Question about Refrigerators
Hi just got a maytag GC2227 off ebay got it back home let it rest before turning it on when i did turn it on left it for couple of hours then checked and when i did noticed it wasnt getting cold the fridge and freezer seems to be blowing warm air can you help me please? thanx jennie
HVACRH20
  • 237 Answers
SOURCE: refrigerator and freezer
Does the compressor click on and off every minute or so and is hot? That would likely be tripping on a thermal overload due to not being able to start (bad motor starter on the compressor). If the compressor is running normally and warm then you may have a froze up coil. Take the lower rear back sheetmetal cover off the inside freezer section and look at the coil. If it's frozen block of ice basically the defrost cycle is not working and the ice has blocked the air flow through the unit. (could be bad defrost heater, defrost timer or defrost t-stat). If the compressor is running normally and warm and you see no ice or even frost on the coils then you have a sealed system problem that usually means most if not all of the refrigerant has leaked out of the system (or a blockage/restriction in the system). This would be the worst case since it means a whole bunch of money to repair. Let us know what you find out and we can have a better idea on what to recommend.
Posted on Nov 24, 2006
notsomot
  • 67 Answers
SOURCE: samsung fridge freezer not cold enough
Heya,
I did samsung warranty for awhile and these fridges have a faulty defrost termination clixon. What happens is when you turn off the fridge it turns it off defrost. If you do get a tech out there are two parts you need to fix it. One is a yellow sensor cable and the other is a defrost termination wire that is black and red. These two parts i use to sell for $70aus when the fridges where out of warrenty.
I actually have one of these fridges now and work so if you have any other problems please let me know
Regards Mat
Posted on Jan 08, 2009
Sea Breeze
  • 4654 Answers
SOURCE: hoypoint ffa9op.defrosted
Has the problem been slowly developing? Is fan inside freezer compartment running? Can you hear fan and compressor running below or behind refrigerator? Is there a collection of dust under and below refrigerator?
Below is a link with more Q&A Click on link and if you need me to assist you are welcome to let me know, Thanks, Sea Breeze
http://www.applianceaid.com/refrigerator.html#freezing
Posted on Feb 01, 2009
MNTECH
  • 1543 Answers
SOURCE: GE refrigerator 12 years old runs continuously, exterior warm
Probably not. Newer (and I mean under 15 years old or so) refrigerators may run more % of the time than older units, but are using far less energy while running, so total energy consumption is actually less. The newest energy star models often use less electricity than a single incandescent light bulb uses if left on 24/7. If your run times are noticeably longer just recently, and there have been no other significant changes to account for it (like more and / or longer door openings or a warmer ambient temp., etc.) then you may have caught a defrost problem or bad door gasket problem early. The warm temp on the outer case near the freezer is to prevent condensation from forming in those areas, and is normal. (as a matter of fact, older refrigs often used low wattage electric heaters for that task, almost all newer units use waste heat from the cooling system to accomplish that task) Please don't bother rating this solution, as anything but a Fix-Ya lowers my overall score. Thanks.
Posted on Feb 16, 2009
SolutionGuy
  • 331 Answers
SOURCE: Frost in frostless freezer, fan not blowing into warm fridge
There are 2 things that cause these to not defrost. Kinda like the "Achilles heel" of GE fridges. The first one is the Defrost heater itself. And the second is the evaporator thermister (GE calls it a "sensor"). They are both very easy to replace. The part numbers are; WR51X10101 (heater) and WR55X10025 (sensor). If you don't have a local appliance parts retailer, just plug those numbers into a search engine. I highly recommend getting both parts because if the sensor hasn't failed yet, it will. The same goes for the heater...
Now for the fun stuff... Turn the temp knobs all the way counter clockwise to kill power to the fridge. Unload all the food from the freezer and remove all the shelves and the basket. Remove the screws that are holding the evap panel (the flat panel on the back wall, it's about 2 1/2 ft tall). Remove the panel to expose the evaporator. You'll see the heater at the very bottom of the evap connected by 2 screws, remove these and pull the heater out. Your new heater comes with instructions on how to install it.
After you have done that, look at the top of the evap. On the left, you'll see a little white sensor clipped to one of the evap tubes (shiny little clip), that has 2 wires feeding it. Remember which tube it's clipped to then unclip the sensor and pull it toward you. Snip the wires right at the base of the old sensor and completely remove it (leave the wires in there). Now separate those 2 wires and strip about 3/8" of insulation off. At this point, you are ready to follow the instructions that came with your new "sensor". Oh! and if it's all frosted up on the evap? Take this time (before you re-install the panel) to use a blow dryer and melt it away. All that'll be left to do is rebuild it.
There ya go! Job completion time= ~45 minutes. Easy breezy, right?
If this has been helpful, please don't forget to rate my solution. Thanks!
SG
Posted on Apr 05, 2009
I have a Maytag GC2227 and it is tripping an RCD. If the fridge temperature setting is switched to off the RCD does not trip but as soon as the temperature setting is adjusted the RCD??
Refrigerators are never supposed to be on GFCI devices, they will tend to "leak" a bit of current to ground during defrost and "trip" when there is no real problem... You can test this theory by plugging the machine into a two-prong adapter to see if it still exhibits the same symptom, the only problem I have seen in home refrigerators that can trip a 20 amp circuit break is a seized compressor that is drawing "locked rotor amperage." By design, the start relay/overload should interrupt power before this happens... Hard Start Kit RCO410
Jul 04, 2016 | Maytag Refrigerators
Samsung rsh1nhmh fridge freezer not turning on and tripping electrics.
sounds like electrical fault within your freezer any small fault will throw your contact breakers on your consumer box without blowing the fuse in the appliances plug
Aug 30, 2015 | Samsung Refrigerators
Ice maker in Maytag French Door not working
replace the ice maker if the reset button has not done any good
Sep 16, 2009 | Maytag 25 Cu. Ft. French Door Bottom...
My iphone wont turn on past the silver apple logo.
Open up iTunes, connect the iPhone. Hold down the power button for 3 seconds, hold both power button and home button for 10 seconds, release power button while still holding down the home button. This puts your iDevice into DFU mode, so it can be restored using iTunes.
Aug 09, 2009 | Apple iPhone Smartphone
Ford ranger 1987 problem with when turn on it
From 1986 thur 1995 Ford had problems with the TFI module over heating change it. Located on the bottom of the distributor.
Jun 16, 2009 | 1987 Ford Ranger
1990 Accord Lx 2.2 won't start. Cranks, but won't turn over
does the engine sound like it is turning over slow? It may be the starter dragging. If it doesn't turn over fast enough it won't crank.
Jan 24, 2009 | 1990 Honda Accord
Maytag side by side freezer ice build up
I HAVE A MSD2454GRW, 23.5 CU, MAYTAG AND ICE BUILDS UP ON THE FLOOR OF THE FREEZER TO A POINT WHERE IT RUNS ON THE FLOOR. CAN CLEAN IT OUT AND 12-15 HOURS LATER, ITS BACK.
Jul 20, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
RT2250 turns itself off
Are you trying to run this unit at 50% or more? I can understand this problem if that's the case. Just turn it down. If you need more "grunt", it's time for more power amping...accordianman
Feb 29, 2008 | RCA RT2500 System
ICE MAKER AND WATER SUPPLY DOES NOT WORK
I lifted the switch to turn ice maker off, left it like that for a couple of hours, then turned it back on. I checked it a couple of hours later....Making ice now....
Thanks pete5runner!!!
Feb 18, 2008 | Refrigerators
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
