Question about Pacific Image Electronics Memor-ease Digital Film Converter
Capture image error . okease restart CyberView CS. If you still have problems , restart your computer . (112 : ) I've gotten this message for 2 days now. I have restarted CyberView, I've restarted the computer, I've uninstalled and reinstalled CyberView. The program worked for 1 day and did 4 slides yesterday and now this message comes up and I don't know what to do. The office is closed for the holiday and I won't get help until Monday (if we decide to keep the scanner that long)
4 Suggested Answers
  • 20 Answers
SOURCE: Unreconizable image
Try updating your scanner driver/software to isolate the problem. If same issue still occurring after uninstalling/reinstall, then source of the problem may be a CCD/lamp failure or some sort of dust, lint, on CCD causing calibration failure.
Posted on Sep 03, 2007
  • 154 Answers
SOURCE: Computer can't communicate with scanner.
Go to START menu click on devices and printer, then locate and click on add device, and follow the instructions.
Hope this helps you
Posted on Apr 09, 2010
SOURCE: The software cannot communicate with the scanner (Prime Film 3600
I have a PrimeFilm 1800u. When I attempt to scan into a Roxio application, the program does not respond. The hardware and software are both installed. No problems scanning or communicating with this scanner before. Is there somethere there that has a soultionfor this problem ? Thanks
Posted on Jan 16, 2011
Cyberview cs memor-ease unable to connect to pc
Try a connecting it to a different port on the computer. Make sure the computer can see a different device on that port, so you know the port is ok. Then try a different cable.
Dec 21, 2013 | Pacific Image Electronics Memor-ease...
How to fix error code 2000-0142
Did you try booting your computer in Safe mode to check if you receive this error message?
1. Use F8 while restarting the computer.
2. Under Windows Advanced Boot Options select Safe mode and hit Enter.
Check if you receive this error message in Safe mode.
It seems like your drive might be corrupted. If your computer is still under warranty, I would suggest you to contact them to get a replacement. But before you contact them, let us see whether Check disk utility would make a way to boot windows succesfully or not.
If you've Windows Vista Operating System disc, then try running the check disk utility from Windows Recovery Environment.
1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
2. Press a key when you are prompted.
3. Select a language, a time, a currency, a keyboard or an input method, and then click Next.
4. Click Repair your computer.
5. Click the operating system that you want to repair, and then click Next.
6. In the System Recovery Options dialog box, click Command Prompt.
7. Type the following command and press enter.
Chkdsk /r
Once your machine has finished repairing the hard drive, type EXIT and press ENTER to restart your laptop.
You can also try typing the following command if Check disk fails to fix the issue. At the same command prompt, type fixboot and press enter.
For your information: If you've a Dell Laptop, then according to Dell, the error code 2000-0142 is a Drive Self Test failed error code. Visit the link below:http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&dl=false&l=en&s=dhs&docid=14B3819735D6B40EE0401E0A55177ED2&doclang=en#HDD
hope 2 help
http://www.bostonrecycling.net/
Jun 18, 2012 | Dell Inspiron 1525 Laptop
I have installed HP PHoto and Imaging Softward for ScanJet 3570c 48 bit. Everytime I try to click on icons on the scanner, my computer shows an error message that there is a problem with connecting to the...
Does the same error occur if you launch a scan from the computer? What OS do you have? Vista only has a basic driver available and does not support the scanner buttons. (You can launch the scans from a number of options: third-party software, Windows Fax and Scan (new scan), Microsoft Paint (File > Import from Scanner or Camera > New Scan) and Windows Photo Gallery.)
If the error occurs when you launch the scan from the computer, try a new data cable and different USB ports. Try a direct USB connection if you use a hub. Then check your USB ports and the drivers for the USB. (For Windows, look in the Device Manager. Start > Control Panel > System > Device Manager (exact directions will depend on the OS).
The HP Photo and Imaging software requires you to set the default scan destinations in the software before you can use the buttons on the scanner (for those OS/driver versions that support the feature). Always open the software and scan from the computer to see what the defaults will be. Each version of HP's imaging software set up these buttons differently; the help option is useful. Try Scan > Scan settings to find where to set the color and black & white destinations.
I hope this helps. If you add a comment with your OS and whether the computer can launch a scan, I'll provide additional help if I can.
(who inherited a scanner when a USB hub failure aggravated the original user into buying a new scanner thinking it was a scanner problem.)
Aug 12, 2011 | HP ScanJet 3570C Flatbed Scanner
I have format error on my cybershot camera. I need to access photoc on camera
The Camera may display the FORMAT Error if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the Camera. The maximum supported capacity and media used is Memory Stick Pro Duo with 1 or 2 GB.
If you've already captured the images in the Camera and the error message displays, then try to open different images captured in the Camera and check if the message appears for all the images.
If this happens with all the images, then remove and reinsert the MS (Memory Stick) in the Camera and check if it works. You may also try cleaning the MS terminals and also check if the Internal Memory of the Camera displays the error. If the issue persists, then insert the MS in the Computer slot and transfer all the images to the Computer. If the images appear normally in the Computer, then Format the media in the Camera. To Format the Memory Stick, select the Format option in the Memory Stick Tool Menu of the Camera. (Menu-->Setup-->Memory Stick Tool-->Format)
Formatting the MS will delete all the files saved.
Formatting the MS should resolve the issue.
Thanks for using FixYa.
Jan 18, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
It does not recognize my memorease digital slide scanner. I am using windows 7 and the lates drivers from Pacific Image and Adobe elemnts is supposed to see the slide scanner bbut doesn't
If your scanner is like mine, the software is defaulted to look for the OVT scanner. Go into properties and change the default to Cyberview CS Memor-ease.
Jan 15, 2010 | Office Equipment & Supplies
IScanner not communicating w/ PC
If your scanner is like mine the software comes defaulted to look for the OVT Scanner. Go into properties and change the scanner default to Cyberview CS Memor-ease.
Dec 30, 2009 | Pacific Image Electronics Memor-ease...
When I turn on Dell Inspiration 1525 laptop. after 2 minute it appear blue screen error and then restart the system.
As soon as you see your "wallpaper" on the Windows desktop, click Start.
Point to My Computer.
Click with the SECOND (usually the RIGHT) mouse-button on My Computer.
Click Properties.
Click Advanced.
Below Startup and Recover, click Settings.
Click to remove Automatically Restart.
Click OK.
Now, the next time that you see the "Blue Screen Of Death", what message _stays_ on the screen? Write it down. On another computer, do a Google-search for that string, and read what others have done when they have gotten the same error-message.
Oct 22, 2009 | Dell Inspiron 1525 Notebook
Small screen goes blank when I click on "Start Recording" and I get "record error" I am trying to record to hard drive folder
Disconnect your dazzle then connect it again at the back of your computer. Click on Start>Control panel>system>hardware>device manager>sound and video games controller> right click on video capture device and uninstall it. Restart your computer. Wait for the new hardware found message comes out and then open your IDVDR again and then do the advance mode. On step number1 choose capture source click the pull down arrow and then choose dvc 100. Turn the power on on your camcorder and run it. Make sure that the video image showed on your preview screen. Try record it again.
Sep 28, 2009 | Pinnacle Dazzle DVD Recorder
Failure to communicate with scanner (Primefilm 1800u)
1. Start -> Click Run
2. Enter msconfig and click ok
3. Click Startup tab
4. Uncheck program that you don't want to startup
You can disable programs that you don't want automatically load when you start your computer. By disabling these programs will help your computer startup faster.
5. Click Ok and restart
Now you should notice that your computer startup faster.
My Hot Tips to Make Your Computer Faster:
* Regularly check your startup folder to prevent malicious programs installed itself without your knowledge.
* Delete the temporary files from Temp folder (Start > Run > %temp% > delete all files).
* Upgrade your RAM to makes your computer boot faster : )
I hope this article can helps you to make your computer faster..
Aug 27, 2009 | Pacific Image PrimeFilm 1800u Film Scanner...
Cannot capture image
TRY REPLACING YOUR MEMORY CARD
Sep 17, 2007 | Cameras
Pacific Image Electronics Memor-ease Digital Film Converter Logo
112 people viewed this question
Top Pacific Image Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Gene Tuck
Are you a Pacific Image Office Equipment and Supply Expert? Answer questions, earn points and help others
