Question about Denon AVR-1601 Receiver
My mac is hooked up to my receiver via analog cables. I have never had any problems, but now for some reason when in stereo mode I only get sound out of the right speaker. I'm only looking for 2.1 sound obviously. When I change the surround modes the majority of them have no left channel. Virtual mode does have both for some reason. How do I get regular 2.1 Stereo sound back? (I have a 18 month old daughter that may have button mashed the receiver)
    President:
  • 1,851 Answers
The most common problem at cases like yours is the jack to RCA cable that connects your mac to the Denon amplifier. This is a cable like this:
Usually there is an internal cut at one of the ends. Check this cable and in case of a problem replace it; it's very cheap. A quick test is to reverse the RCA jacks at the amplifier's side; if you get sound from the left speaker you can be sure that one channel of the cable is faulty. At the "virtual mode" your system is trying to create a stereo image so it's logical to have "pseudo" audio from the left speaker.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on Dec 31, 2010
  • 125 Answers
Try review the manual
Posted on Jan 01, 2011
For some reason our multizonede non isnt' working when we are in cable tv mode
is your cable hooked up via hmdi cable? the zone 2 will only work with an analog signal
Aug 25, 2014 | Denon AVR-2113CI Receiver
Yamaha eq70 hook up to yamaha rxv-2600 tried to hook to tape connections do not have main in hook up do have the preout on back of rec help me
The following is some boilerplate I made up that should explain some usage limitations.
Be advised that the engagement of any device in a Tape Monitor loop on a late-model Audio/Video Receiver will effectively tie the receiver down to stereo-only analog sound reproduction. I'll explain.
The connections themselves are fairly simple but it pays to understand what happens in the loop.
In general, any Line-Level external processor (EQ, dynamic range expander, etc) will go into a Tape Monitor loop on a receiver. A Tape Monitor, when engaged, sends the stereo analog signal Out to the Processor, massages it and returns it to the receiver via the Tape Monitor IN connectors to be passed on to the receiver's internal processes (volume, tone, whatever).
Old school analog stereo-only receivers consistently work this way. Newer digital and audio/video receivers introduce a couple of problems: 1) digital sound processing to simulate a variety of soundfields; 2) multiple output channels, either discrete or digitally-generated.
The latter requires that whatever signal is being processed experiences a maximum of one analog-digital-analog conversion.
EVERYTHING analog coming into the modern digital receiver is automatically converted to a digital signal for internal processing unless you choose a STEREO-only or STEREO-Direct setting. Consequently, no further external analog-digital conversions would be allowed if, say, a Tape Monitor circuit was activated, and a possible feedback loop could otherwise be created in a digital-sourced selection (output to its own input), so the unit is wired to treat the Tape Monitor as the first analog step in the process and defeats any pure digital sources.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? They would NOT be processed. That logical problem also plays into the decision to defeat digital sources if the Tape Monitor is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast.
Okay, back to the hook-up:
You have to select any available 'tape loop' containing an overrideable analog 2-channel Out and In. That would be MD Tape, CD-R, VCR1 or DVR/VCR2 in your case.
Receiver Tape Out (Rec) - to the External Processor (EQ, whatever) Preamp-, Rec, Line-In;
Receiver Tape In (Play) - from the External Processor (EQ, whatever) Preamp-, Play , Line-Out.
So, to sum up, you can only use the EQ or any outboard processor for analog stereo sources. If you actually want to use an analog recording deck you could place it within the typical Equalizer
Feb 12, 2011 | Yamaha EQ-70 Home Equalizer
All speakers work on sound level test but i have no music coming from rear, center and sub when playing 5.1 dvd. also i am unable to use any of the surrond sound modes. richard
What cable did you hook up your dvd? The 5.1 sound works only with optical cable or HDMI. Check in the input settings wich one is selected. With the analog cable ( Stereo RCA) is not working. Good luck!
Jan 29, 2011 | NAD T762 Receiver
Need to hook up a Realistic model 31-2000 equalizer to a Yahama receiver.
Okay, back to the hook-up: Receiver Tape- or VCR Out to the External Processor (EQ, whatever) Preamp-, Amp-, Tape- or Rec-In; Receiver Tape- or VCR In from the External Processor (EQ, whatever) Preamp-, Amp-, Tape- or Rec-Out.
So, to sum up, you can only use the EQ for analog stereo sources. If you actually want to use an analog recording deck you could place it within the typical Equalizer's own Tape Monitor loop(s). Many have two to facilitate equalized dubbing between decks.
[Or you could obtain a dbx Program Route Selector (check eBay, I highly recommend the 400x, of which I have two) and it would, while only using one receiver Tape Loop, allow for three discrete attachment paths for processors and three for tape decks with the added flexibility of front-panel selection of any and all, with the processors being before, after or between the source or tape decks. Plus it has a dedicated facility for an inline dbx Noise Reduction Processor that can also be juggled around via pushbuttons. Pretty neat.]
Jan 17, 2011 | Audio Players & Recorders
I have Arcam Receiver AVR 300. I bought it used a few months ago and the receiver had worked like a dream. Suddenly, for no apparent reason, there was no sound from the SAT channel/output where the...
Seems you set it to "Stereo Direct" mode. This is an analog only mode, while you are using a digital signal. You can change this with the mode button.
Press menu, on the main menu screen 1, scroll down to stereo direct. Turn this OFF.
This should solve your issue!
~KenjiFox
Jan 07, 2011 | Arcam AVR-200 Receiver
No analog comming out of receiver when optical input is used .
as a rule...in order to get analog audio out of a receiver, it must have an analog input. you could use a digital to analog converter between the tv and stereo or come out of both of your source devices (ps3, cable) with analog to the receiver. good luck
Feb 10, 2010 | Yamaha HTR-5740 Receiver
Screen stays in analog mode
analog usually means its hooked up via VGA cable
digital means its hooked up via DVI cable
Sep 04, 2009 | LG Flatron L1750S 17" LCD Monitor
Sound from reciever
LFE (ONE CABLE ON THE SUB TO SUB OUT ON AVR) OR stereo L/R analog cable from sub to tape in/or out on avr (depends on AVR) LFE connection the sub turns up with the AVR - the stereo cable threw tape in/out on AVR only turns up via its own onboard amp volume from AVR has no affect.
Aug 21, 2009 | Sony STR-DH700 A/V Receiver
Not reading digital sound, only analog
do you have the "B" speaker selector button pressed? i believe that it will only run in Stereo mode when running both at the same time.
Mar 01, 2009 | Yamaha RX-V2600 Receiver
BA735 no sound but sound card works in analog mode.
this should be pretty easy to diagnose. both speakers have mini jacks right? if so, and you plug one pair of speakers in on say, port "A" and you get sound then if you plug your other speakers in on port "A" and you don't get any sound, the problem is with your speakers.
Oct 19, 2008 | Boston Acoustics BA735 Computer Speakers
Denon AVR-1601 Receiver Logo
124 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
