Question about Skil 5600 01 7 1/4" 120V Circular Saw Kit Usa
I was given a skil circular saw model 5600 but its missing the set to attach the blade (hex screw, supporting disc(s)). What else do I need? The skil diagram shows two supporting discs - do I need just one? Thanks.
5 Suggested Answers
  • 302 Answers
SOURCE: I have a very old Skil circular saw Model #586.
measure from the center of the shaft to the inside of the guard, double that distance. subtract about 3/4 of an inch and this will be real close to the blade diameter that you need
Posted on Aug 17, 2009
brewerstool
  • 141 Answers
SOURCE: I need the outer flange/blade clamp for my skil model 77 type 16
The replacement part is 1619X02969. And you can get it from directly from boschtoolservice.com ($3.75).
Posted on Oct 13, 2009
  • 885 Answers
SOURCE: We have Skil 7 1/4 circ saw model 5400-01 how do
There is a lever on the back of the top blade guard, if you pull up on it you can adjust the foot up or down to control how deep the blade will cut.
Posted on Oct 16, 2010
  • 142 Answers
SOURCE: I need a switch for a Skil Model 516 Circular saw.
Contact Eurton electric. They stock many switches that have been discontinued by the manuffaturer.310-948-4477 or 1-800-423-4789
Posted on Dec 16, 2011
Why is my blade hitting the blade guard
Hard to say without seeing it but....wrong sized blade, bent blade, clamp missing or installed wrong, bent guard, or bent blade shaft. I'd look in that order. Hope that helps.
Jul 26, 2014 | Skilsaw 5150 Circular Saws
Skilsaw 5380 blade installation problem.
Don't know exactly, but on amazon you can find user manual. here Skil Circular Saw Model 5350 Owner Manual Operating Guide Paperback 1988 . Hope this was helpful. cheers skilsaw-5380-blade-installation-problem-uh3jsoynacgcqh0wcsujgpyu-3-0.jpg
Jan 20, 2013 | Skilsaw 5380 Circular Saws
My Skil Worm Drive Skilsaw Blade stops when cutting
If the blade stops it could be from a loose hex bolt, flanges missing or you have a gear problem. UNPLUG tool and check the blade first. I would remove the fill screw on the gearcase and see if the oil has metal shavings in it, if it does the gears are worn allowing the blade to slip. If not I would recheck the blade. Did this suddenly happen and if so what did you do prior to your problem
Mar 12, 2012 | Saws
We have Skil 7 1/4 circ saw model 5400-01 how do you adjust blade depth?
Oct 16, 2010 | Skil Xdrive 7 14" Circular Saw Ships Fast
How to replace saw blade on skil saw
On the side of the saw in the center of the blade, there should be a bolt to remove that will get the blade off. Some saws have a special wrench needed to remove it, but since you have a Skil, you should be able to use either a 1/2" or 9/16" wrench or socket to take it loose and switch the blade out for one of your choice. Hope that helps.
Oct 09, 2010 | Skil 538501 120Volt 714Inch Circular Saw
Need lower blade guard for Skilsaw Model Model 77
Yes I do Know where, here you go !
http://www.toolpartsdirect.com/skil/skil-34.html
Nov 09, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Oct 11, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
I have a very old Skil circular saw Model #586. What size blade does it use?
Aug 16, 2009 | Skil Saws
Where is blade lock for my Skilsaw 5150 located
look for the button on the right side of the handle. Other models require you to put a phillips head screwdriver into a hole in the blade to hold it against the body of the saw.
Jul 13, 2009 | Bosch 7 - 1/4" Skilsaw Circular Saw
Where is the blade lock button on a skilsaw 5150 2 1/8hp ???? i can't get the blade off and turning the saw bolt the same direction as it spins isn't working.
First, there is no blade lock button on the Skil model 5150. I called the Skil customer service and they emailed me the exact manual for this circular saw. The method I used to loosen a VERY TIGHT blade stud was: spray with WD-40, imbed the blade in scrap wood, set Skil wrench (usually found in back of foot under handle) on so it could be struck going in counter-clockwise direction. Use hammer to strike handle of wrench a couple of times. To replace blade, finger-tighten blade stud, then use wrench to tighten 1/8 turn or (45°).
Jun 25, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Skil 5600 01 7 1/4" 120V Circular Saw Kit Usa Logo
96 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
