Question about Insignia 5-Disc CD Changer with MP3 and WMA Playback
My Insignia 5-Disc CD Changer Player, IS-DA1802 will not eject the last disc in the unit?
SOURCE: Insignia DVD Player
Try hitting the "Lock" button on the remote. That solved the problem for us.
Posted on Jan 28, 2007
sandrew
  • 2961 Answers
SOURCE: Insignia DVD/Cassette combo player
I imagine you have checked the disk for scratches top and bottom, if so you can purchase a cd/dvd lens cleaner cdrom as the laser may need realigning and cleaning.
Posted on Sep 06, 2007
  • 14 Answers
SOURCE: Built-in DVD player
Are you trying to play DVD's you've made or copied yourself or new one's you buy from an actual distributor? Because sometimes self-ripped Cd's & DVD's won't play on a LOT of DVD players. Otherwise it's bad DVD player and you should go get it swapped out if it's not too late.
Posted on Mar 02, 2008
SOURCE: Insignia 5.1-Ch. Home Theater System w/5 disc changer
when I press dvd it msg comes on
Posted on Dec 23, 2008
  • 12 Answers
SOURCE: insignia dvd player saying no disc after trying to load w/ disc
have you tryed cleaning the lens and dvd?
Posted on Jun 04, 2009
Sony CDP-C910 will no longer play cds or eject changer cartridge
Mine did the same thing. My player was primarily used in the garage and the cold weather may have caused my player to do the same thing. I just fixed my player. I removed the top cover and looked at the CD in the play position. In the upper right corner from the CD, you will see a spindle motor with a belt on it. Gently spin the motor back and forth carefully with your finger. I rotated it a half-spin in either direction, careful not to dislodge the belt. When I turned the player back on, the mechanism operated as it normally would and began playing the disc. I was able to eject and reinsert the magazine without any issues, solving the problem. Hopefully that will work for you.
Dec 17, 2012 | Sony CDP-C910 10-Disc CD Changer
The system won't eject the CD changer.
You will need to reset your system.
Turn on the master unit and select the CD as your source. Open the door on the master unit to show all of the speaker numbers, here you will find a small pin hole next to the number 5 speaker. Use a small paper clip, unfold it and stick it into the reset hole. Hold the pin there for a minimum of 5 seconds until the clock starts to blink. Hit the time button seven times to get a solid time again. After turn on the master power and try the CD player again.
In my case the disc cartridge ejected when i was resetting the system.
Oct 26, 2010 | M&S Systems DMC1CD 6-Disc CD Changer
Cd error wont play or eject 3 of the cds in the 6
sorry unit is not servicable you can get a used one at many junkyards
Nov 12, 2009 | 2005 Dodge Grand Caravan
The 6 disc magazine will not eject -
Ok..just happened to me. I'm a tinkerer so it's assumed that everything is out of warranty. The low down and skinny is this. The last disc holder is stuck on the metal changer tab, preventing the magazine to eject. 1. Remove the six screws on the left and right sides. 2. Use a small flathead screwdriver to GENTLY pry off the front Alpine CHM-S620 plastic facia.\ 3. On both left and right sides, collapse and push in the rubber suspension mounts. 4. Carefully remove the vertical/horizontal mount springs. 5. Gently pull off the data cable ribbon. 6. Flip over the changer unit. Use a coathanger to gently push the cartridge back into magazine. **You may damage the cd and last holder. Small price to pay to get things back to working order though. You may also have to wiggle the last cd holder to get it over the metal lip. 7. Reassemble in reverse order. 8. Change out that last cd cartridge so it doesn't jam again. Good luck.
Sep 27, 2009 | Alpine CHM-S620 6-Disc CD Changer
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
CD ERROR DISPLAYS
CD Changers
E01:
E02:
E04:
upside down
WAIT:
Jun 14, 2009 | iLO CA3000V CD Player
Signal R-8
hold eject for more than 5 seconds on the changer
Jan 06, 2009 | JVC CH-X1100 12-Disc CD Changer
Cds Stuck in cd changer. stuck at no. 6.
i have a infiniti i-35 2002 and my cd player won't play or eject i was switching cd's on no. 4 and when it went in it got stuck inside it won't play no. 1thru6 are there any suggestions
Jun 16, 2006 | Bose Wave music system Multi-CD Changer...
Insignia 5-Disc CD Changer with MP3 and WMA Playback Logo
64 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Curt Larson
Level 1 Expert
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
