My wii won't turn on. Every thing is plugged in, but it isn't working. The little light for power isn't on, and it usually is red when it is off and green when it is on but its just a black dot not lit up
Wii red light going batty flashing like every 1/3rd of a second, and it will not turn on. I FIXED MINE BY UNPLUGGING EVERYTHNIG CARDS, CABLES, FROM EVERYWHERE, AND REMOVE SDCARDS ALSO, AND DISCS, BOTH GC & WII CARDS, SENSOR BAR PLUG, POWER Plug *ALL THAT'S PLUGGED OR INSERTED... Now i plugged everything back in ACCEPT Not Sensor PLUG To back of wii, then the light quit (This is after 4 min break all undone...) And then plugged the Sensor plug and THEN as i finally plugged in the POWER Plug I first held the SYNC red button on the Wii, and then plugged it in and WAH-LAH Isue Resolved Immediately, KUDOS for the hints Cheerz & Peace Love Banish Fear/ hate to not even give it thought in root thoughtfulness.!. www.fb.com/stanleydeanparker/
U check the power sourced like the other equipments that plug into that a/c power outlet work?Yes,than tries tv unplug,replug it back like about an hour later by letting the tv to do a resetting itself back to the factory setting.The tv now it should be working again.If the tv still have the same result?Yes,than the tv have a power supply board it is dead.That the board where the power a/c cord plug into it.U have some basic mechanical skills like take things aparts and putting it back togther again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power suppy board for the replacement.
If you plug in your Wii and the power light ISN'T RED BEFORE YOU TURN IT ON
1 Disconnect everything
2 hold the power button down for 20-30sec
3 Plug everything back in
4 The power button should be red
5 Press it
6 It should be on
7 If not you have power supply problems and need to get a new one
Thank you for your time, Good luck and I hope this works
Turn on the Wii console, when at the home screen press any button on the wii remote, if the lights on the wii remote remain dark then it needs new batteries.
If the lights all light up at the same time then stop this means you are not synced. Press the 1 and 2 buttons at the same time to sync, this will work if they have been synced before.
If your four lights still blink blue then you need to open the little compartment on the console that is right below the disc tray. Inside is a little red button, press the button. Now open your battery compartment on the wii remote and take out the battery, then press the red button inside. Put the battery back in and the controller should sync up. If you are still having trouble you will need to contact Nintenedo Technical Support.
im guessing your wii is fried i would send it in for this is not a common thing. wiis ussually have proper airflow unless really surpressed. overheating is a common factor in consoles frying.
HI, Mine did the same thing. Open up the small door where you put a memory card and push the red reset button. That may help to clear it. If it doesn't work then the best thing is to have it looked at.
Usually, after a power outage, a power spike (when the power returns) can disable/blow the fuse in the AC adapter for the Wii.
Try the following steps in this order:
FIRST:
- unplug the Wii's power cord from the wall, and leave it unplugged (from 5 mins. to 5 hours). Then, plug it back into the wall. (Unplugging the power cord from the back of the Wii will not help. You need to unplug the power cord from the wall.)
- This usually helps reset the fuse circuit in the AC adapter, and your Wii should work again.
SECOND:
- open the panel on the AC adapter box in the power cord; since the screws are proprietary, you will need to creatively use existing tools to turn the screws
- check the 3A fuse in that box; if it looks blown, then replace it
THIRD:
- it might be cheaper to replace the AC adapter with another one
FOURTH:
- get the unit repaired
MUST DO:
- buy a SURGE PROTECTOR power bar, and plug all of your expensive items into it (to prevent this from happening again).
According to Nintendo u can try this. 1. push the reset button and if that doesn't work unplug all cords and memory cards (including sd) from wii and unplug av from the wii and the outlet in wall. Wait 2-3 min and then plug it back in. Thats as far as i got because that fixed my problem hope this helps someone!!!
