Question about Vinpower 16x CD / DVD Duplicator with NEC Burner 8 targets Burner
I am getting this error when trying to duplicate my advertisments discs "burner mixed or firmware version mixed" and it is even nt getting into advanced setup.. wht shud i do ?
  • 3 Answers
If you can not go into " Advance setup" then you can't update your writer firmware through controller. The only thing you can do is connect you writer to a PC, update writer one by one and put all back to tower.
If all your writers are same brand ( NEC ) , but different model, this solution won't take care you problem. In this case, two way you can do:
1, Find out what the model that you have most and buy that one from any seller, remember " Update F/W to same version.
2. Get a ACARD controller, ACARD controller can mix brand, model and firmware in one system.
Posted on Jan 07, 2011
Acard duplicator comes up 'source drive not ready' it has been working fine untill now is it just a case of replace the disc drive or is it more serious?
Have you tried to upgrade firmware ?
If this is up to date and still causes function error try to Completely uninstall all software for it and reinstall....
May 15, 2012 | Acard ARS-2030PC 1-to-3 Target USB Card...
Keep getting "Target Overflow" error message, even
you may have a bad ROM. If you have a multiple target unit, switch the source from the ROM to one of writers and try copying that way, if it copies then it confirms that the ROM is defective.
If you have a Single target unit, check your master disc under disc info, depending on which controller you have it should be under utility or disc info. Once in disc info it should tell you the size of your master disc, for DVD-R it should be under 4488MB, for DVD+R it should be under 4482MB. Then double check the master in the PC just to confirm.
Jun 12, 2011 | EZ Dupe EZDupe Two Target DVD Duplicator...
I have EZ Dupe 7 duplicator . It can not duplicate DVD to DVD , the message appear in the screen is "CAN'T DUPLICAT DVD TO CD " but I put blank DVD into the drives even I tried for more...
I would suggest uninstalling the software, reinstalling it and then making sure that you have all of your updates on the software and the firmware updates on the DVD drive.
May 12, 2011 | EZ Dupe Computers & Internet
When trying to copy a CD, I get the following error message: Warning - Bad Master Disc!
I assume it means just what it says. The Disc you are trying to copy is faulty?
Clarify what you are trying to copy. If it is copy protected, A duplicator wont copy it. Or the disc was made in a format incompatible with the master drive you are using. Ive had drives read some discs and another drive that cant read the same disc. Some brands of discs work better on certain drives. Try to use top quality reccomended discs such as Verbatim.
Char S.
May 27, 2009 | LG 1 to 6 Target CD Duplicator 52x CDRW...
I have a Go-Video-PDS Professional Duplication Systems Tower and It records 11 CD's at once. I don't have the manual instructions booklet that came with it and so i have been looking all over the internet...
One a CD has been used or even partially recorded... you can not record on it again.... so if you stop recording on the CD-R disc... you have to start with a new fresh CD-R and throw away the other CD-R disc. Many people make this mistake and try to record on the partially recorded CD-R discs or they have one or two mixed in with their blank CD-R's and wonder why their duplicator doesn't work?
Mar 06, 2009 | Tower CD&DVD Duplicator Cases: 8 Bays...
PROBLEMS DUPLICATING WITH MY CONDRE TRACER PRO
You could try using a lens cleaner in the drive. Another is to update the firmware version from the manufacturer's website. The last thing I can think of is to uninstall the drive from device manager, uninstall your burning programs, and then re-install them.
Feb 25, 2008 | Condre C38824DVD-T 3-Target 8X DVD...
Vinpower 16x CD / DVD Duplicator with NEC Burner 8 targets Burner Logo
238 people viewed this question
Top Vinpower Computers & Internet Experts
jhnolson
solver2010
Are you a Vinpower Computer and Internet Expert? Answer questions, earn points and help others
