Question about BellSouth 2007C Answering Machine
I have a Sprint Digital answering machine, SP-813, 43-5813. It started beeping continuously at 3:30 a.m. The window shows a code, "F 1." The phone line is working. The electrical outlet is working. What does the code mean? Is this a problem that can be repaired? Thank you.
MY TOP LOADE WASHING MICHINE SHOWS CODE PR HOW CAN I SALVE THE PROBLEM PLZ SEND ME ANSWER
PR is normally the code for--- pause in the wash cycle-- press start again and it should continue washing from where it was paused
other than that call in a technician for a proper diagnosis and a quote
Jul 15, 2016 | Washing Machines
At&t 1717 after power failure get beeps and flashing "E2" code. 1717 no longer responds to any command.
Please check the manual, or download it here. At page 7 of the manual, theyl mention you need to call a service-number for help, concerning E-codes.
Oct 10, 2012 | AT&T 1717 Digital Answering Machine
What is Error Code "F6E1"
I had the f6 e1 code flashing on Whirlpool Duet washer. It would stop midcycle and beep. I cleaned out the lint filter. This seemed to help but gradually the problem got worse. I cleaned filter again. Still beeping. I read more solution and finally found the answer! I never put the cover back on. There is a switch on the left bottom that is held in by the cover. Works fine now!
Jan 14, 2012 | Whirlpool duet Washing Machines
Gestetner 2212 copier Service Code SC542 I"ve
In your machine (model) you have to enter in SP mode to reset your error code.
Try this:
Yellow key.
1-0-7 on the key pad
Red key at least 3 sec.
Press "copy sp"
On the key pad press 5 810 and #.
Press execute
Exit all the way out.
Turn the machine off and on.
Feb 28, 2011 | Gestetner 2212 Digital Imaging System...
Cat.no. 43-5812 i have a sprint answering machime that was made for radio shack when plugged in it sounds a repeated beeping sound that is not changed by any combination of reset buttons what do i do to...
I don't know the answer, but I'm having evidently the same problem. I get 5 beeps in about one second followed by 3 seconds of silence and the pattern repeats indefinitly. F3 shows briefly in the window each cycle. Please email me at dmusicant at pacbell dot net if you have any ideas! Thanks!
May 11, 2010 | Radio Shack 3822 Digital Answering Machine
Function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
  • Check and clean or replace the possible defective thermistors or out of position.
  • Fusing heaters open circuit.
  • Thermostats for open circuit.
  • Power supply unit.
Good luck and please rate me, thanks.
Mar 02, 2009 | Ricoh Aficio AP3800C Laser Printer
Sprint RadioShack answering machine CAT. NO.: 43-5812
http://telephones.att.com/docMgt/public/art/162/1717_manual.pdf
Your question is not clear enough, You can check it out in the user manual. I just guess you are asking recording your personal annoucement.
Before using this answering system, you
should record the announcement (up to
one minute long) that callers will hear
when the system answers a call. If you
choose not to record an announcement,
the system answers with a prerecorded
announcement: “Hello. Please leave a
message after the tone.”
1 Press and hold "Annc/Skip". The system
beeps. Speak toward the microphone
normally, from about nine inches away.
While you are recording, the Message
Window displays —.
2 To stop recording, release "Annc/Skip".
The system automatically plays back
your announcement.
To review your announcement, press
and release "Annc/Skip".
Sep 02, 2008 | AT&T 1717 Digital Answering Machine
Radio Shack Sprint SP-812 Answering Device can't retrieve messages
Follow the below link for your manual,
http://support.radioshack.com/support_phones/39764.htm
The F it is displaying means current memory is full, I would reccomend playing your messages and then recording them onto a portable cassete recorder, or even play it back and record it onto your pc if you have a mic.
hope this helps
Mar 03, 2008 | Lands Phones
BellSouth 2007C Answering Machine Logo
150 people viewed this question
Top BellSouth Lands Phones Experts
Are you a BellSouth Lands Phone Expert? Answer questions, earn points and help others
