Question about Whirlpool Dryers
Clothes not dry although mechine run 2 hrs. - Whirlpool Dryers
    President:
  • 1,194 Answers
When the dryer wont start it is the thermal fuse that is bad, you can test it with a voltmeter before replacing. This fuse is located inside the rear panel and it cannot be reset.
Hope this will help...
Posted on Jan 01, 2011
My wife ran my phone thruu the warsing mechine. I was able to dry it out but the screen will not ome back.
Get a bowl of dry rice
Place the phone WITHOUT the battery in the bowl
Cover over the phone with the rice
DO NOT TOUCH
Keep in bowl for 48 hrs
Re-insert battery
Phone should work.
If not the moisture was too much, youll need a new phone
Mar 04, 2011 | Cell Phones
My clothes have been drying for 2 1/2 hrs and are still wet. The dryer is spinning and the clothes feel warm to the touch but not dry. Any suggestions? Thank you!
Turn the dryer off, unhook the exhaust tube, and make sure it isn't clogged. Also check to make sure the outside exhaust vent isn't blocked or clogged with anything.
Feb 04, 2011 | LG Dryers
Dum turns to fast for cloths to tumble, 2 hrs. to dry!!
don't know about the drum turning to fast, but the two hours to dry I do know. Disconnect the vent tube and dry a load of clothes, as there is a restriction in your vent tube. You will need to clean the tube out with a vacuum or leaf blower, you may want to clean the inside of the dryer out,also. Good Luck Tim
Jan 06, 2011 | Maytag Neptune MDG9700A Gas Dryer
Have Whirlpool awg 345/4 i have tried drying clothes dfollowing instructions bu will not heat up and dry clothes had on for 2 hrs on full cycle with 1200 spin
you dont say if this machine is new if it is contact the whirlpool web page and they will tell you how to do the programs but i must say 1200spin is not very fast for drying you need at least 1600 soin to do a good job.adrian,,,,,
Jun 29, 2010 | Washing Machines
WHAT IS THE COST OF REPAIR ON A HEAD GASKET FOR A 1997 SATURN SC? THANKS, JOE
1.9L SOHC - head gasket set which includes all gaskets needed to remove cylinder head with thermostat runs about $150.00. Head mechine ( check for cracks and milled ) $145.00. Labor time to remove and reinstall cylinder head 8.5 hrs X shops labor rate.
1.9L DOHC - head gasket set and thermostat runs about $210.00. Head mechine $175.00. Labor to remove and reinstall cylinder head 10.7 hrs X shop labor rate.
Labor times per Mitchell labor book, this is a guide all repair shops used.
Jan 12, 2010 | 1997 Saturn SC
Dryer heats up but takes 2 hrs to dry clothes
If the dryer takes so long to dry 1 elimet mit be burned out, tick the drom out and you'll see 2 springs 1 mite be burnet.
Oct 16, 2009 | Whirlpool LER5636P Electric Dryer
Smells hot. does not dry. sticks on 20 min all cycles
just a quick suggestion
check your exhaust outside for proper airflow
Oct 11, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Dryer isn't getting as hot as it should, clothes take twice as long to dry
clean out your wall vent,dryer hose and lint trap that should do it,what happens if you have a clogged vent the dryer keeps the wet hot air in loner and it take twice as long to dry-mike
Apr 20, 2009 | Dryers
Clothes aren't drying properly
look behind dryer is vent hose kinked or mashed flat? ck a load with hose completely disconnected may get warm and a little dusty but if problem solved reck hose all the way through
Nov 17, 2008 | Frigidaire Dryers
Dryer spins fine but no heat
First and most importantly you have to be sure the venting is completly clear of debris and lint. Then remove and inspect the heating element and all thermostats with a multi-meter. Unless your familiar with this type of procedure you might consider calling a technician. Your wasting too much energy and money drying clothes for 2 hours. Technician much cheaper in long run. Good Luck tatau.
Dec 09, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
