Question about Kenmore Washing Machines
Kenmore, He4T washer, Washer had run on the heavy duty cycle. The clothes eventually finished. We only use HE approved soaps. When we went to run next load, we pushed the cycle we wanted to select. I saw 3:15 on the timer and all lights began flashed in sporadic pattern, the lights in the area where you select specific for your cycle stayed on. I tried closing the door a couple times and holding the pause/cancel button, no results. I left the machine, then about 30 minutes later a steady beep started that wouldn't stop. I finally unplugged machine. When plugged in no response from any buttons, won't go into test mode. Repair history replaced CCU with new unit about 1 or 2 years ago for an f. code
  • 2 more comments
  • Rick Ead
    Rick Ead Dec 31, 2010
    what is the model number of your machine?unplug your unit for 5 minutes when you plug back in are you hearing a click coming from the ccu as well as the door latch?Thanks Rick
  • cliffordocon Jan 02, 2011
    We Will See
    I have been trying to give your payment and it would say unsuccessfull payment , I will keep trying !
  • cliffordocon Jan 09, 2011
    Rich
    Thanks for the comback ,I managed to barrow a used CCU and I have the same problem.Any other ideas?
    Thanks
    Cliff
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
There are several problems with the wiring harness and CCU being a problem on this model. I would start there first. Have a look at all the plugs that interface between the CCU (Central Control Unit), MCU (Motor Control Unit) and the Interface boards for any loose or burnt wires or components. The CCU has probably gone out again on you I am sad to say. Over time the CCU tends to take quite a bit of punishment from heating. I even had a customer that after replacing the CCU several times, installed a cooling fan over the CCU and has not had a problem since.
Have a great New Years!
The FixYa Team
Posted on Dec 31, 2010
Kenmore Elite HE4T standing water
I also have standing water after a wash cycle, but not immediately after. Given the history of very expensive repairs to this Kenmore HE4T washing machine, I suggest you do what I do, if the machine is still cleaning the clothes. Whatever cycle you use, try to be around when the machine finishes, so that you can turn off the water supply and remove the damp clothes to the dryer or clothes line. Turn on the water supply only when you want to use the machine. This works for me because I don't do many loads per week and my laundry area is right next to my kitchen. If it was in my basement, I'd have replaced it already with a top loading machine with mechanical not electronic controls.
Aug 21, 2012 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Washer doesn't rinse well. Doesn't spin water out properly.
Ok.you need tro make sure that its pumping out okay...if not check the filter..then pump..
Feb 21, 2010 | Washing Machines
Face Clothes and Towels are smelling bad after being washed and dried in my Kenmore HE3 washer and dryer. Have tried running an empty cycle with bleach only, washed small loads with hot water, pre-wash and...
Try running an empty heavy duty wash cycle with a pint of vinegar added to the water, run wash cycle for two or three minutes then turn the machine off for thirty minutes then restart and let finish the full wash cycle
Aug 02, 2009 | Maytag EPIC MFW9700S Front Load Washer
While the washer drains and spins, new water comes in
Drain hose must be at least 30 inchs above the floor.
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore HE4T Elite F06 problems
Given I had purchased the Extended Warranty, Sears replaced the washer. So, we will see how this one works.....
Jan 04, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore Washer Won't Drain
yes, check the drain, could be clogged, or check the water pump assembly as well, the clothe could be stuck in the impeller.
the burning smell could be coming from a separate electric water pump and it can not turn that is why it is burning already.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Washing Machines
Leaves soap residue
theres a new product just hit hte market www.affresh.com try this stuff speciffically designed for the frontloaders and endorsed by whirlpool, makers of your machine
Apr 01, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Kenmore Washer won't agitate, spin or drain
It's not your exact model but does have some good information about the possible causes.
http://www.shopyourway.com/questions/1099421
Apr 07, 2017 | Washing Machines
Washing Machines Logo
24 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
