Question about GE Dryers
Ge Profile dryer don't heat in any cycle. - GE Dryers
  • 11,896 Answers
Either the heating element has failed, or there is a block in the venting causing no heat or the flap that closed to heat and opens to cool is stuck open allowing all heat to escape.
Posted on Dec 31, 2010
Ge profile dryer does not heat at times
Sounds like one of two things.
1) you have a bad connection, specifically, a loose connection that is making contact once in a while.
2) one of the "overheat thermostat switches" is failing.
If you wish to fix it yourself, you will need to dismantle the machine and have a testing instrument to look for the problems.
Be advised, however, if you take it all apart and it happens to be on a "I will be working now, thank you very much" cycle, you may not find anything!
It really needs to be "not working" for the flaw to show up.
Be blessed.
Feb 22, 2013 | GE Profile Harmony DPGT750EC Electric...
GE profile Mod DPSR610G0WT dryer shuts off multiple times during drying cycle, need to wait about 5 mins, then restart; have partially dismantled to vacuum lint around drum and controls
you need to check the thermostats,, they have limits that are preset , The cycle selected determines which thermostat is used. A cycling thermostat can be found somewhere in the path of air that is leaving the drum. It could be found on the blower wheel housing or inside the venting/exhaust system. Dryer thermostats are usually oval shaped and about an inch and a half in length. Also, there should be two wires leading to each thermostat. Label these wires before you remove them so that you are able to correctly reconnect them later.Set your multimeter to the R X 1 setting. Take each of your meter's probes and touch one to each terminal. You are testing for continuity, and you should receive a reading of either zero or infinity. At room temperature, testing the thermostat should produce a reading of zero. But if a thermostat is tested when it is heated to its limit, a reading of infinity should be produced. if you don't have a meter, consult someone with one or call a repairman
Jul 04, 2011 | GE Profile DPSB619ED Electric Dryer
Blower does not blow on profile dryer GE Profile dryer drum turns heats but does not dry
the clip that holds the fan on the back shaft of the motor may have broken so the fan isn't turning, check that , but first check the duct and make sure that you don't have a ball of lint clogging the vent,, also check the venting all the way out of the house,, clean the overhang of the outside vent cover, they get moist and collect lint
Jun 21, 2011 | GE Profile DPSB620GCWW Gas Dryer
GE Profile gas dryer won't ignite
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 01, 2010 | GE Profile DPXH46EAWW Gas Dryer
GE profile harmony dryer electric won't heat after first load
Did you end up replacing this thermistor? If so did that solve the problem? We are having the same issue and I don't want to waste time and $$.
Dec 22, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Profile Dryer. Sometimes fails to heat or just air dries.
Cold solder joints on blower motor coils. Needs re-soldered. I suggest finding a buddy who knows how to take the dryer apart and knows how to solder. Luckily for me, I know how to do all of that, I had the same problem you have.
Oct 19, 2009 | GE Profile Harmony DPGT750EC Electric...
GE DPSB620ECWW dryer tumbling, air blowing out, but no heat. How do I check which part is bad?
open up dryer, temporarily jumper wire the hi-limit switch, the thermal fuse and the cycling switches or check them with a multi-tester
Aug 29, 2009 | GE Profile DPSB620ECWW Electric Dryer
DescrI have a GE profile harmony electric dryer model #dpgt750ec1pl. About 5 minutes into a drying cycle the blower shuts down. There is still heat but no air coming out of the dryer duct. Any suggestions?...
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony Gas Dryer DPGT750GC1PL not heating
post your email i will send you the book there are too many things to check via posting here
Mar 09, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
66 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
