Question about Kenmore Elite Stainless Steel 24" BuiltIn Dishwasher with TurboZone Rotating Spray Jets 13103
My dishwasher is not getting wet on the top rack and so not cleaning at all
  • Kenmore Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Posted on Feb 20, 2011
  • 641 Answers
SOURCE: dishwasher leaves residue in top rack only
Most cleaning problems are caused by the dishwasher not getting enough water. It could be cause of the switch level, which control water level in the tub. The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine, but if you will open the rear panel you will find it easily. Be aware you should discoonect the power cable !!! Clear the tube (attached between the switch and the bottom of the washer's outer tub) from any obstruction.In case it will not solve the problem, you should replace the switch. Good luck !
Posted on Jun 01, 2006
aborcass
  • 2651 Answers
SOURCE: top rack not cleaning
load 4 cups right side up in all four corners of top rack, move all wash arms to a known positon(pointing foward just want to check there rotaiton). start diswasher, when you hear it start washing give it 30 sec or so andpop it open try to focus on middle spray arm when opening, shlould be turning quite well. and glasses sould be starting to fill. at least thats how it SHOULD operate
Posted on Feb 26, 2008
  • 338 Answers
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Posted on Nov 25, 2008
larryyb
  • 291 Answers
replace the top spray arm and it should work ok again
Posted on Nov 27, 2008
techcrazy
  • 72 Answers
SOURCE: Kitchenaid, new dishwasher, stopped cleaning top rack dishes
The problem most people encounter with dishwashers is a simple inability to get the dishes clean. There might be stuck-on food or residue from the detergent. A water pressure problem may be the culprit. You may need to replace the water intake valve. Another common problem is mineral build-up. If your house has hard water, the mineral build-up can clog the water jets. Clear each jet with a wire or pin, and run an empty load with some vinegar in the detergent dispenser about once a month.
Sometimes, the dishwasher has problems draining properly. There could be a clog in the drain hose, or a problem with the pump. It's also possible that the dishwater is getting too sudsy, and sensors in the washer aren't detecting the soap foam as water. This causes it to shut down the drain cycle too early. Just use less detergent.
Posted on Feb 02, 2009
The top rack dishes do not get cleaned. I have run the vinegar rinse. The bottom rack dishes get cleaned. It doesn't even look like the top rack dishes get wet. I ran the washer without the top rack in and...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
Nov 06, 2010 | Dishwashers
Only bottom rack cleans. Re-plumb or replace?
Do you have a garbage disposal? If I run mine while the dishwasher is running, dishes do NOT get clean!
Jan 09, 2010 | GE 24 in. Profile PDW7800 Built-in...
My whisper quiet dishwasher is not cleaning the top rack dishes
I'm having the same problem. Did some testing and found that the sprayer on the top rack is not even moving and hence not getting any water. Not sure what to do.
Sep 07, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Feb 02, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Top rack not cleaning
Some dishwashers have a telescoping nozzle in the center on the bottom. If this is blocked by a large pot in the middle of the bottom tray, the nozzle will only extend up into the pot, and not be able to spray the entire top rack.
Also, some models have an arm mounted in the top. Check and see if it can spin freely, and if it's nozzles are clogged.
De-clog by soaking the part in vinegar.
Sep 17, 2008 | Kenmore 24 in. 16539 Built-in Dishwasher
Dishes not cleaning
it may be hard water or some other minerals in your water. there is a new product out called the dishwasher filtration system and it actually filters the water going into the dishwasher. i tried everything to get my dishes clean but nothing worked until i tried this system. my glasses all had a white, cloudy look to them and it was terrible. you can get it at www.dishwasherfilter.com. it is very affordable and works amazing. the filter fits right under the sink and solves the problem immediately. if you use the discount code DFMTEN you will get 10% off
Apr 01, 2008 | Dishwashers
Kenmore Elite Stainless Steel 24" BuiltIn Dishwasher with TurboZone Rotating Spray Jets 13103 Logo
Top Kenmore Dishwashers Experts
D. E. Hev
Adam Dower
Adam Dower
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
