Question about Tasco Astronomical Refractor Telescope
The cd rom supplied with the telescope is not compatible with my computer. i have got windows 7 installed in my computer
  • 3,186 Answers
The cd rom only contains a planetarium program. Here is a free one which you can download and install:
www.stellarium.org
Posted on Jan 01, 2011
I have windows 7 and I have been trying to install hasbro sorry game cd rom but it wont install
You need to read the case that the CD came in. It will list 'system requirements". I bet that the game is written in 32 or 16 bit language and windows 7 is 64 bit and it is not "backwards" compatible, meaning that it won't run a 16 or 32 bit program.
Feb 25, 2011 | Hasbro Interactive Video Game Consoles &...
Circle of Blood won't load because it claims there is not enough space on drive c. This happens on 2 computers which have lots of available space. Both computers are running Windows 7. Circle of Blood is a...
Try running in compatibility mode for Windows 95.
1. Right click on the program's shortcut, .exe file, or installation program.
2. Click on Properties.
3. Click on the Compatibility tab.
4. Check "Run this program in compatibility mode for:"
5. Select Windows 95 or higher OS
Feb 17, 2011 | Virgin Interactive Circle of Blood
I recently upgraded to Windows 7. I went to install this software again but says that it is not compatable with the drivers. How to install this?
Windows 7 has a "Program Compatibility Wizard".
Launch this Wizard, and tell Windows that you want to install a Windows XP application.
Point to the CD-ROM containing the software, and install it.
Dec 17, 2010 | Nova Development Art Explosion Scrapbook...
Installing the jumpstart advanced 1stgrade cd rom that has 4 cds to it and I can't get it to install.
Jumpstart advanced 1stgrade cd rom installation.
System Requirements
Windows: 98/ME/2000/XP; Pentium II 266MHz (Pentium II 300MHz or faster for XP); 64 MB RAM (128 MB RAM for XP); 100 MB HD; 12x CD-ROM drive; 16-Bit color; Windows compatible sound card
If you are installing on a newer OS ie Vista, or Win 7, due to software incompatibility the software might not install, or even you can install the software might no work.
You can try using the "compatibility mode" in Vista or Win 7 to install the programs as "administrator" but no guarante this will work.
Alternatively, you can get a newer version which is compatible to your Operating System.
Hope it helps.
Jul 25, 2010 | Jump Start JUMPSTART ADVANCED 1ST GRADE...
My web cam can only be installed on windows xp but now i have windows vista and i can not re-install it on it, can you help me please..? web-cam is the Veo Connect personal web camera. Thank you for your...
Hi Friend,
Please follow the below steps,
Step 1. Hold down the shift key on your computer to
disable the CD from Autoplaying.
Step2. Insert the Veo Advanced Connect Installation CD-ROM & Bundled Sofware CD-ROM in your CD-ROM/DVD-ROM Drive.
Step 3. Browse to the root (first) directory of the Install CD and locate Autorun.exe
Step 4. Right-Click Autorun.exe and select Properties
Step 5. On the resulting window, move to the 'compatibility' tab and tick the box labeled "Run this program in compatibility mode for:" then select "Windows XP (Service Pack 2).
Step 6. Click "OK"
Step 7. Browse back to the executable (Autorun.exe), run it and install it as per normal.
Regards,
Aysaam
Jun 09, 2010 | Veo Connect Webcam
Can't install HP 4355 on windows 7
Installing HP 4355 on windows 7 is pretty easy ,kindly insert the PROGRAM CD in the CD ROM drive and auto run the aplication CD without connecting the printer,in few minutes of installation progress you will get alert to connect the printer and then printer is configured by OS Above is the normal procedure,very minute but technical tip is to connect the printer first and insert program CD for printer in the rom drive and open device manager and scan for hardware changes ,you will get alert on task bar that new hardware is found and new window for device installation ,click continue with browsing file path for CD in drive and continue installation ,in nex few minutes your device shall be ready to use.
Incase there is problem with installation with CD kindly go to manufacturers website and download windows 7 compatible drivers.
For Safe Computing Knidly keep your antivirus updated and firewall is on.
Thanks And Regards Kindly rate this solution
Feb 25, 2010 | HP Officejet 4355 All-In-One InkJet...
My canon i9900 printer wont install on my Windows 7 computer. What to do?
Instead of trying to use the CD-ROM that came with the printer, access the manufacturer's web-site: http://www.canon.com and click "Support".
Find the latest device-drivers for your "i9900" printer that are compatible with Windows 7. Download them, and install them.
Nov 26, 2009 | Canon i9900 InkJet Photo Printer
Programme does'nt open
here is the solution for your problem :
A problem has been identified when installing early pressings of the CD-ROM on machines running Windows 98 or Windows ME in conjunction with certain antivirus software and firewalls. The installation appears to be successful but the OALD 7 Compass program fails to launch with no error message given, or with a message "License data invalid".
Should you encounter this problem:
  1. Download oald7.zip (4.5 megabytes)
  2. Unzip oald7.zip to extract the oald7.exe program
  3. Ensure your OALD 7 Compass CD-ROM is in your CD-ROM drive
  4. Replace the old oald7.exe file on your computer (this is usually found in c:\Program Files\Oxford\OALD7) with the new oald7.exe file you have downloaded
  5. You should now be able to run the OALD 7 Compass software
If the download doesn't work, we can send you this file on a CD-ROM - please email us , and tell us your full postal address. You will need to copy the update file to your hard drive to install it, as you will need your OALD 7 Compass CD-ROM in your CD-ROM, as above.
Please email eltdict.help@oup.com if you require further help.
See also: more information about the OALD 7 Compass CD-ROM
For help with other Oxford ELT Dictionary CD-ROM products, see the Multimedia FAQ page.
Mar 30, 2008 | Microsoft Windows XP Professional With...
Optics Logo
57 people viewed this question
Top Tasco Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Lyle Siemens
Lyle Siemens
Are you a Tasco Optic Expert? Answer questions, earn points and help others
