Question about Swatch Irony Chrono #YOS414G Watch for Men
Both the second hands are moving. how do you stop the one smaller, the one in the middle circle? PLEASE help! :D THANK YOU.
  • lessandrajoy Dec 31, 2010
    does the dial on the middle circle the one for seconds run continuously?
Why is my second hand not moving
THE watch is in stop watch mode (pause) , reset your side mounted post buttons to go to normal time
Sep 16, 2015 | Festina F16190/1 Chronograph Watch for Men
Hi i bought a new ikc1816. The prob that i face is that the "second" hand (longer one) when starts by pressing button "s1" the smaller hand on the above eye (i guess it is called 1/10th second hand) also...
this is a chronograph I think and what you are referring to as the long second hand is actually the chrono hand the seconds hand is at 9 oclock on this model and the smaller hand that is moving simultanusly is actually the chrono revolution counter
May 08, 2014 | Kenneth Cole Watches
Please clarify use of the 3 smaller dials and how the hands to each are set and reset
The small bottom dial is seconds counter and there is no option to set or reset it as it is part of the main gear train - it just counts the seconds. Top right dial is 1/10 seconds counter and runs only when the chronograph function is engaged. One full circle indicates 1 second. Top left dial is 30 minutes counter and runs only when the chronograph function is engaged. One full circle indicates 30 minutes, two circles = 1 hour. The big centre seconds hand is actually Chronograph hand and runs only when the chrono function is engaged. So, the chronograph hand and two top dials works all together when chrono function is engaged. To start chrono: push upper button once. To stop chrono: push upper button again (once). To return all hands to zero: push lower button once. There is another option: if you already stopped chrono by pushing upper button, but want to continue counting without returning hands to zero, push the upper button once more and the counting will start from the point where it stopped. You can repeat this as many as you wish - it will count on and on, till you will stop it and reset to zero. Fine tuning of chrono hands can be made by pulling the crown half way out and while leaving in this position pushing and holding one of the push buttons (which one - depends on movement caliber). Watch has an tachymeter function as well (big inner ring). Learn how to use it by browsing through my Tips and Tricks- it is explained there. Rate me, please.
Feb 28, 2011 | Calvin Klein K7547107 Celerity Watch for...
Jacques Lemans 5015B model, drop my watch on floor yesterday, 2
You need a hand alignment at the very least. Sounds like your sweep arm is getting stuck on other objects in the face.
Sep 26, 2009 | Jacques Lemans Watches
Not sure what parts should be moving on new Fossil Me1020 watch.
I have a Fossil Twist ME1011, basically the same idea behind the one you have. What happens is there is a weighted third-circle that is in the back of the watch behind the battery (you can't see it) that spins a spring (the spring is the bottom seethrough part that ISN"T moving!) the spring then moved the UPPER seethrough part, which in turn spins the second hand!
IF the second hand stops working, carefully take the back off the watch and you'll see the weighted third-circle that I was talking about. It should spin, and in the middle there is a tiny flat head screw. The screw can get loose, so gently tighten it and the second hand should work again!
May 30, 2009 | Fossil ME1020 watch
Stop Watch not resetting
pulling the crown out to position 2 and pressing button to zero it out one increment at a time is the way to do it do touch the watch hands. Works on fossil watches as well as tag watches
Aug 27, 2008 | Tag Heuer Kirium Ti5 CL1181.FT6000 Wrist...
Rolex Daytona Chromograph
ok. bear with me. lol. on most watches without a chronograph. the second is the largest hand on the watch and naturally that's what most people refer to as the second hand. On a chronograph the "true" second hand is the little middle dial. It should always be constantly moving and the large hand should only move when the stop watch funtion is in play. The way to employ the stopwatch funtion is by unscrewing both buttons. The top button starts the action. Once pressed then large hand will begin. The little dial on you left will keep up with each minute that passes. To stop the function, press the top button again. To reset the stop watch, press the bottom button. The little dial on your right is simply military time. Hope that helps. Good luck!!
Apr 26, 2008 | Rolex Daytona 116520 Wrist Watch
Set?
Press Both side buttons at the same time. This should reset the hours and minute mini-circles. Then use the top button to "start" the second hand moving again. press it again to stop the second hand. I'm unaware as to how to restart the bottom seconds circle.
Dec 03, 2007 | Fossil FS2920 Wrist Watch
Sweep 2nd hand operation & watch time setting on my Pulsar watch.
The larger second hand on the Pulsar PF8036 is part of the stopwatch feature. The upper button starts/stops the stopwatch feature, and the lower button operates the lap/reset function. Why they made the larger hand work only with the stopwatch instead of the smaller hand to the left is beyond me, but that's how it is designed.
Oct 09, 2007 | Watches
Swatch Irony Chrono #YOS414G Watch for Men Logo
213 people viewed this question
Top Swatch Watches Experts
Ansel Alberto
Ansel Alberto
Johannes van der Wel
Level 1 Expert
Are you a Swatch Watch Expert? Answer questions, earn points and help others
