Question about Jensen Vm9214 Car Video Player
Will not play videos from my library on my windows media player when i save videos to a flash drive
How do i download music on my mp3 player?
How to Put Songs on Disney Mix Max
The Disney Mix Max portable media player is capable of playing audio files in the MP3 format. It can also play videos formatted as WMV and display photos formatted as JPEG. You can convert audio files into MP3 using the Disney Mix Max software -- Mix It Plug-in. The plug-in works with Windows Media Player 10. This software CD came with the player and is not available online. To download music to the device, you can use Windows Media Player 10 or Windows.
Things You'll Need:
* USB cable
* Mix It Plug-In installation CD
Instructions
Convert Non-MP3 Files
Install Mix It Plug-In. Insert the Mix It Plug-in installation CD into the computer's optical drive. Click "Install Mix It Plug-In" when prompted. If no screen opens, double-click on the "My Computer" icon. Double-click on the installation CD icon. Then double-click on the setup or installation file; this file is often formatted as EXE. Select to have the program saved to your desktop. Then double-click on the desktop icon -- "disneymixitplugin" to open the setup wizard. Click "Next" in the setup screen. Follow any additional setup prompts.
Open Windows Media Player 10 and create a playlist. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Open Mix It Plug-In. Select "Yes" when asked to save analysis information for your music files. The software will analyze each track's compatibility with the Disney Mix Max player.
Press "Go!" to start the conversion process. Once the process is complete, an inactive "Go!" will be displayed. All music that has been converted is still listed in your Windows Media Player 10 playlist. You are now ready to download music to the player using Windows Media Player.
Open Windows Media Player 10 on your computer.
Remove the USB jack cover located on the bottom of the Disney Mix Max. Insert the compatible end of the USB cable into the USB port on the Disney Mix Max. Insert the other end of the cable into the computer's USB port.
Click "Library" and click a playlist name. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Select the "Sync List" tab and choose "Sync List" from the menu.
Verify the items to be synced to the Mix Max, or right-click on a song title and select "Delete" to remove it. Click "Start Sync" to download music to the Mix Max.
Windows
Insert the USB cable to the Disney Mix Max USB jack. Connect the player to the computer with the USB cable.
Click on the desktop "Start" menu and choose "My Computer."
Double-click on the "Removable Disk" that corresponds with your connected device.
Drag songs saved on your computer with your mouse into the Removable Disk folder.
Tips & Warnings
If you converted files using the Mix It Plug-In, you will need to use Windows Media Player 10 to sync them to the player.
Mar 11, 2011 | Disney Mix Max Digital Media Player
How to put music on
http://www.p4c.philips.com/files/s/sa6045_37/sa6045_37_dfu_aen.pdf
Organize and transfer music and pictures with Windows Media Player11
4.1 About Windows Media Player 11
While your player will work with Windows Media Player 10, we suggest that you use
Windows Media Player 11 for a more enhanced media experience, both on the computer
and on your player.
Windows Media Player 11 is an all-in-one playback and recording program that lets you
play your CDs, rip CD tracks to your hard disk, transfer media files to your player, etc. This chapter describes the steps that you need to follow to successfully set up and transfer music and pictures to your player. For more information, see Windows Media Player Help on your computer or visit www.microsoft.com/windows/windowsmedia/player/faq/default.mspx
Important: Make sure that you have installed the Windows Media Player 11 software provided in the accompanying CD for music and picture transfer.
Although Windows Media Player also lets you transfer video files from your computer
to the player, please use the MediaConverter for Philips provided in the accompanying
CD for video transfers. For more information regarding transfer of videos, see 3.6
Transfer video.
4.2.1 Add music and picture files to Windows Media Player library
By default, Windows Media Player automatically loads all the music and picture files
stored in your My Music and My Pictures folders into the library. If you add new files to
these folders, they will also be automatically added to the library.
Add music and picture files that are stored elsewhere on your computer or
computer network
1 Select Start > All Programs > Windows Media Player to launch Windows Media
Player program.
2 Click the down arrow beneath the Library tab and select Add to Library ...
3 Click <<Advanced Options to expand the dialog box.
4 Click Add...
> Add folder dialog box appears.
5 Select a folder in which you have kept your music or picture files and click OK.
6 Return to Add to library dialog box and click OK.
> Windows Media Player will start scanning the folder and add available music or picture files
to the library.
7 Click Close when done.
Dec 28, 2010 | Philips GOGEAR SA6045 MP3 Player
I put my sd card into my pc and it comes up but i can not get my video to play on my media player.....how can i get it to play
Windows media player does not support all type of files to play. You can try to play those video in VLC player or follow the link & download the software then start set up. restart your system and play the video in Windows Media player.
http://ftp.freenet.de/pub/filepilot/windows/multim.../klcodec375f.exe
This is working like an engine. After install the software your Media player updated with some other time files. For exam: mp4,mpeg4,avi,mov etc type file can play via media player.
Waiting for your feed back.
Jan 31, 2010 | PNY 2GB microSD Memory Card
Cant play videos
save the movie file as an AVI(audio, video interlaced) file in a folder you can find in the computer hard drive. go to opal and the pc library click on the import media tab. go to the folders tab and find the folder with the AVI file. click the import media button and there should be a screen showing the pharase transfering all compatible media. the files should then be found in the opal pc library under video. click the file you wish to upload, then click on the transfer to device tab. it should then begin converting the file, which may take a while. after the conversion it should begin transfering the file to the player.
ENJOY!,
-Ninja Dude
Jan 12, 2010 | RCA OPAL M4001 MP3 Player
I have songs on a usb and I want to put these songs onto my windows media player library
plug in usb drive....open window media player...let it 'search' computer for music/media files...it will automatically add them to your library
Oct 15, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
On my windows media player the Audio noise i can here but i can not see no picture with any of my video's do you no how to fix it
try to update your video codecs, or update your media player online.i think that should soved the problem, if you dont know how to have that update, just try to install new player in your pc, other than windows media player, then you can play it to your media player. :)
Oct 04, 2009 | Sony 256MB Classic Violet Micro Vault USB...
My windows media player wont play movies
Try downloading VLC player, if this does not play your videos then it is your Drive that needs a driver update or has gone bad. If VLC player does play it or asks you to install mpeg2 codecs, then all you need to do is google "mpeg2 codec download for windows media player X" (X being the current version of WMplayer you are using). The reason behind this problem is that Windows media player does not come preloaded with a full library of codecs, there are packages of codecs that you can download such as divx codecs that will have the majority of commonly used video compression decompressors.
Jun 15, 2009 | Gateway Computers & Internet
HOW CAN I GET NEW MUSIC ON MY RCA M4002A MP3 PLAYER
Use Windows Media Player
The instructions in these pages, which are largely links, pertain to Windows Media Player 10 and 11 only.
Windows Media Player is made by Microsoft. The general help page for Windows Media Player is:
http://www.microsoft.com/windows/windowsmedia/default.mspx
Through this link, you can enter a variety of search terms that will help you find what you are looking for (exs.: “add files to my mp3 player”; “delete files from my mp3 player,” etc.)
Important Vocabulary:
The code word for “mp3 player” in Windows Media Player is “DEVICE” or “portable device”
The code word for adding files is “SYNC,” “syncing,” or “synchronizing”
The code word for copying files from CD is “RIP,” or “ripping”
The code word for files stored on both My Computer and my Mp3 player (when it is connected to the computer) is “LIBRARY”
To add files (SYNC) to your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/wmp10/harrison_wmp10.mspx
To add files (SYNC) to your mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/player/faq/sync.mspx
To delete files from your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0085.mspx#EDF
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
To copy (RIP) files from CD to Mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/getstarted/ripcd.mspx
To copy (RIP) files from CD to Mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/easystart/mp11guide.aspx#RippingCopySsongsfromCDstoYyourCcomputer
Dec 14, 2008 | Audio Players & Recorders
Saving my music
Windows media player is probably right because you have moved the music to another location. You might need to rebuild the library.
Use Windows Explorer to check that the music is on the new drive.
Can I also recommend downloading Winamp to play your music, It's free, sounds better and doesn't spy on you!
Oct 20, 2007 | SimpleTech Pininfarina 80GB External USB...
Jensen Vm9214 Car Video Player Logo
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
