Question about Celestron AstroMaster 130 EQ Reflector (65 x 130mm) Telescope
I have set up my celestron astromaster for the first time but cannot see anything through it. I have followed the instructions to the letter and watched the youtube video.
    Genius:
  • 1,177 Answers
New telescope users are taken by surprise at the difficulty of just pointing the telescope in the right direction to see anything. The field of view is quite limited, especially if you are using a high power eyepiece. The higher the power of eyepiece on a telescope, the dimmer the image, the more difficult to aim it at any chosen object, and the more difficult to focus. When the scope is not focussed, even if there are stars in the field of view, they will only be faint blurs.
It is best when you are starting out with a telescope to try it with the least powerful eyepiece (the one with the highest number) to begin with, until you become more familiar with how it works. Do NOT use the Barlow lens if one came with the scope.
The finder scope is meant to help you get the main scope lined up on the object you want to view, but it won't be any use in pointing the telescope until you adjust it to precisely line up with the main scope. Telescope manuals recommend that you do this in daylight, by pointing the scope at an object on the horizon and adjusting the finder to match (never point a telescope toward the Sun!). Once you have a tree or mountain peak in the center of the main scope's image, you can then adjust the screws around the finder scope to get the crosshairs (or red dot) centered on the same object. It is very difficult to do this job in the dark, especially as objects in the sky are constantly on the move. You will find that there is a very wide range of movement in the focus mechanism, because different eyepieces focus at different points, but the actual focus range for any eyepiece will be a small part of the overall range afforded by the focusing mount. It is much easier to familiarise yourself with this in daylight.
At this point you will learn that astronomical telescopes usually show an upside down image. There is a good reason for this- erecting the image needs more bits of glass in the light path, which reduces the amount of light and increases aberrations. Even if this is only slight, astronomers prefer to avoid it, and they don't really care which way up the Moon or Jupiter appear.
Once you have done the above, you can try the scope at night, on an easy to find bright object like the Moon. Looking at random stars will probably be disappointing, as they don't look different under magnification. You will have to find planets, star clusters or nebula to see anything interesting. You will also find the the object you are looking at swims out of the viewing field, and you must continually move the scope to follow it. This will be more pronounced at higher magnifications. Again, use the least powerful eyepiece. Small scopes are often advertised as having unrealistic powers (300, 500) which can never be practically achieved. You just get dim blurs.
There is an excellent website for beginner telescope users at THIS LINK
Posted on Jan 05, 2011
What is the switch for below the viewing lens on a Celestron Astromaster EQ76 telescope?
Your picture is not very clear. However there is a complete setup video located here. I did NOT notice any switch near the eyepiece; only the thumbscrews used to hold the eyepiece in the focuser.
http://www.celestron.com/browse-shop/astronomy/telescopes/astromaster-76eq-telescope#
Feb 16, 2015 | Celestron Optics
How can I set up a telescope?
Best bet would be to get a cheshire collmination eyepiece About $30 (unless you go laser >$100) instructions are easy to follow.
Sep 05, 2014 | Celestron AstroMaster 130 EQ Reflector (65...
Where can i buy a replacement 10mm lens for celestron 31035 astromaster 76EQ telescope
There are various qualities of 10 mm, some fearsomely expensive. In the USA try here
http://www.optcorp.com/manufacturer/orion?cat=14
May 28, 2014 | Celestron 31035-astromaster 76eq - Kit
I use a celestron astromaster 130 eq. When I focus on an object such as a planet at night, the silhouette of the secondary mirror and its mounts overlays the image of the planet. I do not experience this...
You need to collimate your telescope. This site has a really easy to understand diagram and instructions. Hope this helps. http://www.astro-baby.com/collimation/astro%20babys%20collimation%20guide.htm Good luck. Astronomyforums.net and cloudynights.com are two really good sites for information.
Sep 03, 2012 | Celestron AstroMaster 130EQ Telescope
Not able to see anything would like how to use cerlestron EQ 114
This is a small reflector style telescope on an equatorial mount. The mount and tripod must be polar aligned in order to be used. Read this:
http://arnholm.org/astro/polar_alignment/index.html
Simply pt the eyepiece with the largest number written on it into the telescope, take the scope outside during the day time and practice focusing on a distant object like a building.
Celestron's manuals are located on this web site-- find your scope and download one for free:
http://www.celestron.com/c3/downloads.php
www.telescopeman.org
www.telescopeman.us
www.telescopeman.info
Aug 13, 2011 | Celestron AstroMaster 114EQ (100 x 114mm)...
How to use the celestron Astromaster 114EQ
This is an EQ mount which must be polar aligned in order to be used:
Read This:
http://www.optcorp.com/product.aspx?pid=3050
Dec 26, 2010 | Celestron AstroMaster 114EQ (100 x 114mm)...
Does the Celestron AstroMaster 114EQ use a diagonal?
NO, you do not need a diagonal. The eyepiece goes directly into the focuser.
images in astronomical telescopes are always INVERTED-- you can buy an "erecting prism diagonal" for terrestrial viewing, but it is not needed for star gazing.
Dec 23, 2010 | Celestron AstroMaster 114EQ (100 x 114mm)...
Setting the star coordinates on a celestron Astromaster EQ mount
You need to put more information into your question. There are several different Celestron EQ mounts with different hand controllers.
Go to www.cloudynights.com and post your question with the exact model information in the member forums.
Nov 06, 2009 | Celestron Optics
Celestron AstroMaster 130 EQ Reflector (65 x 130mm) Telescope Logo
108 people viewed this question
Top Celestron Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Vernon Taylor
Lawrence Oravetz
Are you a Celestron Optic Expert? Answer questions, earn points and help others
