Question about Wintergreen CMV CT-723A 17" LCD Monitor
What size power supply is used - Wintergreen CMV CT-723A 17" LCD Monitor
    New Friend:
2,6 Amps 19 Volts, may have odd plug, cant remember
Posted on Apr 08, 2016
  • Wintergreen Master
  • 6,694 Answers
it uses 19V AC power supply adapter.
ok
Posted on Dec 31, 2010
Can this Tally Print work with any 7,5v power suply?
The TallyCom works with a 7.5 volt power supply, you would need to ensure the correct size connector is used and also the power supply center pin is of the correct voltage.
Also ensure the power supply is able supply the ampage required by the TallyCom
NOTE the TallyCom+ uses a 5 volt power supply do not use a 7.5 Volt power supply if the print server is the + version
Nov 18, 2010 | Tally (43555) Print Server
I have a pioneer car stereo-12V DC, a sony xplod amplifer(2 chanel)-12V DC and I want to use them in my home, what kind of power supply will I need?
You want to use a 12 Volt power supply. This takes your 110V power and converts it to 12V power. Which size you need completely depends on how powerful your amplifier is. Your stereo needs about 10amps of power and looking at the fuse size on your amp, you need to add thses to the 10 amps for the stereo and this will tell you what kind of power supply you are looking at.
Aug 09, 2010 | Pioneer Car Audio & Video
I have an ThinkCentre M51 8143-14U and i wish to upgrade to a better power supply for a graphics card. But i don't which to buy because of different dimensions sizes and cords. im after anything over 500W.
There are only two different sizes of power supply commonly used that I know of and all power connections are the same as well.
I would suggest a reputable power supply that has specs for each "rail" in amperes not just 500w as there are many pwr supplies that do not "cut the mustard". You can research these in www.tomshardware.co.uk
Mar 29, 2010 | IBM ThinkCentre M51 PC Desktop
What size power supply do i need for westell versalink 327w
You need to use an external 120 VAC to 12V DC wall-mount power supply.
Take note: Westell recommends the use of a surge suppressor to protect equipment attached to the power supply.
Hope this helps!
Dec 10, 2009 | Westell Wirespeed VersaLink...
I am looking for a wiring diagram for my emachine front power switch
Power Supply Types
There are two basic types of power supplies. There are AT power supplies, which are older and in older computers, and ATX power supplies, which you will find in virtually every new computer you can buy.
There are two fundamental differences between AT and ATX power supplies. First, the switch mechanism is different. AT power supplies use a normal on-off switch, which directly turns the power supply on or off.
ATX power supplies use a momentary switch which does not directly control the power. Instead, the switch signals the motherboard, which performs one of three actions:
  • If the computer is off, the power supply is turned on (which turns the computer on)
  • If the computer is on, the computer goes into power-saving mode (standby)
  • If the switch is held for more than 4 seconds, the power is cut and the computer turns off.
Because of this difference, ATX power supplies are better for projects that require the second power supply to turn on automatically when the computer is turned on.
The second difference is in the motherboard connector: AT power supplies provide two 6-pin connectors (figure 1), which are easy to insert backwards. The ATX connector is a single 20-pin connector that only plugs in one way (figure 2).
Figures 1 and 2: The difference between AT (left) and ATX (right) motherboard connectors.
Both power supplies provide two types connectors for plugging devices into. These connectors are called Molex connectors, and they come in two sizes (see figure 3 and 4). A power supply will generally have a few of each size.
Figures 3 and 4: Large (left) and small (right) Molex connectors.
There is no difference between the two sizes other than the size itself. Both sizes provide the same amount of power to whatever device is plugged into it (12V and 5V). The small Molex connectors are generally used only for floppy drives. Large Molex connectors power hard drives, CD/DVD drives, and many fans and lights as well.
Note: You can purchase large and small Y-adapters if you run out of Molex connectors. Be careful when using the Y-adapters however, because if your power supply does not have enough power for all the devices attached (especially true for older, lower-wattage supplies), you can damage it.
Dec 03, 2009 | E-Machines eMachines Desktop PC
I need to install a power converter in my truck.Can any one help me with the basics? Please get back to me. Keith
What is it exactly that you want to accomplish? It looks like this unit is powered by the electrical system of your truck, but if it indeed can provide 2500 Watts of output power, its input demand from your truck electrical system will be in excess of 200 Amps!!! You'll need some pretty hefty wiring to support that type of demand, and I doubt if your alternator can put out that amount of current.
Are you sure you want/need to do this - and run it off your truck electrical system?
Sep 22, 2009 | Xantrex Technology DPS350KB 2500-Watt...
Have a gateway E2000 want to rebuild,
the e2000 has a speacial type of power supply. Replaces Gateway E2000 power supplies that use "Nina" chassis. http://www.atxpowersupplies.com/180-watt-power-supply-FSP180-51NIV-GW.php is a power supply i would suggest getting.
Dec 16, 2008 | Computers & Internet
Dell Optiplex G110 power supply unit replacement
Yes you can replace the old defective power supply with the new atx but the problem is the size. It the size it fit to your computer nothing to worry because power supply now is almost the same output only the wattages changes.
Apr 11, 2008 | Dell NPS-110AB (NPS110AB) 110-Watt Power...
Power supply gigaset 8825
The power supply for the 8825 base is to be 13 volts AC, rated at 850 milliamps or higher. You can go anywhere from 13 up to 15 volts without hurting the unit, and a higher current rating is even better. We actually make them ourselves through bulk purchases of varieties of power supplys. Your next delimma will be the plug size, it is a pretty common size, most universal adapters will have the right size of the outer and inner connections.
Nov 16, 2007 | Siemens Gigaset 8825 Cordless Phone
Wintergreen CMV CT-723A 17" LCD Monitor Logo
109 people viewed this question
Top Wintergreen Computers & Internet Experts
David Payne
David Payne
Are you a Wintergreen Computer and Internet Expert? Answer questions, earn points and help others
