Question about Kenmore Refrigerators
Model 795.7730 when the doors are shut the light stays on most of the time . other times it stays out. help. i disconnected the power hopeing it would reset but no luck
  • 11,896 Answers
I would replace the door switch
Posted on Dec 31, 2010
My garage door light stays on all the time after opening or closing the door.
The light can stay on for a number of reasons .. especially depending on how many features your opener has. If your opener has a lot of features ... take a look at your owners manual and some feature may have been inadvertently activated that keeps the light on.
However ... if everything is set up correctly try the following to help narrow your root cause down.
If you can change the delay time of the light ... reset it to the lowest time value which just helps in troubleshooting. Most are set for 4-5 minutes which is along time to wait if your troubleshooting.
  1. Disconnect power from the unit, and disconnect door control wires from the opener.
  2. Reconnect power only. Light(s) should come on. Allow light(s) to cycle off.
  3. If light(s) turn off after delay time, the problem lies with either the door control or wiring. Continue with next step. If the light stays on, it is the logic board.
  4. Disconnect power from unit. Remove door control from wall, connect to operator via a known good short pair of wires. Reconnect power only. Light(s) should come on. Allow delay time for light(s) to cycle off. If light turns off, it's a wire issue. If not, the door control should be replaced.
Mar 16, 2018 | Building Materials
Dome lights stay on when all doors are shut and interior light switch is clicked off but staying on. WHY? 1990 Chevy Silverado k-2500 5.7 l.
door switch have to find out which door is the cause and replace switch not sure on exact location on a 90 silverado could intergraded with the latch or a push style located in the door frame if they are located in the frame push the button one at a time and hopefully light goes out sometimes pushing switch manually will turn lights out but won't always go out with door being closed hope this helps
Apr 22, 2015 | Cars & Trucks
Maytag microwave model mmv1153baw light won't shut off and won't start
Either the latch in door (spring related) is not in the correct location or you have a door switch issue and its not expensive to fix if you husband is handy. Part number you can use is 28QBP0495 or the factory one 3405-001034 (more expensive). This issue is common and these switches are located inside the control panel on the left side, the switch you seek is the lowest one in the bracket of three. Good Luck and I hope this helps.
Apr 20, 2014 | Maytag Microwave Ovens
Interior light stay on
Probably a bad door switch disconnect them all then plug in one at a time until the light comes on with the door shut
Feb 08, 2014 | 2002 Chevrolet Chevrolet TrailBlazer LS
Dome light won't shut off after truck is off and doors are shut and door ajar light is on while driving but all three doors are shut.
sounds like one of the dome light switches is bad pop them out one by one and disconnect only one at a time until the light goes out or door ajar goes off, then a quick trip to the parts store and you are good to go! :) hope that helps
Jan 23, 2010 | 1997 Ford F150 Regular Cab
On/standby Red light blinking can't turn on system
It's in protection. Disconnect all your speaker wires at the receiver then power it up. If it stays on, the receiver is ok and you need to check all wires and speakers for shorts. The easiest way is to reconnect one speaker at a time and test power until it shuts down, then disconnect the speaker wire at the speaker and test again. If it stays on, meter the speaker for shorts or bad voice coil. if it still shuts off, check your wire or replace. If the receiver's power still flashes with all speakers disconnected, it needs service or replaced. Before reconnecting your receiver after repair or replacement, check all wires and speakers 90% of the time, that's the cause. Hope this helps. If you still need help, post a comment and I can help you troubleshoot further.
Oct 17, 2009 | Denon AVR-2807 Receiver
I have a kenmore 795,7730 22.4cu ft french door
the little switch that is activated by door not working,it may be sticky from a spill, check it, it should be where door meets fridge, hinged side. plz rate -bozcro
Sep 16, 2009 | Refrigerators
No picture
CHECK THE LAMP DOOR THIS IS A LAMP DOOR ERROR.
Jun 13, 2009 | Sony KDF-50E2000 50" HDTV
Lift-Master garage door opener Model 1045-6 1/3 hp
Most residential garage door openers have a max. amount of cycles they can run per hour. Thus the difference between a residential opener which only needs to be opened a few times a day vs. a commercial opener which needs to open 10-20 times and hour. This could be your problem, you may be running too many cycles too soon. This would explain why it seems to work again after unplugging the power. You're resetting the unit. Hope this helps.
Feb 06, 2008 | Sears Craftsman LiftMaster Chamberlain...
Refrigerators Logo
187 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
