Question about Microsoft Xbox 360 Console
Ok my xbox disc drive isn't reading discs ive opened it up cleaned all dust off rails lens etc. but is making no difference whatsoever. if i replace the drive do i need to switch the original board on to the drive?
    Problem Solver:
  • 10 Answers
I have the same problem with mine, this is what i do
Lightly slap the top of the system while it is reading the disk and it takes a few trys for it to work, dont hit it too soft also
Posted on Dec 31, 2010
Everything on my Xbox 360 works, but it won't read my games,movies or cds? Its sounds like it going to work then it trys to read the disc and then it goes to open tray.!!!!!!! Its only 6 months old and...
hey man this is a disc drive problem but its very simple to fix.only thing is you'll need to disassemble your console and take the case off your disc drive. it will void warranty. its very easy to fix, not worth sending back to MS and get charged money. has worked on 3 out of the 3 xboxes ive seen with open tray errors. all had BenQ drive. good luck.">
Sep 19, 2010 | Microsoft Xbox 360 Console
Xbox wont read disk
HI,
Did you try using different disks?If you have alreay tried then please use lens cleaner to clean the lens
Sep 06, 2008 | Microsoft Xbox 360 Console
Wont play game disc
What disc are you putting in?
Mar 19, 2008 | Microsoft Xbox 360 Console
I think my lens is weak, the cd has to be ejected and inserted a couple of times before it works
Like any system, Xbox consoles require occasional cleaning to remain in peak condition. If you're experiencing skipping, poor sound quality, increased loading time, or any number of technical annoyances, simply cleaning your Xbox lens may correct the problem. The lens is responsible for reading all the data on your Xbox game discs; it is the most important part of the entire system. Cleaning the lens takes only a few minutes with the right cleaning product and know-how.
Difficulty: Easy
Instructions
Things You'll Need:
* CD lens cleaning disc
1.Purchase a CD lens cleaning disc. It is important that you buy a lens cleaner for a CD player, not a DVD player. Classic Xbox consoles are not DVD compatible, but they can play CDs. Some lens cleaning discs are marketed specifically as Xbox 360 cleaners, but these may not work in an original Xbox if the disc is DVD-formatted.
2.Turn on your television and Xbox just like you normally would to play a video game.
3.Open your Xbox's disc drive, placing the lens cleaning disc in the drive face-up. A lens cleaning disc works by sweeping small brushes over the laser lens surface. These brushes are located on the bottom of the disc; be careful not to touch the brushes---the microfiber brushes are delicate and can become damaged easily.
4.Close the Xbox and let the machine power up; make sure your television's volume is turned on. Your Xbox should automatically take you to the system's standard CD player menu. If this does not happen, select the menu manually using your Xbox controller.
5.Begin playing the first track of the cleaning disc. Listen carefully, because audio directions will play indicating the steps necessary for properly using your cleaning disc. Each brand of lens cleaning disc will have different steps, but they are typically very simple, involving tasks like skipping ahead to different tracks or briefly putting the CD in fast forward mode. If you cannot hear the audio directions, consult the written instructions packaged with the disc.
6.Remove the cleaning CD after you've followed the audio directions---a typical cleaning cycle only takes a few minutes, and the audio directions will tell you when cleaning is complete.
7.Carefully place the lens cleaning disc back in its case, avoiding damaging the brushes on the bottom. Lens cleaners can be used multiple times, so plan on using the cleaning disc regularly to help avoid future problems with your Xbox console
Aug 19, 2010 | Microsoft Xbox 360 Console
My xbox is not reading any games or dvds when i put a disk in it starts reading then comes up open try like the xbox thinks there is no disc in there at all
it sounds like your dvd drive lens is dirty or out of line without opening your machine the best bet is to buy a cd with tiny brushes on to clean any dust of lens if not you would have to open xbox to clean lens yourself i have plenty of experience with drives they can easily be damaged so get help if not sure.
Jun 20, 2010 | Microsoft Xbox 360 Elite Console - Black
Keeps saying open tray after reading disc
the lasers probably loosened up with the vibration. if its outa warranty take the disc drive apart and look for the tiny screws on the underneath of the rails the laser moves on. (the rails rest on the screws). tighten them a quarter turn at a time and test the xbox after each turn until it reads.
and to be on safe side give the laser a clean while your at it
hope that helps
Mar 13, 2010 | Microsoft Xbox 360 Console
It says the disc is unreadable and ive cleaned
Ok this worked on my mw2.
Take some toothpaste, a soft cloth.
wet the dist then dab a small amount on the game disk. (NOTE!!) STREAK OUTWARS TO THE EDGE NOT IN CIRCLE IF YOU DO NOT DO THIS IT WILL MAKE IT WORSE!.
after youve done this wash and repeat 10-15 times (note) it will take about an half an hr if you do it properly.
Dec 31, 2009 | Microsoft Xbox Console
Xbox 360 open tray error apears to be a dirty laser. how do you clean it ?
Go to the electronics section of Wal-Mart, Target, etc. and buy a laser lens cleaner. They typically cost 15-20 dollars.
They will come with specific instructions, but typically you:
1) Insert the disc into the disc drive
2) Have the disc drive read a particular track on the disc, so that the soft brushes attached to the underside of the disc can clean the laser lens.
Some people attempt to clean a laser lens by lightly wiping it with a Q-tip soaked in rubbing alcohol. This is NOT a good method because of the high probability that you will either scratch the lens or leave some cotton on the lens making your problem worse.
Nov 14, 2009 | Microsoft Xbox 360 Console
My xbox 360 elite wont read games or dvds. it says reading then open tray. the only way i have been able to get my games to work is by tapping it above the disc drive when i first insert the disc. my...
Open up the DVD drive, clean the laser lens with a Qtip and alcohol, push the laser lens cradle next to the center (spinner) and lastly dust off the insides of the console. This works all the time. I've done this more than 10 times on different consoles.
Oct 03, 2009 | Microsoft Xbox 360 Elite Console
My game wont read on my xbox 360
I believe you can use a DVD cleaner without voiding your warrenty. If you have a warrenty then call Xbox tech support to get it fixed. And if you don't buy an extended warrenty for $50 and then call them and tell them you need your Xbox fixed
steps to be followed.
  1. step 1 Purchase a DVD lens cleaning disc.
  2. Step 2 Turn on your television and Xbox just like you normally would to play a video game.
  3. Step 3 Open your Xbox's disc drive, placing the lens cleaning disc in the drive face-up. A lens cleaning disc works by sweeping small brushes over the laser lens surface. These brushes are located on the bottom of the disc; be careful not to touch the brushes---the microfiber brushes are delicate and can become damaged easily.
  4. Step 4 Close the Xbox and let the machine power up; make sure your television's volume is turned on. Your Xbox should automatically take you to the system's standard CD player menu. If this does not happen, select the menu manually using your Xbox controller.
  5. Step 5 Begin playing the first track of the cleaning disc. Listen carefully, because audio directions will play indicating the steps necessary for properly using your cleaning disc. Each brand of lens cleaning disc will have different steps, but they are typically very simple, involving tasks like skipping ahead to different tracks or briefly putting the CD in fast forward mode. If you cannot hear the audio directions, consult the written instructions packaged with the disc.
  6. Step 6 Remove the cleaning CD after you've followed the audio directions---a typical cleaning cycle only takes a few minutes, and the audio directions will tell you when cleaning is complete.
  7. Step 7 Carefully place the lens cleaning disc back in its case, avoiding damaging the brushes on the bottom. Lens cleaners can be used multiple times, so plan on using the cleaning disc regularly to help avoid future problems with your Xbox console.
Jun 13, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
29 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
