Question about Refrigerators
Ge monagram refrigerator cannot set temp ups- set for 44 degrees, always ends up at33 or 32 in refrigre compartment
  • Refrigerators Master
  • 8,220 Answers
The weather is bad in the area I lost you in the chat. But I found you in the freebies. Now here is the links you will need:
Monogram service manual
Here is a videos that shows how to check the thermistors
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 31, 2010
Regulate the temperature on a GE Monagram refrigerator
will need to check ur temperature control switch and ur thermistors all of them in freezer and fridge, have u manually checked the air flow vent to see if it opens and closes ok
Feb 22, 2015 | GE Refrigerators
GE monogram refrigerator too cold
There is a balance between the freezer and fridge. Reduce the freezer temp and see what the fridge temp does. By reduce I
mean make the freezer warmer. If it is set too cold the fridge gets colder.
Nov 25, 2013 | GE Monogram ZISS480DRSS Stainless Steel
Hotpoint fridge freezer freezer ok but fridge not working temp is always 21 degrees tried to set to 4 degrees but just keeps going to 21 freezer is fine -22 degrees
Merv -
Most manufacturer's fridges are designed for 34 degrees F in the fresh food compartment and 0 degrees F in the freezer compartment. Setting the fresh food compartment to a value lower than 32 degrees will freeze any moisture in foods, fruits and vegetables and freeze water in juices and other beverages resulting in broken containers, exploding cans, etc.
What you need is another freezer. Trying to convert a refrigerator into a freezer is going to be very difficult - especially without ruining it.
Aug 09, 2010 | Hotpoint Refrigerators
Refrigerator will not hold temperature lower than 44 degrees!!
I bet it's a GE Monogram? I have the SAME problem. Our refrigerator is stuck at 44 degrees. It was stuck at 47 degrees, but after 6 visits from the repairman we now have it down to 44 degrees! At first we didn't realize how bad it was, and we were eating food that was making us sick! My daughter was admitted into the hospital from severe intestinal problems and without getting into details... this has cost her health, and tens of thousands in medical bills.
We have thrown out a ton of food. The repairman has replaced a bunch of parts including a fan, a thermostat, replaced a switch, cleaned, checked the gaskets, replaced a thermostat control device, and possibly other stuff as I can't keep track anymore. He's has been coming 2-3 times per week for the last 3 weeks. And now says the ONLY thing it can be is a "leak" in the copper line. Since it is a sealed system he has to tap the copper line with a valve to check the pressure, and that valve will always have to stay in place once it is tapped. And we will have to have the freon filled every so often because valves will slowly lose the freon over time.
This GE monogram is suppose to be a top of the line GE appliance. Our entire kitchen is GE Monogram, and we have had many many problems with most all of the appliances. The dishwasher was replaced at approx. 4 years due to over priced service calls, and super expensive parts. GE wanted close to $300 for an upper dishwasher rack. It was less expensive to buy a new one.
Don't these appliance manufacturer's get it? They may save money on the manufacturing side, however they lost a customer for life. Not only did they lose me, they lost my daughter, my son, and my grandson.
These GE appliances that are built to fail end up filling up our landfills. GE should be embarrassed.
Possibly have your repairman check the copper line for leaks? We're waiting to see today if that will work.
Apr 27, 2010 | Sub-Zero 650 / O Bottom Freezer...
Freezing problem in maytag frig
the probe from the temp panel is not sensing correct temp or the panel itself is bad...call a tech to check it out
Feb 04, 2010 | Refrigerators
GE Monigram Ref, main food comparment stuck at 25 degrees
is your damper door between the freezer and refrige compartments opening and closing as you adjust the temp settings,they can become stuck open by ice build up,defrost the damper door and see if it closes then
Jan 16, 2010 | Refrigerators
Vegetable and meat draws freezing everything temp@16 deg. f.
Turn your thermostat down. If all the rest of the food was even 45 degrees, it would be okay. The vetable and meat drawers will always be colder, so you set the level for the rest of the fridge at what is tolerable.
May 14, 2009 | GE Monogram Refrigerator Built-In...
GE Fridge: PSS26SGPA SS Model
CallMe-
Your "freezer" and "refridgerator" temps are not jumping back to 14 and 44 respectively. When you change temps, they both wait 3-5 seconds before they revert back to a temp reading, not a temp setting.
Does your "freezer" make any loud or thumping noises? If not, do you hear a quiet whisper when both compartment doors are closed?
Solutions could be :
1. Servicing the coolant (might have a small leak)
2. Checking the seal on your freezer compartment (black rubber that meets the metal frame)
3. Your internal cooling fan is not operating and needs replacing (but I think your temps would be significantly higher).
Best of luck.
Jul 28, 2008 | Refrigerators
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
