Hello i have a 1985 delta 88. For some reason my battery keep draining. I replaced the alternator and the battery. i changed the battery cables also. When i cut the heater on in the car my lights dims, blinkers stop working, radio cuts off,and the battery drains.Also the low coolant light, low fuel, and check engine light came on. all these problems accuried after my battery drained one day from listenig to music with the key turned backwards. thanks for your time, and i really hope you could help me solve this problem.
Hello im the person who posted this problem. If anyone can help please email me [email protected]Hello im the person who posted this problem. If anyone can help please email me [email protected]
You can't post conmments that contain an email address.
Being you ruled out the alternator as a cause for the battery dieing, i would start looking into the parasitic draw on your battery when the car is shut off, make sure all your courtesy lights are going off and that none of them are staying on overnight, check your glove box light and make sure thats going off and not saying on, another overlooked item would be your trunk light, make sure the light in the trunk is in fact going off as you close the trunk, if any of these lights are staying on it will drain the battery and cause it to be dead the next morning....
COULD BE BAD BATTERY POSITIVE CABLE.BATTERY FEED WIRE FROM THE POSITIVE BATTERY CABLE BROKEN.YOU COULD HAVE POOR GROUND.YOU COULD HAVE BLOWN ALTERNATOR FUSE LINK OR FUSE BLOWN.CHECK ALTERNATOR FIELD WIRE OR BATTERY FEED WIRE FOR BROKEN OR DISCONNECTED WIRES.
Well, if the alternator belt squeaks a little, it cannot be actually charging properly, resolve that...
First steps would be to fully charge the battery and measure the voltage. Turn of vehicle Disconnect the negative terminal overnight, for a night or two.
If battery still dead, focus on the battery.
If battery is not dead, put a volt meter between the negative terminal and cable and measure voltage... do not be mislead by interior lights, or clock, pull those fuses, during testing...
Anyways, keep going until you find a drain.
The alternator has diodes that can cause a drain...disconnect for testing purposes...
NEVER run the vehicle with the battery cable dicsonnected.
