Question about Panasonic HHR-P105 Cordless Phone
Mi telefono panasonic HHR-P105 se le borro el idioma español y no puedo volverlo al español
3 Suggested Answers
bhur
  • 85 Answers
SOURCE: telefono inalambrico kx-tg3031s
you may coldsolder the flash ic and cpu
Posted on May 29, 2008
bbl242003
  • 1637 Answers
SOURCE: manual telefono panasonic kx-tg2258 en
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones MORE USEFUL INFORMATION FOR ALL YOUR ELECTRONICS When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me.
Posted on Jan 18, 2011
Como cambiar el menu a diferentes idiomas?
Sorry I do not speak Spanish. Try searching with Google using this: Manual imageRUNNER 6020 Copier That should get you to the correct place.
Lo siento, no hablo espa?ol . Intenta buscar con Google usando esto: Manual imageRUNNER 6020 Copiadora que debe llegar al lugar correcto.
Dec 05, 2014 | Canon imageRUNNER 6020 Copier
Como puedo desbloquear mi estereo clarion vz401 le
si el estereo que tenes es el que viene de fabrica llama al dealer y ells te daran el codigo
Sep 25, 2014 | Cars & Trucks
Como porfabor puedo descargar o obtener el manual de instrursiones de mi relo Citizen eco driver e310 pero no se cual es el modelo aqui le dejo porfavor alguno de los datos que tiene en la tapa y en la...
HOLA YASSERDIDIE !!!!!!!
ENCONTRE UNA PAGINA DONDE VIENE UN MANUAL PARA EL RELOJ CITIZEN E310, ES UN ARCHIVO EN PDF Y VIENE EN ESPA?OL
EL LINK ES: http://sumanual.com/instrucciones-guia-manual/CITIZEN%20WATCH/E310-_S
ESPERO SEA EL MISMO MODELO QUE TU RELOJ Y QUE MI INFORMACION TE SIRVA PARA RESOLVER TU PROBLEMA. :)
Apr 29, 2011 | Citizen EcoDrive Calibre 3100 BT000007E...
Mi microsoft office me pide una clave y no se donde buscarla y no puedo hacer mis trabajos
debe estar dentro de el caso de que el software se puede pulgadas necesita ponerse en contacto con Microsoft para probar la propiedad y ver si se le entregará un nuevo código si se ha instalado antes. lo siento mi español es tan pobre.
Jul 11, 2009 | Microsoft Office Professional 2007 Full...
Zyxel 964
gracias por comunicarte conmigo te cuento me regalaron un zyxel prestige 900 cable router 964 se q fuciona pero no lo puedo instalar no se porq mi computadora no lo lee es una hp pavilion dv9410us notebook pc no tengo el software del modem y no se como conseguirlo me podrias ayudar?? muchas gracias!!! andrea
Oct 18, 2008 | Zyxel Prestige 964S Router (02009900001)
Motorola W375
Vas a presionar el boton de menu (es el boton de en medio de el circulo)> Settings > Initial Setup
> Language
Sigue el order que te mostre arriba y luego eliges spanish
Oct 14, 2008 | Motorola Mobility W375 Cellular Phone
Identificador de llamadas
Yo no conozco ese producto, pero te puedo ayudar si me identificas el manufacturero (fabricante) y el detalle del modelo. Es posible que ese manufacturero tenga instrucciones en espa?ol. Si no, puedo hacer la traducci?n al ingl?s. Estoy en Puerto Rico y soy bilingue,
Mar 26, 2017 | ATS 4121CCL Twin Cordless Phone
Idioma
Si lo has comprado en un pais donde se habla espanol, o en un pais europeo o en los EEUU deveria de tener el espanol en los seteos del idioma. Si es asi aconsejo de ir al vendedor y chequear.
Si no tiene espanol puede ser de improtacion. En este caso tienes que re instalar el firmware.
No se si le valdra hacer el update desde el telefono (nececita conesion al internet). Yo aconsejo de ir a un vendedor de telefonos y pedir de reinstalar el software del telefono, es una operacion bastante sensilla. aconsejo de grabar todos los contactos anter de llevar el mobil a la tenda.
Otra solucion podria ser bajar el software desde el internet i instalarlo usted con un cable y una ordenadora, esta operacion tiene un poquito de riesgo si nunca lo hizo antes.
Apr 06, 2008 | Sony Ericsson K750i Cellular Phone
I have problem with running my 40 GB
Hi, problems with "running" your 40 GB Hard Drive?
Is it hooked up properly? Do you know how to hook it up?
Is the power cable hooked up to it? The IDE or other "data" cable properly connected to it?
Check all items with the connection with your hard drive.
If this isn't your problem, please repost.
Best of Luck.
~Ominious Depression
Jan 08, 2008 | Transcend (TS40GSJ25) 40 GB Hard Drive
Panasonic HHR-P105 Cordless Phone Logo
81 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
