzing.You may also have loud buzzing if the rear of your Plasma TV is too close to a wall or other hard surface. Try moving your TV away from the wall until the buzzing is minimized. [1]
If the buzzing is at a higher frequency and resembles a crackling sound (like the sound of Velcro being pulled apart), and originates from the upper middle back of the TV, you likely have a failing SMPS board. Place a support call with Samsung to have the SMPS board replaced.FP-T5084 Have a known buzzing problem with a very simple fix.If the buzzing is coming from the left or right sides of the rear and the volume can be changed by pressing lightly on those locations, you are probably hearing the vibration of the grounding springs on the back panel. Call Samsung (or whoever) and have a technician confirm the problem. The easiest fix is to insulate the offending spring by applying some felt tape.
May 22, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
Hi, I have a pair of Polk RT1000i powered towers and one now makes a constant loud humming or buzzing sound. It is not hooked up to the receiver. It does it as soon as its pluged into the wall. Any...
the volume on the speakers are too high. try to put make the speakers the master volume(whatever device you plug in into your speakers make that device's volume go all the way up and then adjust the volume on the speakers to what ever volume you desire.had the same problem with my computer speakers
Jan 16, 2010 | Polk Audio RT1000I Speaker
Constant buzzing in my 15 W amplifier
Make sure you have a ground prong on your power cord. Most input jacks nowadays are closed circuit. They have a switch built in that won't allow any sound without the cord plugged in. You may have a damaged jack that will give you a loud hiss, a loud hum or crackling depending on what volume your controls are set at.
Aug 27, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
Loud buzzing/Humming noise.
I have a Amana ASD2622HRW Lately there is a loud buzz that comes and goes. We cleaned everything and blew it out under and behind the fridge. And it still is happening. Any suggestions? It still cools fine. But this Buzz is so loud that you can hear it through the house. Please help!
Apr 24, 2009 | Amana ASD2622HR Side by Side Refrigerator
Loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Dec 16, 2008 | KLH HTA-4906 System
JBL PB10 Subwoofer Logo
754 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
