Question about GE GSS20GEW Side by Side Commercial Refrigerator
I have a GE model GSS20GEW and I am having the ice machine freeze up at the top where the water comes in above the freeze tray, and then leaking into the back of the freezer causing problems with the fan, making things not freeze, it seems to be putting out too much water, on outside of the ice machine on the left side there is a + and - plastic circle, but with no teeth for turning, I don't know if this is for a feature my machine doesn't have or what. I have heard you can adjust this slowly for flow? Maybe someone knows if this is a bad water valve or if there is a way to change the amount of water it releases, or what my problem actually is, thanks.
3 Suggested Answers
tborn6
  • 700 Answers
SOURCE: water coming from ice maker freezing down back wall of freezer
check for levelness of the ice maker also make sure that the fill tube is inserted all the way into the unit
Posted on Apr 25, 2009
arikrom
  • 528 Answers
SOURCE: ice maker is leaking into the tray where the ice is dispensed causing the ice to become embedded into the tray
there is a screw in the ice maker unit that can adjust the water level open the ice maker whit cover and you should see it but turn it gently little by little each time...and see how much you getting :) very EZ good luck
Posted on Jan 02, 2010
My Ice maker doesn't make ice anymore
90% of ice maker problems are water related. Sounds like water may be continually seeping in from the inlet water valve (normal thing to do if the water level is low). This will not allow the water to get down to freezing temperature. You have to identify the reason that water is constantly running in. It's probably "leaking" out at the dump valve. Or does that unit have a float valve that may be leaking. Check your drain to see if water is leaking out during the freeze cycle.
Jul 07, 2014 | Hoshizaki Freezer Commercial Ice Machines...
I have a GE PTC22MFMBLCC Top Freezer Refrigerator. I recently noted that the water line that dispenses the water to the ice tray has a drip leak. The drip starts at the back end of the tube. Now my...
the water valve is bad it is in the back under the frig. go to appliacepartszone.com put in the model # it is easy to repace just unplus the frig first
May 26, 2011 | GE PTC22MFM Top Freezer Refrigerator
Ice maker does not work how do I fix
Is freezer cold enough to freeze ice ?
There is a wire across the ice tray that must be down into the tray so the ice machine knows there is room for the next batch of ice in the tray.
If the wire is up in the off position ..no ice willbe dumped into the tray.
Is water being supplied to the ice machine ?
If all above is not the problem ..go online and buy a replacement ice machine.
The cost to fix old machine greater than cost of new machine.
Nov 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker is leaking into the tray where the ice is dispensed causing the ice to become embedded into the tray
Jun 06, 2008 | GE PDS22SIS Bottom Freezer Refrigerator
Defroster leaks
you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Feb 25, 2008 | Whirlpool (ET8FTEXSQ) Top Freezer...
The ice maker usually is an easily removable assembly, lift and pull or something like that. It may be the little water line has cracked, plastic don't like being cold.
Jan 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
The tube freezes over where water comes in to fill the ice tray
You may have a related problem. If the freezer compartment isn't sealing off it will have excess moisture inside eventually making excess ice build up on the water inlet tube on the ice maker. Otherwise the water inlet valve is not closing completely and a little bit of water is building up and freezing.
Dec 26, 2007 | GE GSS20IEP Side by Side Refrigerator
Ge profile leaks from front of freezer
your drain will be plugged under the tray. there is a hose that runs to the drip tray. the back cover comes off you can then get at the hose
Sep 05, 2007 | GE GSS25JEMWW Side by Side
GE GSS20GEW Side by Side Commercial Refrigerator Logo
66 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
