Question about Garden
Corrosion of battery contacts occurs within of 6 months use!
  • 11,896 Answers
This is actually quite common. To help your chances of this, add an extra negative cable from battery to un unpainted or scraped surface of the metal body
Posted on Dec 31, 2010
96 Dodge Ram 1500, V8, 5.9L- Replaced alternator and battery, but battery drains within minutes of removing jumper cales
Disconnect the battery cables and inspect for contact corrosion, if present the alternator is not charging the car's battery because of a poor electrical cable connection. Next mix a solution of one part baking soda to three parts tap water and pour over both the cables and the battery contacts, allow the baking soda to dissolve the corrosion, once the fizzing has stopped, pour more tap water to clean remaining corrosion, dry with a paper towel and reconnect cables tightly to the battery.
Dec 22, 2013 | 1996 Dodge Ram 1500 Club Cab
Handset won't charge
Not using the handset for several months  would have allowed corrosion to develop on the charging contacts.  You have to use cotton buds and a strong solvent to clean the charging contacts.
Alternately, it may be that the battery is already dead and no longer would accept a charge.  These are plug-in types and are replaceable.  Incidentally, it is also possible that the corrosion developed on the battery connector contacts themselves.
Indication of corrosion would be dull colored contacts with bits of flakes - clean to make shiny again; the connector corrosion would be wet powdery greenish substance on the wires or connector from the battery.
Hope this be of some help/idea. Post back how things turned up or should you need additional information.
Good luck and kind regards.
Oct 26, 2007 | GE 25951EE2 Phone
Tip
Cleaning battery contacts to keep your laptops, portable dvd players, etc...
Cleaning battery contacts is an important general maintenance procedure and should be done about every 6 months. The following are some reasons why you should keep battery contacts clean. The steps provided in this tutorial applies to any battery operated device.
1. Cleaning the contacts keep the devices that use the batteries working properly.
2. Keeping the terminals/posts and contacts clean from corrosion can help extend the life of the battery, especially rechargeable ones.
3. Keeping the contacts clean will save you a lot of time and money in the long run.
Battery contacts come in different shapes, sizes, configurations, and are made from different materials. The following picture shows you some examples:
Example of a spring end of a battery contact:
Keeping rechargeable batteries and the contacts clean can extend the life expectancy of the batteries and keeps the device operating properly. The following is a chart that demonstrates the life expectancy for lithium-ion rechargeable batteries commonly used in laptops:
Picture of a laptop battery and it's contacts:
If batteries and the contacts become dirty or build up corrosion, the battery can no longer make a proper contact. This causes the battery to loose their charge faster and also prevent the device from receiving the proper voltage and prevent it from operating properly.
You can purchase products to help clean the batteries or contacts. The following shows you some examples of a battery cleaning product and a battery contact cleaning pencil. You can actually use a regular pencil eraser to clean battery contacts if you want.
Battery contact cleaning pencil:
Cleaning steps:
1. Make sure you have the proper tools you might need to access the batteries or contacts. Wearing gloves and eye protection is always a good safety precaution when handling batteries.
2. Make sure you have a flat, clean surface to work on with adequate lighting.
3. Remove the device cover to the battery compartment and remove the battery.
4. Check the batteries for burnt spots, leaking, bulging, cracks or breaks. If you see any of these, discard the battery because it will need to be completely replaced. These are indications that the battery is no longer serviceable and failure is imminent.
5. Check the contacts for any signs of damage such as breaks in the metal, broken springs (if applicable), etc. If any damage is found, replace the contacts before continuing to use the device.
6. Using the pencil eraser end, clean the tops and bottoms of the batteries (or if you have purchase a special battery cleaning product, follow the directions).
7. Next, tilt the device you are cleaning (if possible) so that any debris will not fall further into the device. Take the pencil and clean the contacts in an outward motion to help sweep dirt, corrosion, etc away from the device. You can use a small keyboard vacuum to help clean the inside of the battery compartment also.
8. If the pencil eraser is not cleaning the contacts due to large amounts of corrosion, you can use a small piece of metal (this should be the last resort). You gently scrape away any corrosion or packed on debris from the contacts. Exercise extreme caution to not damage the contacts by severely scratching or breaking them.
9. If you are cleaning a 12 volt car battery, you can apply the same measures as mentioned. If you are having trouble removing debris, you can use a wire brush to gently remove it.
10. You can now replace the batteries into the compartment and replace the device cover.
CAUTION: It is not advisable to use chemical cleaning solutions on batteries.
Following these steps and regular preventative maintenance on your batteries and device can help ensure a longer life expectancy for the batteries and longer use of your product.
on Feb 04, 2010 | Computers & Internet
Kodak easyshare m753 will not turn on, i have new wall charger and battery i just purchased and camera was not working before this only because i had to buy charger so the camera sat for about 6 months but...
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries, place them back in the camera and give them a good charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Dec 07, 2009 | Cameras
I can't get my t1031 digital camera to turn on. Battery is fully charged. Please help! I've had the camera for a year but it hasn't worked for at least 6 months of that time.
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Nov 27, 2009 | Polaroid t1031 Digital Camera
I have had this camera for a year and a half, and
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Nov 07, 2009 | Polaroid i633 Digital Camera
I have had my camera for just over 2 years.over the last 6 months i have had problems with the battery side. i have used the correct batteries, within 10 minutes the camera drains batteries with occasional...
Oct 25, 2009 | Kodak EasyShare C633 Digital Camera
Cant click with Flash on
Your problem may be due to corrosion on the contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries are just too worn to handle the task anymore.
Sep 27, 2009 | Canon PowerShot A700 Digital Camera
'05 mazda 6 will not start with new battery
Make sure connection for thick red wire going to starter is good if you had that much corrosion.
Jul 25, 2009 | 2006 Mazda 6
Charge can't keen on more than 5/6 hours
first, check your battery in other mobile phone.
then if this batttery have same problem then connect me.
Nov 22, 2007 | GPS
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
