Question about Hotpoint Refrigerators
Have temp gage almost to 9 (per instructions to make warmer ) but still at 33 degrees F. need to make warmer
  • 101 Answers
The freezer cools the fridge side so if you open the air flow up going in to the fridge it will only get colder. so cut the air flow down low and it should warm up. this causes the freezer to get cold quicker too because there is more cold air available in the freezer so it cuts off the compressor sooner.
think about how it works. if you doing everything right then you need to listen to be sure the stat is cycling the compressor or does it never get cut off by the stat.
Posted on Jan 01, 2011
I have a 2001 dakota that is overheating. put in new thermostat, didnt help. put in new water pump, still overheating. finally replaced the radiator. still is overheating. what else can I do to fix it
Sometimes when you open cooling system, air gets in, it can cause problems with temp gage.
How hot does it get in degrees F? Is the coolant boiling over? Are you losing coolant? Use a non-contact infra red temp gun to take engine temp, At least we will have a degrees F reading. Most temp gages say hi or lo, cold or hot. I don't know about yours?
Can you check for combustion gases in the coolant?
Mar 18, 2017 | 2001 Dodge Dakota
HOW TOIncrease refrig side temp IN mODEL795.5137
Have you tried reading the user instruction manual page 17? Click HERE 795.5137 User Manual
APPLIANCE 911
Nov 16, 2015 | Refrigerators
My dyson won't turn on. In the section for the speed of fan is showing the number 33.
Hi Deborah, it's Jack at Dyson.
It's likely the '33' you see displayed on your machine is the target temperature you've selected, as the fan speed goes from 1-10.
If you've selected 33 degrees as the target, your heater will only activate if the ambient room temperature drops below 33 degrees. It would then continue to run until the temperature reaches 33 degrees once again. The intelligent thermostat is engineered to heat the room to the desired temperature, then to run as needed to maintain this temperature.
If you want the heater function to run, try increasing the target temperature degree by degree until the machine comes on. But if you want to use the fan-only function in warmer weather, turn the target temperature down to 0. The LED indicator around the on/off switch will turn blue, and the machine will run in fan-only mode to cool you down with unheated airflow.
I hope this information helps. If you'd like further help or advice from our experts, you're welcome to call the Dyson Customer Helpline directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jul 18, 2015 | Dyson AM04 Hot Cool Fan Heater White
2006 chevrolet equinox over heating
How hot is the engine in degrees F? Are there any overheating issues besides temp gage? You may need to double check temp gage? If it is overheating, could be number of issues, some possibilities, thermostat--radiator fan--radiator--water pump. Also, you may need to check for combustion gases in the coolant? Are you losing coolant?
Nov 17, 2014 | Cars & Trucks
I need a new battery for my 1986 Oldsmobile ninety-eight regancy sedan. fully loaded. what type of battery would i need?
Attributes Battery BCI # : 75
Battery CA @ 32 Degrees F : 775
Battery CCA @ 0 Degrees F : 630
Battery Height : 7 1/4"
Battery Length : 9 3/4"
Battery Posts Type : Side Post
Battery Reserve Capacity : 90
Battery Voltage : 12 volt
Battery Weight : 33 lbs.
Battery Width : 7"
Wet or Dry : Wet
A lead acid battery with the fallowing specs
group 75
Battery Width : 7"
Wet or Dry : Wet
Battery Width : 7"
Wet or Dry : Wet
Battery BCI # : 75
Battery Width : 7"
Wet or Dry : Wet
Feb 27, 2011 | 1986 Oldsmobile Regency
What temp for turkey done ?
Always use an oven bag is used to promote even cooking.
Microwave on MEDIUM (50% power) for 7 to 9 minutes per pound rotating dish every 15 minutes. Not recommended for turkey over 12 pounds
Use an instant-read thermometer after cooking. Turkey is done when thermometer reads 180 degrees to 185 degrees F for whole turkey or 170 degrees to 175 degrees F for turkey breast. Insert thermometer through **** in oven bag into inner thigh for whole turkey or into thickest part of breast for turkey breast.
For easy slicing, let stand 10 minutes after removing from microwave oven. To open, carefully cut or **** top of oven bag. NOTE Microwave directions were tested in 600 to 700-watt microwaves. Higher or lower wattage ovens may need adjustment in cooking times.
Nov 21, 2010 | Microwave Ovens
I have an 2008 Xciting 500 that will not start when it is below 40 degrees. Any solutions?
kymco 500 has no air temp sensor,ecu reads water temp for coldstart enrickment.a new sender wont fix it ether,sender needs to read 10 degrees warmer to start
Feb 21, 2010 | 2005 Kymco Xciting 500
My GE Profile Spectra oven is taking approximately 10-15 minutes to preheat to 350 degrees and does not seem to fully bake food as per instructions. It takes an extra 5 to 20 minutes to bake anything. ...
18 mins from room temp to 350 is factory standard,
you may need to calibrate the range, most now adays come factory set at -25 degrees for safety
depending on your model number in your instruction manuel should be a part about recalibrating it sounds like your about 25 degrees off
Oct 02, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Gage reads 10-50 degrees below actual tempiture
The needle on the dash gage can be pulled off and slipped back onto the stem of the gage. First get an accurate temp gage to be sure what the engine temp is operating at. Then remove the face of the dash gages and remove the needle and place it back onto the stem to reflect the current correct engine temp and you should be good.
Mar 11, 2009 | 2001 Ford F150 Styleside SuperCrew
I can't find anything in the instructions on the length of time it would take to cook a turkey. Only the temp. of he meat
This may be too late, but you can generally figure on about 20 minutes per pound at a grill temperature of around 300 degrees. This is where a good instant read meat thermometer is your best friend. Take the temp in the deepest part of the breast and in the deepest part of the thigh starting at about the 15 minutes per pound mark and then about every 15 minutes after that.
The reason you see so many comments on the temp of the bird rather than the cooking time is that some folks cook their birds at 200 - 225 degrees, and others at 275 - 300 degrees or even up to 325.
I cooked a 5.5 lb turkey breast yesterday and it was ready in about 90 minutes at about 300 degrees.
Good luck and good grilling!
Pat
Nov 27, 2008 | Grilling
Refrigerators Logo
48 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
