Question about Kenmore Dryers
I just hooked my dryer up & can't find lighting instructions. Is it electronic ignition?
  • Kenmore Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 03, 2011
Dryer runs but does not heat on maytag model med6000xw1
If you have a newer model with electronic ignition, check igniter by the burner, or if a pilot light ignition, obviously re-light, but possibly the gas safety interlock switch is tripped by a weak pilot flame, which causes main gas valve to stay off. Best guess, igniter element has cracked, and is simple to replace, order online.
Oct 30, 2013 | Kenmore 62602 Electric Dryer
Panasonic CQ-C8303U. Hooked up an amplifier and it works with the radio but when i put in a cd the amp doesn't work. the receiver just plays with normal sound.
Verify your wire connections are correct. Keep in mind that if your amp is hooked up to the radios power antenna wire this is the problem. When you insert a cd the radio is designed to lower the antenna. If your amp is hooked up to the antenna wire the radio is shutting off the amp when you put in a cd Panasonic does this on most of all their units. You may have to hook your amp up to a separate switch to turn the amp off and on or hook it to your ignitions acc wire, if you hook it up to your ignitions acc the amp will stay on as long as your key is on even if you turn off the radio.
Here's a link to download the manual for your radio just copy and paste it in to your web browser and download the PDF file. You will need the reader to view it. If you don't have the reader you can download it for free at www.adobe.com
http://www2.panasonic.com/consumer-electronics/support/Audio/Mobile-Electronics/CD/model.CQ-C8303U
Oct 09, 2010 | Panasonic CQ-C8303U CD Player
Does this dryer have a piloit light that has to be lit?
no it should light on its own by the ignitor if the ignitor is not lighting the unit then check with an amp meter on the ingitor wire shoudl be drawing 3.3 amps any less then replace
Jul 18, 2010 | Dryers
I have a brand new dryer model WGD9150WW that will not heat up. All it does is air dry clothes. While this probably will save me a ton of money on gas it sort of is in conflict with the whole dryer idea....
You are correct that this machine does not have a standing pilot. I have had a couple of these machines that have come out of the box with broken ignitors. The ignitor is a pretty fragile device that glows red hot and then ignites the gas after the valve opens. If this is a brand new dryer, you have two options, return it for another one (if it is in stock) or call a whirlpool authorized repair company to come and take care of it for you.
This is something that you could probably do yourself, but you are under the manufacturer's 1 year complete warranty.
If you opt to try to fix it yourself, let me know and I will provide you with a walk through.
Good luck to you!
Jun 15, 2010 | Dryers
How do i re light pilot after dryer has been serviced?
Depending upon how old your dryer is newer models have an electronic ignition and you do not have to light it at all like you would a water heater or something similar. If it is a bit older then there should be a step by step instructions down at the bottom where you access it at. Let me know the model of dryer and I can help you out quite a bit more.
Aug 01, 2009 | Kenmore Dryers
Kenmore 80 series Gas Dryer
HI. you are correct. this dryer, although gas, is using a Glow igniter system. most older models used the snap igniter that clicks over and over to spark the burner but, this dryer is only 2 years old so, it should be outfitted with a glow igniter system. This igniter is powered by electricity.
It works in conjunction with a Flame sensor.
Jun 02, 2009 | Kenmore Dryers
Kenmore dryer not heating
hi,
1) When this happens, something has interrupted the heat source. Run the dryer for a couple of minutes to see if it gets hot. Be sure you don't have the dial or controls on a non-heat setting, such as "Fluff" or "Wrinkle Control."
2) On an electric dryer, this may mean that the circuit breaker or fuse that controls the power has blown; reset or replace this. Be aware that a dryer may have two breakers or fuses. The motor will run when one works, but the heating element requires both.
3) On a gas dryer, recheck the control's setting to be sure it's not on a heat-free setting. Check the gas valve behind the dryer to be sure the gas supply is turned on. Also make sure the house's main gas valve is turned on.
4) Most modern dryers have electronic ignition instead of a pilot light. If yours has electronic ignition and isn't heating, call a qualified repairperson.
On an older dryer, make sure the pilot light is burning. If it isn't, relight it. You can find directions in your owner's manual, and pilot light instructions are often mounted next to the pilot light on the burner, too.
Thanks for using FixYa
Jan 03, 2009 | Kenmore 63942 Dryer
Does a Kenmore Elite H3 dryer have a pilot Light???
No. They are electronic ignition. just plug it in and hook it to gas and should heat up.
Nov 21, 2008 | Frigidaire FGQ332ES Gas Dryer
Hw120m washer/drier
Check if the dryer is heating, if it is not heating check the following There's no heat
Oct 16, 2008 | Hoover H130E Front Load Washer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
